Closed Thread
Old 29th August 2006, 20:35   #31
Default More questions
As suggested by you guys, I went to the installer and wanted to try out JBL 426/kicker4" compos connected to the Amp..
But to my surprise these guys said that the high power amp (sony 504) will blow out the small powered front speakers. Is this true? I was so surprised and I came back without doing anything.
Experts, please advise!
AdXing is offline
Old 29th August 2006, 21:24   #32
rareone's Avatar
Thanked: 11 Times
i had my JBL 426 connected 2 sony xplod 504 amp.
Nothin happened 2 it in 1 year.
May be you have to do the gain settings in amp...
rareone is offline
Old 29th August 2006, 21:35   #33
thnx rareone...
can you please explain as to what do you mean by gain settings in the amp? I am confused
AdXing is offline
Old 29th August 2006, 23:44   #34
Thanked: 13 Times
1. Surprise surprise...
2. NOT TRUE ! Its just a bull**** crappy marketing ploy to sell you something else.
3. Its good you left on your instinct without making a purchase.
4. Im not an expert... but hope this helped
s0uljah is offline
Old 30th August 2006, 09:41   #35
navin's Avatar
Thanked: 4,282 Times
thnx rareone...
gain settings allow you match the level of your speakers. they are used to fine tune front/rear levels but by setting the gain low you can make sure that no matter how high you turn the HU the amp wont deliver enough power to damage your speakers.
BTW it is easier to blow out a speaker (esp a tweeter) using less power than more power. When you use too little power the amp will CLIP. when an amp CLIPs it produces a lot of high frequency energy. Tweeters are not designed to handle that and quitely die. woofers on the other hand will complain (bad distorted sound) before dying.
I hope this explanation is simple enough. If so Sam would be pleased.
navin is offline
Old 30th August 2006, 11:00   #36
thanks Navin..
I currently have a Sony504 amp connected to my rear speakers GTO936.
I was thinking to connect the amo to the front speakers as well (GTO426).
Now, my question- Is there any probs with the above setup?
What should be the gain setting on the amp for the above setup to deliver optimum performance?
AdXing is offline
Old 30th August 2006, 11:25   #37
jkdas's Avatar
Thanked: 1,436 Times
thanks Navin..
it is purrrffectly fine. If I could I would ahev even powered mine with Pio 6100 amp.
abt tuning, emm, hope your installer is a good guy at it. If you doubt him ( well, your gain thingy screw will by set at full or so), read that post by kureti,post doubts, experiment, use your years or/and easier way is to go to a good installer recommended by other Hyd tbhpians
jkdas is offline
Old 30th August 2006, 11:49   #38
rareone's Avatar
Thanked: 11 Times
Wink
thanks Navin..
The above setup has no probs. This is the way people connect thier front and rear speakers on a 4 channel amp...
rareone is offline
Old 30th August 2006, 12:19   #39
Well said jkdas, currently my gain control screw is set to full...
I guess I need to tune it after connecting it with the front speakers.
Anyone knows a good installer in Hyd please help.
AdXing is offline
Old 30th August 2006, 14:06   #40
I was browsing and I found only 1 4" kicker component model ES4.2
Do you think this will be a better bet than GTO426?
Actually, the kicker 4" comp I couldn't find in the shops I searched. So I have to order it. Ppl who have listened to both please advise.
AdXing is offline
Old 30th August 2006, 17:49   #41
Thanked: 26 Times
navin, can you explain this?.... little power?... where?...
regards,
ant.
anToNIcHeN is offline
Old 30th August 2006, 18:39   #42
Sam Kapasi's Avatar
Thanked: 1,473 Times
When you use a LOW powered amplifier (or in navin's words, too little power) to turn the volume up, you will overdrive the amp, driving it into clipping mode. It is easier to blow a speaker with this, than with a higher powered amplifier.
Sam Kapasi is offline
Old 30th August 2006, 19:00   #43
nitrous's Avatar
Thanked: 285 Times
the speaker is a pioneer 6x9 directly installed under the stock location.....
That is some space saving,bro.
Before this, i didnt know u could fix a 6x9 there.Maybe a 6" though.
nitrous is offline
Old 30th August 2006, 19:56   #44
angelfire's Avatar
thanks Navin..
Well buddy...how`s the quality of sound in your present set up..in terms of bass..clarity.. etc...cause am thinkin of the same kind of setup...
angelfire is offline
Old 30th August 2006, 20:36   #45
I currently have GTO936 at the rear connected to the amp.
At front, I have crappy sony speakers provided free by the dealer.
So currently, the sound is pretty good, bass is nice but I want a little more clarity. Also, it is very rear-heavy and almost no sound coming out of the front.
So I am going to get better speakers at the front...and hook them to the amp. I have a limitation of size though - 4"
So I am looking at the following ones:
1. Kicker 4" comp ES4.2
2. JBL GTO 426/ P452
I have only heard the JBL GTO426 one and its good.
But the other ones are not available at the accessory shop.
So, if I want any of those, I need to order...
So, Guyz please advise as to which one will be the better choice
AdXing is offline
Closed Thread
SQ settings for my Santro's setup and rear speaker placement options sidindica In-Car Entertainment 2 6th February 2012 15:46
Sound in the rear speaker is very low.Need advice bsanjayrao In-Car Entertainment 5 19th August 2009 14:00
Need help! No sound in one of the Rear Speaker! finneyp In-Car Entertainment 11 23rd October 2006 14:04
how is kicker rear speaker amit_sound In-Car Entertainment 9 20th February 2006 13:37
