Old 15th December 2016, 19:55   #166
antardaksh's Avatar
Thanked: 210 Times
Default Re: Review: RCD 330G. VW's 2016 Head-Unit for the Polo, Vento & Ameo
Originally Posted by Aston Singh View Post
Is there some funda of not using more that 1-2 folders or something like that?
Hi Aston Singh,
I am using 32GB SD card and its working fine. I haven't tried 3 level sub folders. What is capacity of SD Card that you are using?
Regards.
antardaksh is offline   Reply With Quote
Old 15th December 2016, 22:02   #167
maddyguage's Avatar
Thanked: 177 Times
Finally got my 6.5" RCD 330 plus. Screen is huge and touch is better than my previous 5" RCD 330 G. UI looks rich almost identical to bigger brother Jetta's MIB.
I got a sweet deal from seller and luckily it's cheaper than RCD 330 G.
I got it for $100 with free shipping by aramex (express shipping). I got my package within 5 days.
Definitely go for it. Nice product and feels great to use.
Review: RCD 330G. VW's 2016 Head-Unit for the Polo, Vento & Ameo-imageuploadedbyteambhp1481819377.391498.jpg
Review: RCD 330G. VW's 2016 Head-Unit for the Polo, Vento & Ameo-imageuploadedbyteambhp1481819410.511411.jpg
Review: RCD 330G. VW's 2016 Head-Unit for the Polo, Vento & Ameo-imageuploadedbyteambhp1481819446.497691.jpg
maddyguage is offline   (4) Thanks Reply With Quote
Old 16th December 2016, 14:18   #168
Thanked: 121 Times
Create a Folder named MP3 and move all your songs folder into that folder. Should do the trick.
GJ01 is offline   Reply With Quote
Old 16th December 2016, 18:20   #169
Thanked: 40 Times
Looks Great. Where did you get it? Please can you PM me the link to buy..
Can we install this on 2013 Vento Highline Models which came with RCD 320
CRV2010 is offline   (1) Thanks Reply With Quote
Old 16th December 2016, 18:27   #170
maddyguage's Avatar
Thanked: 177 Times
Yes you can install it in 2013 model. I've already PM'd you the link so check it. If your car comes with OPS module than you will love it. Graphics are top notch.
maddyguage is offline   (1) Thanks Reply With Quote
Old 16th December 2016, 20:55   #171
Thanked: 40 Times
I have 2013 Vento Highline which has RCD 320. How to figure out if my car has OPS Module?
I get only beep sound when I engage reverse gear.
If my car doesn't have OPS module, then is it just a plug n play to install the OPS module ?
CRV2010 is offline   Reply With Quote
Old 16th December 2016, 21:27   #172
maddyguage's Avatar
Thanked: 177 Times
Don't get into OPS module if you don't have. You can install camera instead. And yes you will need ISO to Quadlock connector. Because both player have different connectors. Ask seller for it.
Old 17th December 2016, 20:27   #173
dsinz's Avatar
I got rear camera installed on my 2016 Polo GT TSI. It works flawlessly with RCD 330G unit which came as part of the car. I got it installed from Vagtune Bengaluru branch today. Took 45 mins to complete the setup. Sugesh and Ashraf of Vagtune was there in Bengaluru branch today.
Totally satisfied with the installation. I was happy with RCD 330G unit. I didnt want to change the head unit for the camera. They were able to install the camera with Park pilot on RCD 330G head unit.
dsinz is offline   (1) Thanks Reply With Quote
Old 18th December 2016, 08:33   #174
antardaksh's Avatar
Thanked: 210 Times
Hi dsinz,
Could you please share more details about the part numbers and cost involved in this. Did you get 8K ops or just enabled rear OPS with OEM sensors?
Regards.
Hi maddyguage,
I wanted to change for the same reason (larger screen size) but have put this plan on hold since I did not get buyer for existing unit (RCD 330G).
Do you see noticeable difference in screen resolution and could you please post some pictures of camera view on this unit.
Regards.
Last edited by Gannu_1 : 18th December 2016 at 11:15. Reason: Back to back posts merged. Please use the multi-quote option (QUOTE+) while quoting and responding to multiple posts together. Thanks!
Old 18th December 2016, 12:48   #175
dsinz's Avatar
Originally Posted by antardaksh View Post
Hi dsinz,
Hey antardaksh... This the one I got installed. Camera + Ops 4K + Canbus
http://www.vagtune.in/secure/car-typ...fit-kit-detail
I don't know the exact part numbers. I could see the Ops 4K had Made in Germany tag.
dsinz is offline   (2) Thanks Reply With Quote
Old 19th December 2016, 10:00   #176
Thanked: 24 Times
Hi dsinz, thanks for the URL on Vagtune. How much did you spend overall for the camera and its installation? Who did the installation for you and does it not void any kind of warranty?
meetzap is offline   Reply With Quote
Old 20th December 2016, 11:11   #177
maddyguage's Avatar
Thanked: 177 Times
Hi dsinz,
Regards.
Hey antardaksh,
That's 4K OPS module made by Valeo I suppose. Can get it here for around INR 2500. Part number is 6R0 919 475. It works with rear OEM sensors.
OEM 4K OPS - http://www.aliexpress.com/item/32231...231899529.html
maddyguage is offline   Reply With Quote
Old 21st December 2016, 00:12   #178
Thanked: 21 Times
Does it show dynamic grid lines or static ?
For the Vento, where is the camera installed ? Is it along with the boot lid soft touch button?
Hey antardaksh,
Will installing the 8K module work with 4 rear sensors only ? I plan to install the front sensors later on. Also, is the canbus harness different for 4k and 8k modules ?
Thanks.
Mitz is offline   Reply With Quote
Old 22nd December 2016, 01:31   #179
antardaksh's Avatar
Thanked: 210 Times
Thanks.
Hi Mitz,
Camera supported by RCD330G will display static grid lines. I have installed RGB camera in the soft touch button. Its in the same place as Ameo rear view camera.
http://www.team-bhp.com/forum/car-en...ml#post4093930 (Review: RCD 330G. VW's 2016 Head-Unit for the Polo, Vento & Ameo)
You will need 8 sensors and 8K ops module to display all sensors. All you need to do it connect sensors to control module and then connect control module to CANBUS powertrain.
Enabling OPS for 4 rear sensors is simple, all you need to do is to replace existing control module with 4K ops module and connect this to CANBUS and enable this from VCDS.
Installing 8K is complicated since it involves drilling hole in front bumper, routing additional wires from engine compartment to the control module in boot and installation of PDC switch.
Both 4k and 8k modules are available on Aliexpress.
You will find details about OPS in following thread
http://www.team-bhp.com/forum/long-t...ml#post4067976
Regards.
Old 22nd December 2016, 09:00   #180
ventoman's Avatar
Thanked: 165 Times
Has anyone been able to modify/upgrade ops module on Polo/Vento so far? I've not been able to locate existing unit in my Vento. Also missing some detailed DIY instructions.
ventoman is offline   Reply With Quote
VW Polo DIY: Delphi RCD 510 headunit + 9W7 Bluetooth unit installation Gannu_1 In-Car Entertainment 60 7th August 2017 19:41
Problems after DIY install - RCD/RCN 320 on Polo/Vento callme9009 In-Car Entertainment 41 21st February 2017 16:58
Volkswagen Ameo @ Auto Expo 2016. EDIT: Starts at Rs. 5.14 lakhs! Rehaan The Indian Car Scene 271 14th July 2016 12:22
DIY: RCD 510 head-unit upgrade for VW Vento and Polo moralfibre In-Car Entertainment 96 23rd April 2016 11:36
VW's Polo-based compact sedan, Ameo unveiled! volkman10 The Indian Car Scene 243 3rd February 2016 20:06
