Old 10th August 2006, 16:06   #16
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by whatcanthisbe
From what i know of subs they just produce the boom boom .. rite ... i dont really want that boom boom .. correct me if i am wrong
i want sound clarity and each note to be distinct.... say 20-30 is the budget .. and with the DSP linked above i can set the listening position to driver only and all 4 speakers will be adjusted to my position in the car andthe sound stage set accordingly...
pls let me know...
again i dont want a box as trunk space is critical for me.
u can get boom boom , dhoom dhoom or the ching ching depending on how u set ur eq & sound settings in ur hu. if u r a real connoseiur, u will appreciate the deep resonance from the sub to go with the sharp sounds from ur tweeters. i think iraghava has given u a pretty good combination. prune it a little if it affects ur budget & add them later. amp is a must, even if u dont want a sub.
cheers
Old 10th August 2006, 16:50   #17
whatcanthisbe's Avatar
Originally Posted by iraghava
That's a good setup but what budget are you looking at??
Sub could be Pioneer 306 or JBL GT 12. Not sure if you have too many options for 10"
Amp again depending on your budget either you can get a decent 2-ch amp or a monobloc to drive the sub.
Do you want the speakers to be driven off an amp too??
should the speakerds be driven off an amp
i am getting the infinitys for like 6.5
the fonts for 1.5
the hu for 6
i have abt 8 k to play with
so sub and amp for 8 k
BUT open air no box
whatcanthisbe is offline   Reply With Quote
Old 10th August 2006, 21:09   #18
iraghava's Avatar
Thanked: 156 Times
the fonts for 1.5
the hu for 6
BUT open air no box
If you want good sound the speakers should also be driven off an amp. But since you have a limited budget, you can drive them off the HU too.
So you are getting Infinity 6*9's for 6.5k. I would advise you to drop them as they would create a rear soundstage which you do not want unless you are chauffered. I would advise
JBL Comps at the front 6-7k (This will give you good front sound stage)
JBL Co-Axials at the rear 3-4k
Pioneer 306 Free Air woofer on rear tray 3.5-4k
Sony 502 Amp 3.5-4k
Wires & Install 2k
P.S. Sam/Navin/Gubir/B&T - Is it advisable to install a free-air woofer? Would it pump out any SQ or will it just be boom-boom? Do you think he should probably drop the amp & woofer & go in for a good 4-ch amp to drive the speakers??
Old 10th August 2006, 21:52   #19
Thanked: 294 Times
I think I will do the job it will be nice sound if tuned properly.....
I used to have 2 subs in the rear deck and they sounded very nice and lowwww......
Old 11th August 2006, 11:48   #20
on what car ?
mine is a lancer so a bigger trunk
Old 11th August 2006, 11:59   #21
I wnat the sound coing from all directions and in a lot of the jazz and instrumental that i listen to different sound come from different directions so if i have underpowered ones for the rear then woundnt there be a sound diff ?
gimme some model numbers for the front and rear .. i need to get this done tmr
Old 11th August 2006, 12:46   #22
k i was looking at fxaudio and at JBL's site ... i saw the GTO507 for the fornt .. is that a single speaker or does it come as a set
http://www.fxaudio.com/caraudio/jbl-speakers-gto507.htm
http://jbl.com/car/products/product_...at=GTS&ser=GTS
i have pretty much decided to go with JBL speaker and the 5950 unless some one can convince my ears and pocket other wise.
Old 11th August 2006, 13:05   #23
iraghava's Avatar
Thanked: 156 Times
All speakers come in a set of two i.e. for the 507 you will have two bass speakers, two tweeters & two crossovers. Subwoofers are sold as single units.
JBL is a very good choice & VFM.
Old 11th August 2006, 13:06   #24
i meant the midrange the tweeter and the crossover together ... as a set
but ty man
appreciate it
Old 11th August 2006, 13:12   #25
Thanked: 26 Times
but ty man
appreciate it
yes whatcanthisbe.... when you buy gto507, you would get 2 tweeter, 2 midranges and 2 cross overs( total 6 items) in the package!!...
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 11th August 2006, 15:45   #26
Driven's Avatar
WCTB,,, with ur music tastes you should get a listen of Hertz components and speakers,,,
I wnat the sound coing from all directions and in a lot of the jazz and instrumental that i listen to different sound come from different directions so if i have underpowered ones for the rear then woundnt there be a sound diff ? gimme some model numbers for the front and rear .. i need to get this done tmr
Driven is offline   Reply With Quote
Old 11th August 2006, 16:44   #27
Thanked: 451 Times
invest on good quality speakers & amp, if ur budget would allow that...try hertz or boston also, but amp is a must, if u really love ur music.
corsa 1.4 gsi..suggestions advice turbo_lover Modifications & Accessories 53 25th June 2014 08:51
Gypsy mod suggestions needed vyvek Modifications & Accessories 9 31st March 2010 18:54
Honda city 1.3 EXI, suggestions please Surprise Shifting gears 15 11th March 2005 00:03
need suggestions normally_crazy Modifications & Accessories 6 30th June 2004 02:13
performance suggestions for CBZ MadMax Motorbikes 6 19th June 2004 09:55
