Closed Thread
Old 2nd September 2006, 22:32   #76
Thanked: 17 Times
Lightbulb
Originally Posted by AdXing
So what should i do?? please advise.
Seems like a wiring problem. So, Just get it done properly!
Whatever you do, dont let your installer make you think of a capacitor for a setup like this!
speedzak is offline
Old 2nd September 2006, 22:55   #77
ya I thought that this should be quite an easy setup to install... but seems like I went to the wrong place.. but is there any problem with fitting a capacitor?
Anyway, I have told the shop owner that if this problem doesn't go away, then I am not going to pay for the amp and the wirings.
AdXing is offline
Old 3rd September 2006, 08:38   #78
Thanked: 17 Times
There is no problem in fitting a cap! It's made to help high end installs. But for your install, adding a cap is not necessary. Not at all needed. The installer is just trying to sell you a cap. That's all!
You have'nt paid him yet?? That's surprising! Normally these guys wont let you go like that.
speedzak is offline
Old 3rd September 2006, 13:10   #79
Thanked: 13 Times
Yeah man it will be something simple like impoper grounding of the amp or botched up connections. Thats why you dont need a capacitor in your particular setup.
s0uljah is offline
Old 3rd September 2006, 21:44   #80
i thought a capacitor is cheap!
Anyway the shop owner said he wont charge me for that...so what say guys?
AdXing is offline
Old 3rd September 2006, 22:34   #81
Thanked: 13 Times
Until the probem is correctyl diagnosed it wont go away so figure out what needs to be done... the cap might not sort it out!!
s0uljah is offline
Old 4th September 2006, 00:37   #82
Sam Kapasi's Avatar
Thanked: 1,490 Times
I think adxing, you need to get better quality RCA cables and you need to lower the gain on your amplifier.
That should sort you out.
Sam Kapasi is offline
Old 4th September 2006, 10:43   #83
well...more update on this... i went to the shop and it was observed that the sound came mostly while honking...it came otherwise also but not so regularly.
the mechanic said that he will fit a capacitor or something like that to get rid of this problem - does it make sense ?
all the technical gurus plzzzzzzzz help me as to what may be the cause of this problem?
some kind of horns are known to create electric interference, which may be audible through speakers. Check this thread, may be you are facing the same problem....
http://www.team-bhp.com/forum/car-en...highlight=horn (Strange noise from speakers)
santosh.s is offline
Old 4th September 2006, 11:02   #84
jkdas's Avatar
Thanked: 1,437 Times
guyz
i connected all 4 speakers(GTO427 and GTO936) to the amp and the sound is good.
BUt after running continuously for some time, some strange 'phat phat' sound was coming out sometimes. The frequency of this sound increased as time went by.
Today morning, there is no such strange sound.
Please enlighten me as to what may be the cause of this problem and whats the remedy?
frm all speakers? and all max vol?
as Sam said, check the gain, did you use good RCA? and is this a whistling type of sound? Is the sound ther when the car's parked/engine off.
jkdas is offline
Old 4th September 2006, 11:12   #85
navin's Avatar
Thanked: 4,351 Times
I suspect the horn relay is defective. a cap across the horn relay is just band aid better to change the relay itself.
navin is offline
Old 4th September 2006, 11:19   #86
gunbir's Avatar
Thanked: 25 Times
Right on... ALL Santros manufactured between November 2005 and March 2006 (this is the range I have seen thus far, may be more) have this issue. If its just the "pat pat" sound and only when you press the horn, then YES, its the horn relay. Change the relay.
gunbir is offline
Old 4th September 2006, 12:42   #87
jkdas, its coming when souding the horn...and its not a whistling sound.
Also, it comes even when the volume is pretty low.
No sound when car is parked/engine off.
Also the mechanic suspected something wrong with the RCA cable...he tried 3 difference RCA cable, but still the same problem.
So, I suspect the problem may be with the horn relay...I will try to change that and see if the sound goes away.
AdXing is offline
Old 4th September 2006, 12:43   #88
Gunbir man, you are spot on...
thats exactly what is happening. Can I get the horn relay changed from the company? How much does a horn relay cost?
AdXing is offline
Old 4th September 2006, 16:18   #89
Since the audio setup was done outside, will the dealers change the horn relay free of cost? How do I convince them to do it as part of the warranty?
In the worst case, how much I need to pay for a new horn relay?
AdXing is offline
Old 4th September 2006, 16:44   #90
gunbir's Avatar
Thanked: 25 Times
Not much, a couple of hundred bucks... thats it..
gunbir is offline
Closed Thread
SQ settings for my Santro's setup and rear speaker placement options sidindica In-Car Entertainment 2 6th February 2012 15:46
Sound in the rear speaker is very low.Need advice bsanjayrao In-Car Entertainment 5 19th August 2009 14:00
Need help! No sound in one of the Rear Speaker! finneyp In-Car Entertainment 11 23rd October 2006 14:04
how is kicker rear speaker amit_sound In-Car Entertainment 9 20th February 2006 13:37
