Old 17th August 2006, 02:37   #16
929RON's Avatar
An Amp is like the heart of the system, a Bad amp can make a system with the best speakers sound terrible,
But a Good amp with average speakers can sound good.
The power rating on every amp is not proportional to the output they give, some amps will write big numbers but not deliver, Only amps which are CEA Rated on power will deliver the rated power even when Battery Volate is on the lower side.
Well no amp performs well under 10 Volts, but that is a different story.
Verdict - always have a very good amp and head , Half the jobs done.
929RON is offline   Reply With Quote
Old 17th August 2006, 15:53   #17
Bass&Trouble's Avatar
Thanked: 74 Times
This may sound like I am getting a bit too critical with your posts, but the verdict part should actually go - always have good car audio components all around. They should all be of even calibre.
Please don't mind. I thought some newbies might read a bit differently into it.
This depends on the amp's design. There are amps that can 'hold' their power delivery numbers within 2% of rated between 10 to 16 volts. While others could put out upto 50% more power at 16V versus 10V. That's regulation.
Well, no one would want that to happen either. If it did, and did it well, that would be the only electrical appliance still running in an otherwise helplessly-electrically-screwed-up car.
Old 17th August 2006, 19:13   #18
i still didn't get the answer to my questions
1. what will JBL GTO 601.1 , JBL GTO 1201.1, pioneer amp or sony amp will cost around and also jbl subs with bill & without bill (grey) .please mention power(Rms) of the amp & sub. i need 1X 1000w Rms or 2X 500w rms D class amp.
2. btw i have uploaded video of my friend's pioneer dvc with glider amp , you see , hear & decide whether the amp is clipping or not. i have measured the output voltage of the amp in bridged mode , it was around 27 V .each coil of dvc was recieving 27 volts.
video
[COLOR=#800080]http://rapidshare.de/files/29615442/pioneerdvc.pdf[/COLOR]
rename extension pdf to divx
3. do we have HIFONICS BXi 2006D or BXi 1606D or BXi 1206D available in india ?
virender_gaur is offline   Reply With Quote
Old 17th August 2006, 19:32   #19
jp1
Thanked: 44 Times
Guys, I have no idea about which amp to go for or which speaker to go for. But what I noticed is the location of the monitor, it make me nervous... Is the intention is to see movie while driving!!. It looks very very scary. Are these allowed as per our Motor vehicle act?
jp1 is offline   Reply With Quote
Old 17th August 2006, 20:11   #20
Sam Kapasi's Avatar
Thanked: 1,474 Times
Virender there is no need to make the same post twice. People can read the first one just fine. Please do not do that in the future, thanks.
Old 18th August 2006, 00:17   #21
amit_sound's Avatar
A JBL 601.1 will cost you 19,990 B&W. (424 x 1 RMS at 4 ohms)
JBL 1201.1 will cost you 32000 B&W (748(app) x 1 RMS at 4 ohms)
What subwoofer are you planning to buy??
amit_sound is offline   Reply With Quote
Old 18th August 2006, 10:19   #22
Thanked: 295 Times
pioneer 510D mono block will be
Continuous power output
300 W × 1 (at 14.4 V, 4 Ω, 20 — 240 Hz, 0.4% THD)
500 W × 1 (at 14.4 V, 2 Ω, 20 — 240 Hz, 0.8% THD)
price will be nearly 10k without B/W
Old 18th August 2006, 11:17   #23
jkdas's Avatar
Thanked: 1,436 Times
amit could you post prices of 300.1 and 301.1 too pls.
and waht would that Pio mono cost ( grey )...okok. 10k , just read lbm's post
Old 18th August 2006, 21:01   #24
JBL 1201.1 @ Rs. 32000
it's specification
Amplifier Type: Mono
power @ 4 Ohms: 787W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: <1 %
Bridged RMS Power @ 4 Ohms: 1114W x 1 @ 2 Ohms
Speaker Level Inputs: yes
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0 - 12 dB
Frequency Response: 10-302 Hz
Signal to Noise Ratio: 70 dB
pioneer 510D mono block @ 10k without bill & warranty ( didn't get any information regarding this amp on net if some one can post the link it will be helpfull )
SONY XM-SD51X @ Rs.12000 ~ 13000 with bill & warranty
rms power 250 w @ 4 ohm (0.3 % thd)
500 w @ 2 ohm (0.6% thd)
S/N ratio 100 db
freq response 5~300 Hz
http://www.sonyindia.co.in/static/Ca.../xm_sd51x.html
i think buying 2 sony amps will be a good choice
& mating them to 2 pio DVC
Old 18th August 2006, 23:03   #25
Thanked: 17 Times
I would suggest you go for Alpine MRD-M605.
• 250W x 1 RMS (4ohm, 12.0V, 1% THD+N)
• 400W x 1 RMS (2ohm, 12.0V, 1% THD+N)
• 400W x 1 RMS (4ohm, 14.4V, 1% THD+N)
• 600W x 1 RMS (2ohm, 14.4V, 1% THD+N)
• Max. 1.000W x 1
• Frequency Response 20Hz-20kHz (0, -1dB)
• S/N Ratio 90dBA
It costs a cool 22,500/- with B&W. Can handle 2 subs if needed.
Old 19th August 2006, 10:02   #26
Thanked: 295 Times
http://www.pioneerelectronics.com/pn...850147,00.html
here u go for the pioneer D510 if compared to the other mono block this is surley best bang for the buck but the only problem is that it comes in Grey no B&W here...... other wise it is the best money can buy.......
and it can also handle two subs provided they are 4ohms svc......
or two of these amps for two dvc ( I have personnal have listened to this setup man they pound a lot)
Maximum power output
600 W × 1 (4 Ω) / 1,000 W × 1 (2 Ω)
Load impedance
4 Ω (2 — 8 Ω allowable)
Frequency response
5 — 240 Hz (+0.5 dB, –3 dB)
Distortion
0.03% (10 W, 120 Hz)
Old 19th August 2006, 10:05   #27
Thanked: 295 Times
Max. 1.000W x 1
S/N Ratio 90dBA
some thing written wrong here...........
Old 19th August 2006, 17:42   #28
Thanked: 17 Times
What is wrong?
It's from the owners' manual I have and the alpine website says the same too.
Old 19th August 2006, 19:05   #29
Thanked: 295 Times
Max. 1.000W x 1
S/N Ratio 90dBA
Frequency Response 20Hz-20kHz (0, -1dB) its saying 20Hz-20kHz this cannot be true..... it is a sub woofer amp not a full range amp......and the site says.....RMS Power (at 14.4V,20Hz-200Hz)
http://www.alpine-usa.com/en/product...model=MRD-M605
Old 20th August 2006, 20:19   #30
kb100's Avatar
Thumbs down Watch Out For Stuff Like This!!
Whatever you do stay away from things like this...Look at what I found on Rediff!!
http://shopping.rediff.com/shop/prod..._home_leftnavi
kb100 is offline   Reply With Quote
Please help me select the right amplifier for my NHC Auriga In-Car Entertainment 6 29th March 2014 21:06
Need help deciding on a JVC Subwoofer and Amplifier ghpk In-Car Entertainment 31 25th April 2012 03:51
Pls help me Urgent: Help me to connect ipod classic to amplifier vasudeva Gadgets, Computers & Software 2 5th October 2009 17:14
Need help selecting a 4ch amplifier jCube In-Car Entertainment 72 26th February 2007 13:02
accord is it right price and right time to buy used rubin2006 Luxury, Imports & Niche 15 6th December 2006 15:36
