Old 26th August 2006, 00:55   #1
First of all, let me thank team-bhp users for providing wealth of information here on indian cars. After reading this forum and considering some practical features, I bought Getz last month.
I've also been searching this forum to get an idea of car audio setups and options. What an experience and stunned by the professional answers and suggestions.
I've a question regarding my simple car audio setup:
For the headunit,
I've shortlisted the recently launched Kenwood KDC MP5033U in India. Specs - Power: 22 W X 4, Speaker Impedance: 4-8 Ohms.
For now, I would like to make it simple with no amp & sub- woofer and just have front components & rear coaxial speakers on doors (as suggested by many here). All power specified in RMS below.
Front - JBL Component GTO607. Specs - Power: 50 W (Tweeter) 70 W (2-way component), Impedance: 2 Ohms (Tweeter) 2 Ohms (2-way component).
Rear - JBL Coaxial CS2165. Specs - Power: 40 W, Impedance: 4 Ohms.
My question is whether the lower power of HU amp can drive the high power and produce good sound quality? Is any external amp necessary in the above setup? I read in Crutchfield that it is advisable to overpower rather than underpower the speakers.
Also, is it required to match the impedance of HU with speaker?
The reason for not going for amp & sub-woofer is primarily not to lose boot space and to avoid modifications.
Appreciate your patience in reading this and any inputs will be valuable.
Thanks,
Hitra.
hitra is offline   Reply With Quote
Old 26th August 2006, 12:23   #2
Thanked: 294 Times
the above setup will work fine till a certain volume. after the sound will start distorting and then the whole sound scene falls apart. if u listen to low volume and dont play it hard then this is best combination which will satify your need.
but if u add a amp to it no sub only amp the overall sound will change it will be more cleaner at higher volumes and even at low volumes also. to add a amp to the above setup no mods will be done to the car only 4 screw will be add to fix the amp to a secure position ......
If budget is not a constrain here u can add a amp which will help to improve the sound of the ice quite alot more......
one more thing normally the hu are 4 ohms stable a 2 ohms speaker would might damage the hu or the speaker if played at high volume ........
Old 26th August 2006, 13:19   #3
Sam Kapasi's Avatar
Thanked: 1,473 Times
Ummm, the CS2165 is 4 ohms. The GTO607C package is 3 ohms. (from the crossover input)
You are ok dude, enjoy your music. When you have more money buy an amplifier. cheers.
Old 26th August 2006, 14:01   #4
Thanked: 21 Times
Congrats, its a great car.
For the headunit,
Good choice again. Look up the Getz Install Help thread on how to install it properly.
Will work well. As already mentioned, get an amp. You wont have to modify anything in your car.
Old 27th August 2006, 00:58   #5
Thanks a lot for your inputs.
Old 27th August 2006, 01:23   #6
Thanked: 17 Times
Many thinks an amp is needed if you want a Sub. And Sub is given importance than the amp.
I'll rather choose a nice amp first. An amp can seriously improve the sound quality. So get a nice 4channel amp (alpine, audison, jbl, blau etc..) to power your components and co-axials.
Old 28th August 2006, 23:42   #7
The HU KDC-MP5033U has got two sets of Preamp Outputs (2V each) and no Sub Preamp Outputs. If I plan to add a Subwoofer, is it possible since the HU does not have a dedicated Sub Preamp Output? Where does the crossovers occur - HU or Amp?
I heard there are 6 1/2" subwoofers available in the market. Does it fit on Getz rear doors? If it does fit, having two subwoofers in the doors enhance the bass? Is this setup possible with just two sets of Preamp Outputs?
If this is possible, I can go for 6 1/2" subwoofers on the rear doors instead of coaxials. Is it possible to get some decent bass out of it?
Thanks for your inputs.
Old 28th August 2006, 23:51   #8
Sam Kapasi's Avatar
Hi!
Yes you can, the crossover occurs at the amplifier.
I do not think there are 6.5" subwoofers. And you cannot expect a subwoofer to give you any decent bass in the door.
Old 29th August 2006, 01:35   #9
Thanked: 21 Times
We used to have a 6.5" subwoofer in Hertz but it was discontinued recently... as seen here...
Old 29th August 2006, 09:27   #10
navin's Avatar
Thanked: 4,286 Times
Gunbir what on earth would the owner do ni the rains?
Old 29th August 2006, 10:04   #11
jkdas's Avatar
Thanked: 1,436 Times
nice doubt
and hows it fed?
Old 29th August 2006, 10:31   #12
Thanked: 21 Times
Originally Posted by jkdas
nice doubt and hows it fed?
Hehe Mumbaikars tend to rain-analyse everything, and I dont blame you. I had some pics where they had a fiberglass cover for that. Let me dig em up.
JK, see the footrest, do you catch a glimse of an SRx amp installed there...
Old 29th August 2006, 11:27   #13
navin's Avatar
Originally Posted by gunbir
Hehe Mumbaikars tend to rain-analyse everything, and I dont blame you....
I spent 16 hours stuck in my car waist deep in water on 26-7-2005.
Old 31st January 2014, 11:54   #14
sandeepmohan's Avatar
Thanked: 1,900 Times
Default Re: Matching HU amp power with Speaker power?
Reviving this thread.
I plan to do a speaker upgrade on my Linea. The stock speaker specifications are 20watt@4ohms. Unfortunately, no sensitivity values are given on the speakers. Sensitivity is super important and will decide how hard the amplifier needs to work to wake up the speakers.
I plan to put in the following and would like some clarity on the same. My understanding of impedance suggest that my head unit should be alright. I play loud once in a while but never at ear splitting level.
Blaupunkt CX160 3ohms 92db 62watt nominal power
Blaupunkt Gtx663de 4ohms 93db 50watt nominal power
sandeepmohan is offline   Reply With Quote
Old 31st January 2014, 12:35   #15
DerAlte's Avatar
Thanked: 2,879 Times
... Linea. The stock speaker specifications are 20watt@4ohms. Unfortunately, no sensitivity values are given on the speakers. ...
Technical data on OE components? Yes they are available, you only have to ask the manufacturer of the OE stuff. Since almost no one (other than the car manufacturer's audio guys) needs that info, they are not published
... Sensitivity is super important and will decide how hard the amplifier needs to work to wake up the speakers. ...
Sensitivity simply means how loud will the speaker sound when fed with some electrical power. No, it is not 'super important' - most people do just fine without knowing it. That is because you can't do much - would you not buy the car if the speakers were not sensitive? One just cranks up the volume a bit if it is not loud enough.
... I play loud once in a while but never at ear splitting level. ...
They will do just fine without analysing impedance and sensitivity. You should be more worried about the power level (electrical) at which the amp driving them starts distorting. The amp, especially an HU-internal amp, is more likely to nastily distort at high output levels than the speakers.
DerAlte is offline   (1) Thanks Reply With Quote
Matching component speakers for JVC AVX800 ramkris In-Car Entertainment 12 10th February 2009 17:37
Weak clutch on Esteem - Car speed not matching engine RPM gaurav.28ch Technical Stuff 2 26th November 2008 17:47
Looking for Tonally Matching Fronts with JBL Voice Center Channel pitchucold Gadgets, Computers & Software 1 30th August 2008 21:59
Amps and Speaker matching! anToNIcHeN In-Car Entertainment 16 14th September 2006 18:02
