Old 29th August 2006, 10:50   #1
929RON's Avatar
Default Super Class A/B Amps
I recently read about some Super CLass A/B amps and they claim to be better than Class D amps, now can anyone explain how this Super Class A/B works and whether it is really any better in output ?
When I say output , I mean power.
929RON is offline   Reply With Quote
Old 29th August 2006, 11:09   #2
Thanked: 295 Times
some thing on the ampilifier types......
Power amplifier classes
For a long time the only amplifier classes relevant to high-quality audio
were Class-A and Class-AB. This is because valves were the only active
devices, and Class-B valve amplifiers generated so much distortion that
they were barely acceptable even for Public Address purposes. All
amplifiers with pretensions to high fidelity operated in push-pull Class-A.
Solid-state gives much more freedom of design; all of the amplifier classes
below have been commercially exploited. Unfortunately, there will only be
space to deal in detail in this book with A, AB, and B, though this certainly
covers the vast majority of solid-state amplifiers. Plentiful references are
given so that the intrigued can pursue matters further.
Class-A
In a Class-A amplifier current flows continuously in all the output devices,
which enables the non-linearities of turning them on and off to be avoided.
They come in two rather different kinds, although this is rarely explicitly
stated, which work in very different ways. The first kind is simply a Class-B
stage (i.e. two emitter-followers working back-to-back) with the bias
voltage increased so that sufficient current flows for neither device to cut off
under normal loading. The great advantage of this approach is that it
cannot abruptly run out of output current; if the load impedance becomes
lower than specified then the amplifier simply takes brief excursions into
Class AB, hopefully with a modest increase in distortion and no seriously
audible distress.
The other kind could be called the controlled-current-source (VCIS) type,
which is in essence a single emitter-follower with an active emitter load for
adequate current-sinking. If this latter element runs out of current capability
it makes the output stage clip much as if it had run out of output voltage.
This kind of output stage demands a very clear idea of how low an
impedance it will be asked to drive before design begins.
Valve textbooks will be found to contain enigmatic references to classes of
operation called AB1 and AB2; in the former grid current did not flow for
any part of the cycle, but in the latter it did. This distinction was important
because the flow of output-valve grid current in AB2 made the design of the
previous stage much more difficult.
AB1 or AB2 has no relevance to semiconductors, for in BJT’s base current
always flows when a device is conducting, while in power FET’s gate
current never does, apart from charging and discharging internal
capacitances.
Class-AB
This is not really a separate class of its own, but a combination of A and B.
If an amplifier is biased into Class-B, and then the bias further increased, it
will enter AB. For outputs below a certain level both output devices
conduct, and operation is Class-A. At higher levels, one device will be
turned completely off as the other provides more current, and the distortion
jumps upward at this point as AB action begins. Each device will conduct
between 50% and 100% of the time, depending on the degree of excess
bias and the output level.
Class AB is less linear than either A or B, and in my view its only legitimate
use is as a fallback mode to allow Class-A amplifiers to continue working
reasonably when faced with a low load impedance.
Class-B is by far the most popular mode of operation, and probably more
than 99% of the amplifiers currently made are of this type. Most of this
book is devoted to it, so no more is said here.
Class-C implies device conduction for significantly less than 50% of the
time, and is normally only usable in radio work, where an LC circuit can
smooth out the current pulses and filters harmonics. Current-dumping
amplifiers can be regarded as combining Class-A (the correcting amplifier)
with Class-C (the current-dumping devices); however it is hard to visualise
how an audio amplifier using devices in Class-C only could be built.
Class-D
These amplifiers continuously switch the output from one rail to the other
at a supersonic frequency, controlling the mark/space ratio to give an
average representing the instantaneous level of the audio signal; this is
alternatively called Pulse Width Modulation (PWM). Great effort and
ingenuity has been devoted to this approach, for the efficiency is in theory
very high, but the practical difficulties are severe, especially so in a world
of tightening EMC legislation, where it is not at all clear that a 200 kHz
high-power square wave is a good place to start. Distortion is not inherently
low[5], and the amount of global negative feedback that can be applied is
severely limited by the pole due to the effective sampling frequency in the
forward path. A sharp cut-off low-pass filter is needed between amplifier
and speaker, to remove most of the RF; this will require at least four
inductors (for stereo) and will cost money, but its worst feature is that it will
only give a flat frequency response into one specific load impedance. The
technique deserves a book to itself, and cannot be dealt with properly here.
Other references to consult for further information are Goldberg and
Sandler and Hancock.
Class-E
An extremely ingenious way of operating a transistor so that it has either a
small voltage across it or a small current through it almost all the time; in
other words the power dissipation is kept very low[8]. Regrettably this is an
RF technique that seems to have no sane application to audio.
Class-F
There is no Class-F, as far as I know. This seems like a gap that needs
filling . . .
Class-G
This concept was introduced by Hitachi in 1976 with the aim of reducing
amplifier power dissipation. Musical signals have a high peak/mean ratio,
spending most of the time at low levels, so internal dissipation is much
reduced by running from low-voltage rails for small outputs, switching to
higher rails current for larger excursions.
The basic series Class-G with two rail voltages (i.e. four supply rails, as both
voltages are +/–) is shown in Figure 2.3[9],[11]. Current is drawn from the
lower +/–V1 supply rails whenever possible; should the signal exceed
+/–V1, TR6 conducts and D3 turns off, so the output current is now drawn
entirely from the higher +/–V2 rails, with power dissipation shared between
TR3 and TR6. The inner stage TR3, 4 is usually operated in Class-B,
although AB or A are equally feasible if the output stage bias is suitably
increased. The outer devices are effectively in Class-C as they conduct for
significantly less than 50% of the time.
In principle movements of the collector voltage on the inner device
collectors should not significantly affect the output voltage, but in practice
Class-G is often considered to have poorer linearity than Class-B because of
glitching due to charge storage in commutation diodes D3, D4. However, if
glitches occur they do so at moderate power, well displaced from the
crossover region, and so appear relatively infrequently with real signals.
An obvious extension of the Class-G principle is to increase the number of
supply voltages. Typically the limit is three. Power dissipation is further
reduced and efficiency increased as the average voltage from which the
output current is drawn is kept closer to the minimum. The inner devices
operate in Class-B/AB as before, and the middle devices are in Class-C. The
outer devices are also in Class-C, but conduct for even less of the time.
To the best of my knowledge three-level Class-G amplifiers have only been
made in Shunt mode, as described below, probably because in Series mode
the cumulative voltage drops become too great and compromise the
efficiency gains. The extra complexity is significant, as there are now six
supply rails and at least six power devices all of which must carry the full
output current. It seems most unlikely that this further reduction in power
consumption could ever be worthwhile for domestic hi-fi.
A closely related type of amplifier is Class-G-Shunt.
Some of the more powerful Class-G-Shunt PA amplifiers have three sets of
supply rails to further reduce the average voltage drop between rail and
output. This is very useful in large PA amplifiers.
Class-H
Class-H is once more basically Class-B, but with a method of dynamically
boosting the single supply rail (as opposed to switching to another one) in
order to increase efficiency[12]. The usual mechanism is a form of
bootstrapping. Class-H is occasionally used to describe Class-G as above;
this sort of confusion we can do without.
Class-S
Class-S, so named by Doctor Sandman, uses a Class-A stage with very
limited current capability, backed up by a Class-B stage connected so as to
make the load appear as a higher resistance that is within the first
amplifier’s capability.
The method used by the Technics SE-A100 amplifier is extremely
Similar
I hope that this necessarily brief catalogue is comprehensive; if anyone
knows of other bona fide classes I would be glad to add them to the
collection. This classification does not allow a completely consistent
nomenclature; for example, Quad-style Current-Dumping can only be
specified as a mixture of Class A and C, which says nothing about the basic
principle of operation, which is error-correction.
Variations on Class-B
The solid-state Class-B three-stage amplifier has proved both successful and
flexible, so many attempts have been made to improve it further, usually by
trying to combine the efficiency of Class-B with the linearity of Class-A. It
would be impossible to give a comprehensive list of the changes and
improvements attempted, so I give only those that have been either
commercially successful or particularly thought-provoking to the amplifierdesign
community:
Error-correcting amplifiers
This refers to error-cancellation strategies rather than the conventional use
of negative feedback. This is a complex field, for there are at least three
different forms of error-correction, of which the best known is errorfeedforward
as exemplified by the ground-breaking Quad 405[15]. Other
versions include error feedback and other even more confusingly-named
techniques, some at least of which turn out on analysis to be conventional
NFB in disguise. For a highly ingenious treatment of the feedforward
method by Giovanni Stochino[16].
Non-switching amplifiers
Most of the distortion in Class-B is crossover distortion, and results from
gain changes in the output stage as the power devices turn on and off.
Several researchers have attempted to avoid this by ensuring that each
device is clamped to pass a certain minimum current at all times[17]. This
approach has certainly been exploited commercially, but few technical
details have been published. It is not intuitively obvious (to me, anyway)
that stopping the diminishing device current in its tracks will give less
crossover distortion.
Current-drive amplifiers
Almost all power amplifiers aspire to be voltage sources of zero output
impedance. This minimises frequency response variations caused by the
peaks and dips of the impedance curve, and gives a universal amplifier that
can drive any loudspeaker directly.
The opposite approach is an amplifier with a sufficiently high output
impedance to act as a constant-current source. This eliminates some
problems – such as rising voice-coil resistance with heat dissipation – but
introduces others such as control of the cone resonance. Current amplifiers
therefore appear to be only of use with active crossovers and velocity
feedback from the cone[18].
It is relatively simple to design an amplifier with any desired output
impedance (even a negative one) and so any compromise between voltage
and current drive is attainable. The snag is that loudspeakers are universally
designed to be driven by voltage sources, and higher amplifier impedances
demand tailoring to specific speaker types.
also I dont think the AB class can be more efficent than the modren class d amps. There might be some development in that area. If U have seen such super class a/b amps please tell us so all of us can profit from it....
the above extract has been taken from.....
Audio Power Amplifier Design Handbook
Old 29th August 2006, 11:18   #3
929RON's Avatar
That was more info than I expected, but yeah will test the amps and let you guys know over a few months how it does.
Old 29th August 2006, 11:25   #4
navin's Avatar
Thanked: 4,346 Times
LBM, thanks for the quote and credit but i fear you will scare the newbies off audio for lilfe. next time please feel free to edit the text so that it does ot scare people. :-)
Old 29th August 2006, 11:40   #5
Thanked: 295 Times
Navin Ji thats was I fearing off....but the explation is quite simple If one has a good Engineer mind.......
can u give us the model number or the make of the same so that we can see the specs atleast.....
Old 29th August 2006, 20:58   #6
Thanked: 26 Times
Does this book explain every details of an amp design... say...can a newbie with some knowledge in electronics understand it ?
regards,
ant
anToNIcHeN is offline   Reply With Quote
Old 29th August 2006, 22:40   #7
Thanked: 295 Times
regards,
ant
I dont think so it require a little more than that could post the book if allowed here....
Old 29th August 2006, 22:44   #8
jkdas's Avatar
Thanked: 1,436 Times
LBM I use a Class T amp
Old 30th August 2006, 01:07   #9
929RON's Avatar
The amp I am talking about is a Hifonics Brutus Bxi606 monoblock,
I just fitted it today in my cousin's car and boy it surprised me
People say its an Offbrand etc etc , but it sounded very very neat, As I tuned it, I could really feel the difference between that amp and some of the more commercial stuff like Sony Monos etc,
This is in a different league.
By the way the rated power on this amp is 600 RMS @ 1 Ohm
Old 31st August 2006, 00:41   #10
well if you wanna taste all them do a thing go in a good shop and get all amps install 1 by 1
1. A class
2. AB class
3. D class (wrks only with woofer)
u'll see the difference else to difficult to difficult in expert term as said by 1 of us
ankushagg is offline   Reply With Quote
Old 31st August 2006, 01:44   #11
gunbir's Avatar
Thanked: 25 Times
1. A class
2. AB class
Aggarwal ji, can you please point me to some "good shop" in Delhi which stocks Class A car audio amps. Please.
Old 31st August 2006, 09:53   #12
Thanked: 295 Times
1. A class
I would be very interested in getting one a class for my car......and address or phones..would be a great help.....
Old 31st August 2006, 10:31   #13
Thanked: 161 Times
I thought they did not make class A amps for cars because of the huge power requirement and inefficency.. that is inherent to class A amps??? I got this info from http://www.crutchfieldadvisor.com/IS...rs_faq.html#16
jinu_joseph is offline   Reply With Quote
Old 31st August 2006, 10:37   #14
Thanked: 295 Times
yes there are but very few thats why I am asking where to get them....
Old 31st August 2006, 17:38   #15
Audison VRx Series amplifiers can run class A with optional Class A Booster module. Only applicable on 2 Channel models and a pair of channels of 4 channel and 6 channel models.
TRU Technology used to make amazing class A amplifier but now they have stopped its production.
Autophile is offline   Reply With Quote
KTM 1290 Super Duke R, Super Adventure imported into India Tushar Superbikes & Imports 3 26th June 2015 11:24
Full range class D amps? determinus In-Car Entertainment 11 8th December 2007 22:49
The Quick and Dirty on Car Head units & Amps navin In-Car Entertainment 51 21st March 2007 09:15
Car AMPS and Indian market kutlee In-Car Entertainment 2 6th July 2005 14:05
3 amps, 4 tweters, 4 sub woofers, 2 12''s??? N.J In-Car Entertainment 19 27th April 2005 15:03
