Old 30th August 2007, 13:20   #16
navin's Avatar
Thanked: 4,286 Times
Originally Posted by clearmusiclover View Post
(1) If I were to change the speakers, should I change ALL the four? I don't understand why sam said that I should change the front speakers.
(2) Does having an amp and speakers (including Sub) from the same brand make a better setup than the one with different brands?
(3) How does Blaupunkt as a brand compare with JBL and others as a whole (quality, reliability, price-worthiness)?
(4) I see Blaupunkt setting up a chain of distributors/dealers across the country (including Pune where I live). I don't see such easy access for other brands. From this point of view is Blaupunkt a better option to go for?
1. if you are on a budget only change the front speakers. if the budget permits you to change all 4 then by all means do so.
2. not nessacarily. you can use a Pio amp to drive a JBL sub etc... it makes sense to get the best amp and best sub you can afford regardless of brand.
3. Blau makes HUs JBL does not. Both are reliable, both have good A.S.S, and both are good VFM.
4. Blaupunkt has an advantage in that it is managed by Mico Bosch in India.
Old 1st September 2007, 17:25   #17
Thank you Navin! After going through many posts on Team-BHP, I narrowed down on the following config -
HU - Alpine CDE9845 (OE)
4 ch Amp - JBL CS60.4
Mono Sub Amp - JBL GTO301.1
Sub (box type) - JBL CS1204B
Front components - Infinity Kappa 50.7cs
Rear Co-ax - ?
Many people suggested that if I have Kappa front components, it is better to go for Kappa rears. I could not find a suitable one yet.......
Can someone advise, if this makes for a good setup in a New Honda City (NHC) GXi?
Also please advise on the rears part...
Thanks a lot!!!
clearmusiclover is offline   Reply With Quote
Old 2nd September 2007, 01:33   #18
navin's Avatar
Rear Co-ax - ?
Many people suggested that if I have Kappa front components, it is better to go for Kappa rears. I could not find a suitable one yet.......!!
1. why not the 60.7 it fits just as well. and the 62.7 for the rear.
2. kappa is less available than the reference series which is cheaper so be prepared to look hard for kappa.
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
Found a Used City EXI 2006 Nov Model done just 8k Kms Genuine - Suggestions please? thereal Sedans 4 18th May 2010 22:51
Fiesta 1.4 EXi Vs NHC EXi Vs SX4 ZXi rahul_intlad Sedans 60 16th May 2007 16:50
2003 Honda City 1.5 Exi jesal Shifting gears 15 18th January 2005 20:38
