Old 12th August 2006, 11:11   #1
gonecase_01's Avatar
Default subs for swift ???
hey guys
i have a silver swift zxi, with pioneer 7750 but the only problem is that according to my sound guy i can't fit a sub in the rear parcel tray since the ones fitted in swift are really small.
i really need some advice as in how to get some subs in my tray.
gonecase_01 is offline   Reply With Quote
Old 12th August 2006, 11:12   #2
karthik247's Avatar
Thanked: 16 Times
Why do u need them on the tray? You can always have a enclosure for the subs and keep it in the boot.
karthik247 is offline   Reply With Quote
Old 12th August 2006, 11:22   #3
navin's Avatar
Thanked: 4,282 Times
The Swift tray is barely wide enough to accomodate a 6x9 or 8" sub. I suggest usig a box if you can spare the room in the trunk or using 2 8" subs instead of a 12".
Old 12th August 2006, 12:04   #4
jkdas's Avatar
Thanked: 1,436 Times
emm, or maybe the SWWS install if you wnat boot
Old 12th August 2006, 12:32   #5
kb100's Avatar
lol ... I guess most newbs are going to need help with that one JK... everytime we use SWWS most ppl must be going -"Duh?"
kb100 is offline   Reply With Quote
Old 12th August 2006, 12:37   #6
jkdas's Avatar
alright, its Spare Wheel Well Sub install. Use the search thingy using it
Old 12th August 2006, 16:36   #7
freakrz's Avatar
Thanked: 50 Times
forget the tray on the swift...even for placing the speakers ..its a big mess...try to get it in the boot nd just pull of the tray...
freakrz is offline   Reply With Quote
Old 12th August 2006, 18:09   #8
Thanked: 294 Times
I would suggest go for a 10 or 12 inch sub....in a sealed box....that will do a fine job....if the boot space is required you can remove the sub when required... I would not recommend the Spare Wheel Well Sub because it will require expert hand to install other wise it will not sound bad......
2 Subs - Dual Mono or Stereo - "Kb ka dB" kb100 In-Car Entertainment 847 1st October 2007 07:52
Please Review Soomoku Subs & Speakers SoundManiac In-Car Entertainment 68 19th June 2007 21:03
10" Vs 12" Subs harmon_bro In-Car Entertainment 9 29th May 2006 11:55
Car subs for home use Vivekphadnis In-Car Entertainment 90 11th April 2006 16:20
Amps / Subs abhibh In-Car Entertainment 3 31st March 2006 10:32
