Old 25th November 2006, 09:52   #211
Thanked: 11 Times
Originally Posted by speedzak View Post
The connection leaves me a bit confused here!
Can you please explain how the crossover and speakers are connected??
Zak,
From Amp the pair of wire comes to Input Midbass then from one to mid bass and one to tweeter from crossover.
I cant clarify more, B&T can give more explanation.
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 25th November 2006, 12:28   #212
hydrashok's Avatar
Originally Posted by Mugen_Power View Post
Zak,
Cheers,
Mugen_Power.
I guess the crossover lets you amp the tweeters and the mid-bass separately if you want to, I guess.
Nice observation, Zak. I hadn't looked closely at all. I saw the empty tweeter input only after I'd seen your post.
Old 25th November 2006, 12:32   #213
Bass&Trouble's Avatar
Thanked: 71 Times
That is right. The crossover has bi-amp inputs. They can be bypassed by using jumpers internally. In which case, one can use either of the 2 input terminals.
Old 25th November 2006, 13:12   #214
Thanked: 17 Times
Hmmm...
That's a nice feature. Solved my mistery.
Thanx for pouring in, B&T.
Old 25th November 2006, 18:14   #215
Thanked: 11 Times
Solved my mistery.
But Mine is yet not solved..
Post 202.
Cheers,
Mugen_Power.
Old 25th November 2006, 19:21   #216
Thanked: 17 Times
Aaaah!!! You've got a monoblock amp. If you had 2 amps or a 4 channel amp powering the subwoofers, then this stereo mode would be of your help.
Now your subs are working in MONO or dual MONO. That's one single channel going to both the subs. With stereo mode, you can have 2 different channels going to each subs. Like other speakers, Left and right. Only a very distinguished audiophile maybe able to make out the quality difference in a setup like that. Not for my kind. So, have'nt tried out but heard one setup and I did'nt find any difference. It also matters the type of music played.
More details about this can be found here (2 Subs - Dual Mono or Stereo - "Kb ka dB").
And your other query?? B&T is the person best possible to answer that!
Old 25th November 2006, 20:16   #217
Thanked: 71 Times
Correct. Mono amplifier cannot drive subs in stereo even if it wants to. Not that I wanted it to. As clear from my contributions in previous discussions on stereo vs mono subs, I am a firm proponent of mono subwoofer configurations.
1 - Subs running on which Ohms ?
Each sub is 4 ohms. Wired in parallel to pose 2 ohms to the D510 amp. D510 puts out maximum output at that load, and isn't stable below that.
Old 25th November 2006, 20:53   #218
Thanked: 11 Times
Thanks for the Explanations..
In Innova with Comps i feel that Eminem is singing on dash board, i had a Co-axials in OHC and Qualis at that time i can feel that Eminem is singing outside of the car.
But i really liked the Comps Way, Before this setup i was SPL guy but after this setup SQ matters much.
Thanks All Gurus for the Help.
C Ya,
Mugen_Power.
Old 26th November 2006, 17:29   #219
Thanked: 71 Times
Welcome to 'Imaging'!
Maybe you should feed in the speaker distances and get time alignment going too.
Old 26th November 2006, 20:14   #220
Thanked: 17 Times
If you've turned to SQ, then soon Eminem will be again singing outside your car and Diana Krall will be inside.
Old 26th November 2006, 20:28   #221
Thanked: 11 Times
How can i do that in 8850 ? i have seen some options but dont know much so i dont have tried yet.
Zak,
Any torrents links for Diana Krall's albums ? Or album names ?
Cheers,
Mugen_Power.
Old 26th November 2006, 20:45   #222
rsjaurr's Avatar
Thanked: 27 Times
Mugen,go throguh the manual of ur HU.There u will find TA option and u will have to measure distance from ur listening position[ur ears] to all door speakers and sub and then feed it in the HU for each spk.
Not a difficult if u go through HU's manual.
Experts like Navin,JB,Sam,B&T/Gunbir will do it differently but we should leave that to them
rsjaurr is offline   Reply With Quote
Old 27th November 2006, 13:49   #223
ankur's Avatar
@s0uljah, Wurth 3x1.5 Feet Sheet For 1400.
Tweeter With Cover.
Cheers,
Mugen_Power.
Great thread and really good pictures. I am currently in the planning part of my Innova ICE install and your thread was very interesting for me. Your budget is much higher than mine (i wasted my main budget on a PC setup) so i wont be able to take too many pointers from here. What interested me was the picture above. Is that grill cover standard in a V Innova or is that custom made ? I have a G series and in mine the plastic cover is plain, no grill for a tweeter.
cheers.
ankur is offline   Reply With Quote
Old 27th November 2006, 19:14   #224
Thanked: 17 Times
cheers.
It's the stock grill which comes with V variant of Innovas. You maybe able to get a set from the Toyota dealer.
Old 27th November 2006, 20:55   #225
ankur's Avatar
Thanks. Thats exactly what i will do , makes life so much easier. I wish there were such grills for the rear too.
cheers.
Toyota Innova vs Toyota Fortuner - For a Family MAS SUVs, MUVs & 4x4s 121 24th November 2017 20:26
Replacing our 2 lakh km Innova - Toyota Innova Crysta vs Ford Endeavour icyspikey SUVs, MUVs & 4x4s 31 16th May 2017 18:48
Toyota Innova or Toyota Altis Diesel h.k What Car? 9 4th October 2010 10:48
Audio setup for Toyota Innova ? diehard_chandru In-Car Entertainment 15 12th August 2006 13:53
