Old 3rd September 2006, 22:24   #16
But HUs can put out just a few (maybe 10W) or less of RMS power. If one pumps up the volume it will lead to distortion and clipping. Having an amp will feed the speakers with ample power and the signal to noise ratio will go up. The result: cleaner, better sound. Very simple.
Vivekphadnis is offline   Reply With Quote
Old 3rd September 2006, 22:34   #17
prince85's Avatar
Thanked: 117 Times
Originally Posted by ST7677
I do not think this is true!
As long as HU is able to provide power in the range of Power range of components, it should work fine. Though it,s capabilities may not be completely utilized.
I am not an expert in this but i feel there aren't any head-units in the market(that i have heard of) which give out enough juice(RMS) to do justice to reasonable speakers(leave alone components).
The normal Pioneer/Alpine/Sony HU's give out no more than 10-12W RMS(continous power) which is no match for components like say for instance a JBL GTO 607 component set(which is the topic of discussion in this thread) need atleast 50W-RMS(continous power) for it to sound how it is supposed to sound.
So yup, i believe components perform their best when mated with good quality amps like say JBL, Alpine etc .
Gurus like Navinji, Sam, Gunbir etc, plz correct me if i am wrong
Cheers+
prince85 is offline   Reply With Quote
Old 3rd September 2006, 22:40   #18
Prince85, you thought right. As I said in my post, HUs cant give that much electrical power for clean sound.
Old 3rd September 2006, 23:46   #19
ST7677's Avatar
Thanked: 45 Times
Not really!
There are many HUs today in market which give 40-50W RMS per channel at <1% TDH.
It depends on how much min RMS power is required by the components and what is their sensitivity!
I.e. How much you need to turn up the volume. Distortion should be there only in last 10-15%.
ST7677 is offline   Reply With Quote
Old 4th September 2006, 00:13   #20
prince85's Avatar
Thanked: 117 Times
Not really!
Ok then! Could you name a few Head Units that you know of which pump out 40-50W RMS per channel??
Old 4th September 2006, 00:24   #21
Thanked: 294 Times
Not really!
sorry man no single hu can make 40-50 watts rms continous .......it is not practically possible......in that much space....till any new technolgy comes in....
Old 4th September 2006, 00:27   #22
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by s0uljah
JBL 937 costs approx. 3.8k.
Nope, it's 4990/-
Yes, i would say that of all good speakers in fact. They will perform their best when connected to a good amplifier.
But at lower volumes, often i find that HU's tend to sound better than cheap amplifiers like sony 222 and 502. So i think it is better not to have an amp, than a cheap amp.
Old 4th September 2006, 00:35   #23
Thanked: 13 Times
Originally Posted by Sam Kapasi
Nope, it's 4990/-
Sam, sorry about that, typo on my part and I couldnt correct in time
Old 4th September 2006, 11:00   #24
navin's Avatar
Thanked: 4,282 Times
Things are changing though....
Look what my first google showed...
http://www.teamrocs.com/technical/pages/headpower.htm
http://www.carstereo.com/help/headunit.cfm
http://www.crutchfieldadvisor.com/IS...ew.html?page=4
http://www.findarticles.com/p/articl..._7/ai_n8682480
"Panasonic released the CQ-C9800U, which was the first 70W x 4-channel car audio head unit, setting a new power record"
Old 4th September 2006, 12:39   #25
Bass&Trouble's Avatar
Thanked: 71 Times
Yeah, I saw that and others from the new line-up at the Panasonic launch in Mumbai. Nice range. Sure to give Pioneer a run for the money. Only the top of the line guy uses the PWM stage to put out 70x4 peak.
Old 4th September 2006, 14:10   #26
ST7677's Avatar
Thanked: 45 Times
I was checking with Honda on installing an external amp for the component speakers, they reveted back that I need not do so, as the integrated 2 din Alpine HU is latest in it,s class which pumps out 50W RMS power per channel.
Ofcourse I have asked them for detailed specs, but the system does sound pretty good!
Old 4th September 2006, 16:52   #27
navin's Avatar
...as the integrated 2 din Alpine HU is latest in it,s class which pumps out 50W RMS power per channel.!
Now that I gotta see.
Old 4th September 2006, 17:13   #28
esteem_lover's Avatar
Thanked: 451 Times
@B&T, how much does a HU like that cost ?
@Sam, is the sony 554ZR also considered a "Cheap" amp that it need not exist at all ?
please give your honest opinion guys.
Old 4th September 2006, 19:04   #29
Thanked: 71 Times
I roughly remember the Panasonic head unit priced at about 19990/-. It's the top of the line. I think it's a good deal. I listened to it on a demo board at the event, with chatter and glasses clinking, hence it would have been impossible to tell the SQ aspect, but it was definitely louder than the other units. But my guess is that anyone using it for SQ will idle the internal amp anyway. So, not much point spending that much JUST for the internal amp. I am hoping the overall sound quality is good too.
The cheaper units are also good looking and comfortable to use. I found them better than comparable Sony units from all perspectives. I think the entry level mp3 unit is for 6990. Reliability however, only time can tell.
One unit that really caught my eye was the 2-din MP3 + cassette HU. Absolutely gorgeous. It's actually a 2-box unit at the back that looks united because of the full-sized front faceplate. Will take out the Pioneer 5000's underpants anyday.
Old 5th September 2006, 08:41   #30
ST7677's Avatar
Thanked: 45 Times
Actually after reading thru Navin's links even I am not sure!
I will get back when Honda sends specs in writting.
The HU actually gets hot while playing, if that's any sign (or is it a malfunction?)
Urgent Help Reqd: Need a Convertible in Delhi for half a day manveet Shifting gears 11 12th December 2007 18:02
Planning a Bangalore-Kodaikanna trip help reqd ?? jango Travelogues 22 26th November 2007 13:44
Palghat - Coorg route query, urgent help reqd! Steeroid Route / Travel Queries 1 27th August 2007 10:16
Buying Help Reqd.Current Monthly Cost Rs 2500/-.Choices Fusion (petrol/diesel),SX4etc subscrive Sedans 7 12th June 2007 22:14
suggestions/help reqd about car audio siliconboy In-Car Entertainment 9 26th June 2005 18:08
