Old 9th August 2006, 12:55   #1
panky12345's Avatar
Thanked: 151 Times
Default amp clips at high volume
hi gyz,
i recently bought a pio 6100f.....when i went to get it installed, i found that it shuts off for few seconds while playing the low notes at high volume, while its clear and continous at low volumes....done everything, including removing 0.5 F capacitor, installing new wiring incl RCA cables, but it doesnt seems to solve the problem.
the installer told me that it has something to do with the "MOSFETS". any inputs why and how it could be resolved.
Old 9th August 2006, 13:00   #2
Thanked: 295 Times
what are the stuff ur running on the amp....
what is power wire size and the ground wire size on the amp.....
what is the gain setting....
what are bass setting on the hu...
there will be many more question .....but these will help a lot in resolving the problem....
also clipping and shutting down are both different problems.....
Old 9th August 2006, 14:29   #3
panky12345's Avatar
Thanked: 151 Times
stuff : channel 1 & 2 to power Xplod XSGT 6945 and channels 3 and 4 bridged to Pioneer TS126C sub.
Power wire and ground wire: 8 gauge each, gain setting: Full, Bass setting on HU: 4 (xplod XRCA620X - casseete player mated to 10 MP3 changer).
as i turn up the volume on HU & theres a low note, sounds disppear for about 10 sec and then come back and then disappear and so on till i turn the volume down.
Old 9th August 2006, 14:43   #4
gunbir's Avatar
Thanked: 25 Times
Panky amp gains are not volume knobs... turn your gain down to about 65-70%. Your amp is clipping away to glory... keep it up and you're gonna blow something damn soon...
Old 9th August 2006, 14:47   #5
panky12345's Avatar
Thanked: 151 Times
thanx gunman, do u think turning gain to 65-70% would solve this problem? (irrespective of the volume at HU)
Old 9th August 2006, 15:08   #6
Thanked: 295 Times
gain setting: Full,
man u r taking full juice out of ur pioneer ...
as u have said that the pioneer sub is C so it must be a 4 ohms one and two sony speakers that is not much of a load to this amp....
as suggested by our gunbir phaji reduce the gains to nearly 60-70 %
check the ground and power wire connections......
or rest u can come down to fbd i can practically see and telll
Old 9th August 2006, 18:14   #7
panky12345's Avatar
Thanked: 151 Times
yup phaaji, its an SVC 4 ohm 12" (eqv to Pio TSW306C)....ground cables and power wire are perfect. i used entire new lot (externally) to power the amp, but it still doesnt work! it took me more than 4+ hrs to do the entire permutation and combination lot!
as for full gain, if its capable of producing 120 X 2 RMS, am allowing it to do that!! (at least for couple of minutes)
as for FBD, u need to PM me your #/ call at my #, so that we may carry it fwd!!
Old 9th August 2006, 21:38   #8
Thanked: 295 Times
till now no program....
but if there will be any we will let u know.....
Old 10th August 2006, 00:19   #9
gunbir's Avatar
Thanked: 25 Times
Panky, again, you've got this wrong... The gain DOES NOT work like a volume knob. It is not a control for increasing/decresing volume or setting the amp to its max by setting it on full...
Based on what maximum clean preamp voltage your HU can provide (typically at about 75-80% on your HUs volume), gains are meant to be MATCHED to your HUs output. Somewhere in between the minimum and maximum of the gain, there is a point that can be set by measuring (or even by ear). It is at this point that your amp will give max undistorted output.
Old 10th August 2006, 10:10   #10
kb100's Avatar
Yup!1.. Listen to the experts Panky... Else you most definitely will be blowing something soon!... Full gain is NEVER on!
kb100 is offline   Reply With Quote
Old 10th August 2006, 11:54   #11
Panky,
Your gain settings are wrong.
Turn the gains down, as i remember there is marking on the amplifier's gain pots labeled as Nominal. Set the gains to Nominal position.
Autophile is offline   Reply With Quote
Old 10th August 2006, 12:16   #12
Thanked: 28 Times
Folks ,request you'll to reinvente the wheel,
Mine is a scorpio,
current set up- 5850 Pioneer hu,6" Boston components in the front,assembled amp(malaysia),pioneer sub with enclosure,6x9" pioneer 3 way -rear.
My question -what amp upgrade would you'll suggest.
cheers.
PRADEEP KUMAR is offline   Reply With Quote
Old 10th August 2006, 14:15   #13
navin's Avatar
Thanked: 4,351 Times
pradeep, what is your budget.
Old 10th August 2006, 14:26   #14
Thanked: 28 Times
Boss,
lets say 10-15k
cheers
Old 10th August 2006, 14:51   #15
navin's Avatar
JBL 75.4 for 13K fits right in. I am quite sure there are others.
Watch movie trailers and Imax clips in 720p and 1080p resolution!!! Shan2nu Shifting gears 21 25th September 2007 22:40
Low volume high pitched squealing noise in Siena 1.6 ece2k2 Technical Stuff 3 18th August 2007 20:53
Some Clips of Indians Driving eflanker Street Experiences 2 23rd July 2007 23:21
why sound is harsh at high volume overdose14 In-Car Entertainment 21 25th July 2006 23:36
Video clips ? khaadu75 Shifting gears 9 25th October 2005 09:29
