Old 10th August 2006, 15:22   #1
redeye's Avatar
Unhappy audio installs for lancer
Hi guys ..i have a lancer sfxi
i want to install very good sub woofers for it ...pls suggest which sub woofers with high RMS along with good amps , i want my car to be heard from a long way...
my car audio setup right now is
1.panasonic dvd head
2.jbl component front gto 606ce
3.rear cs396e 6x9 speakers
4. one ,4 channel amp jbl CS60.4.
5.a sub woofer GTO1204br
i need bass boost i will add a mono block and 1 or 2 subs which do u recommend..
my friend amit suggested me
*use your existin JBL CS amp to power the front and rear speakers
*Get 2 JBL CS1200T bass tubes OR 1 JBL GTO 1000W bass tube
*If u can, then wait for sometime and buy a JBL GTO301.1 mono amp
*Connect the bass tube/tubes to the amp.
*You can use 2 CS bass tubes OR at the max 1 GTO bass tube with this mono amp.
*Dont miss on the wiring, get a genuine JBL sub/amp con kit.
*May be after sometime you would be required to install a Capacitor
wat do u think pls help guys, thank u
redeye is offline   Reply With Quote
Old 10th August 2006, 15:29   #2
Thanked: 294 Times
how much u can spend on the whole setup.....................
Old 10th August 2006, 16:34   #3
Thanked: 17 Times
Your friend's suggestion seems good. It cant be decided because you have'nt mentioned your budget.
As you want the sound to be heard outside the car, Bass tubes are ok for you. Basstubes will give enough boom-boom and that will satisfy you. Or you can consider getting a Bandpass enclosure from JBL http://www.fxaudio.com/caraudio/jbl-...gto1204bpd.htm
And get a Monoblock amp. I will suggest to get a 601.1 monoblock. BTW, this setup will cost 30k! Is it under your budget?
Old 10th August 2006, 17:03   #4
Thanked: 294 Times
one more thing install three 306 and some ts-20s like our busted.....
Hey we can tellu lots of option but first we need a limit to how much u can spend I would not recommend bass tube because they are not loud enough .....I would recommend bass tube to those who need neat and clean install and need a little bass in the system...
Old 10th August 2006, 23:30   #5
redeye's Avatar
Smile
my budget is 35000, and how much rms is required to make the car be heard blocks away ..
Old 11th August 2006, 00:47   #6
Thanked: 21 Times
Actually all you need is a tankful of petrol and a lit matchstick...
Go for 2x Pioneer 12" subs and as many Pioneer Monoblocks...
Old 11th August 2006, 09:36   #7
Thanked: 294 Times
man this is not a answer how to make ur car sound ...... I think u need to re-evaluate your listening tates....
any ways if u need what u want it will not be achived in 35k it is very less as the demand u have put.....anyways in my car there are two alpine mono block capable of 2000 watts rms with pioneer spl woofers this only costed me nearly (29+29+9+9) 76K I cannot achive what u want I think u have got my point.....Increase ur budget or..........
Old 11th August 2006, 09:51   #8
navin's Avatar
Thanked: 4,282 Times
1W rms is adequate if you had a pair of Klipschorns in your car. :-) I tis not watts but SPL that matters.
BTW if your car can be heard blocks away it is not good for anyone to be sitting in your car.
Old 11th August 2006, 12:16   #9
amit_sound's Avatar
hi redeye,
Are u Ram from orkut??
amit_sound is offline   Reply With Quote
Old 11th August 2006, 15:35   #10
redeye's Avatar
ya amit it's me ... just thinking wat to do ..i'm kinda confused ,amit bro how does ur car system sound i mean is it heard out side the car..
Old 11th August 2006, 15:36   #11
redeye's Avatar
Unhappy
so much do u think i must raise my budget???
Old 11th August 2006, 18:01   #12
amit_sound's Avatar
As i have told you that i have a JBL601.1 with two 15" JBL woofers. It produces lot of pressure in the cabin, that i it is unberable at time. Come to bombay and i'll show you my car so that you can judge for youself. SAM, has heard my car, and you can ask him. And it makes sense believing guru log like SAM, Navin etc..
SAM sir, help him out!!
Again let me tell you, that simply have a 601.1 with GT4-15 does not mean that it'll be awsome. You need to have proper wirings, dampings, capaitors and most of all a box as per the spefication mentioned.
Try using 15" woofers with a mono amp in some Desi box/wiring worth 400 Rs. I bet you will never wanna listen to it again.
The box which i have in my car cost me 4500 Rs as it was custom build and according to specs.
Old 11th August 2006, 18:08   #13
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by gunbir[B
]Actually all you need is a tankful of petrol and a lit matchstick...
[/b]
aptly put, on target, gunbir
Old 11th August 2006, 18:18   #14
rsjaurr's Avatar
Thanked: 27 Times
Hey redeye
dont listen to LBM when he says what spk/sub to buy and dont ask Kb which amplifier to buy.
Do what speedzak has told u.
Get 600.1 amp and add two 12" subs in ported box.If still want more bass,shows us more money.
BTW,why u want othern to hear ur ICE system when u have spend from ur own pocket.
rsjaurr is offline   Reply With Quote
Old 11th August 2006, 18:43   #15
Thanked: 26 Times
man,
every one who comes here... one or other way, would raise their initial budgets....
here is my $0.02...
if you could wait for some time... wait till year end (say nov - dec time)...
this is the holiday season in US... ask some one coming from US (ie. if you know somebody in US) to bring you the amps and subs.. (atleast the amps..) you would get atleast 50% off on all the products... now is the summer there and not a right time to buy from US...
anToNIcHeN is offline   Reply With Quote
The Downside of High-End Audio Installs GTO In-Car Entertainment 78 3rd February 2015 12:36
Bad Installs... gunbir In-Car Entertainment 179 24th July 2009 01:17
Audio Installs *Done In Cochin* muneemmk In-Car Entertainment 62 10th April 2009 13:06
Under dash woofer and other insane installs. low_bass_makker In-Car Entertainment 43 6th August 2008 13:10
some nice installs. navin In-Car Entertainment 8 23rd February 2008 21:48
