Old 15th August 2016, 18:37   #91
maddyguage's Avatar
Thanked: 177 Times
Originally Posted by smnrock View Post
Thanks, the seller was telling it won't fit skoda rapid. Then I replied saying, the current model is rcd 320 only and sent link to our official review page of TDI DSG where it shows HU and dashboard pictures. Again he replied saying, "we checked it will fit only in Octavia and not in rapid" :(
If it's RCD 320 then it should be fine. Can you share pic of your HU and dashboard. It'll be helpful if you can open HU and click a pic of connectors at the back.
As far as I know Rapid has similar features and similar wiring diagrams. But my HU comes with red backlit and Skoda has green lights in interior everywhere if I'm not wrong.
maddyguage is offline   Reply With Quote
Old 15th August 2016, 18:44   #92
Thanked: 58 Times
Default Re: Review: RCD 330G. VW's 2016 Head-Unit for the Polo, Vento & Ameo
Mine is same as what is shown/reviewed here,
http://www.team-bhp.com/forum/offici...ml#post3557085 (2014 Skoda Rapid 1.5L DSG : Official Review)
Will PM you for further details...
smnrock is offline   Reply With Quote
Old 15th August 2016, 19:24   #93
reignofchaos's Avatar
Thanked: 1,184 Times
Originally Posted by nova9 View Post
No matter that I do i cant see the phones screen mirrored on the head unit.
When you say "pressed the home button" which button are you referring to?
Have you tried this with a samsung s5 or s6 and made it work?
A home button appears on the screen of the head unit.
Don't have a newish Samsung device to test it with. Once I tried an s5 that belonged to a friend and it did not pair via mirror link
reignofchaos is offline   (1) Thanks Reply With Quote
Old 16th August 2016, 03:11   #94
Thanked: 58 Times
Could you please take a video or a couple of pictures of the screen that you get once you start mirrorlink and point out the home button you are referring to. Im not sure if the interface that shows up on the head unit is created by the firmware of the head unit or is created by the phone.
I dont get any icon that seems like a home icon. I also get 2 icons which do nothing when pressed. One looks like a trash can and the other like a screen with icons. Ill click some pick and post tomorrow and i guess then we can compare what screens we get from mirrorlink.
Thanks!
nova9 is offline   Reply With Quote
Old 16th August 2016, 09:16   #95
Thanks!
If you check the images I uploaded, you'll see a home button on the screen in one of them
http://www.team-bhp.com/forum/car-en...ml#post3994961 (Review: RCD 330G. VW's 2016 Head-Unit for the Polo, Vento & Ameo)
I think button is created by the phone - not by the HU.
Old 16th August 2016, 11:46   #96
maddyguage's Avatar
Thanked: 177 Times
Alright I checked that thread and it seems that Rapid has same interiors as well as same RCD-320. But steering controls look little different. I guess may be that's the reason seller said it won't fit. I think you need someone from Skoda stable to check out this matter.
But I still feel that it'll work fine in your Rapid. But ask our gurus before placing an order.
Old 25th August 2016, 18:50   #97
Thanked: 58 Times
got it delivered yesterday. But as the seller mentioned, its not working. Steering controls are not working and HU does not detect the ignition ON as well. Due to this, when i tried enabling bluetooth, it gives an error like "Switch ON ignition to enable bluetooth"
Any help appreciated.
Old 25th August 2016, 20:22   #98
maddyguage's Avatar
Thanked: 177 Times
Don't panic. Nothing is wrong. I guess you missed connecting those 2 wires that are for CAN-BUS. As I mentioned ago, you have to connect CAN-BUS wires from new quadlock connector to iso connector. You will see two empty sockets iso connector.
Go to any local car shop and ask for spare female pins. And connect those pins with yellow wire that came with new quadlock connector. Identify two empty pins in ISO connector. I hope I'm not confusing you.
maddyguage is offline   (1) Thanks Reply With Quote
Old 25th August 2016, 20:29   #99
Thanked: 58 Times
Actually i went to local professional installer only and we did connect the CAN-BUS as described in Gannu's DIY thread. But its not working at all. I also bought reverse camera as well :(, but its not fitting for rapid.
Old 25th August 2016, 21:05   #100
maddyguage's Avatar
Thanked: 177 Times
Alright I guess you should check it once again. See if it's done correctly, it's the only culprit. Try to connect it again using new pins. You can swap pin positions in iso connector. May be this will help.
Old 25th August 2016, 22:24   #101
Thanked: 58 Times
Yeah, we did test it by swapping pin positions and several attempts as well. Also tried with different quadlock connector as well(seller sent two). Nothing was working.
I feel this HU firmware is restricted to VW only, but not sure.
Old 26th August 2016, 09:35   #102
Thanked: 58 Times
Google search shows, some Russian guys installed this in rapid mpi 1.6 automatic. So I don't see why this is not working in my car. I started to feel, it could be the issue in this particular unit(lemon!)? Is there any way to confirm the canbus connections are fine in this HU?
Any polo/vento owners in Hosur/Bangalore can help me test this by installing in their car?
Old 26th August 2016, 13:49   #103
maddyguage's Avatar
Thanked: 177 Times
Alright I'm not sure but according to me your HU is working fine. The problem is with CAN-BUS cables only. I'm saying this because when I bought RCD-330G I sold my old player RCD-320 to a friend. He installed it in his 2011 Vento. Whenever he tries to connect Bluetooth it shows "KEY OFF" error which is in fact a known error due to CAN-BUS. Older models of Vento did not come with CAN-BUS so may be that's the reason.
Try to consult any Skoda expert. I feel your BCM doesn't support this player.
Old 31st August 2016, 00:19   #104
diganta.gogoi's Avatar
Hi everyone,
I have a few questions around this system:
1. Have anyone changed the stock speakers?
2. What could be my choices if I can and what expenses am I looking at?
3. Can I fit a sub?
Thanks for your inputs.
diganta.gogoi is offline   Reply With Quote
Old 31st August 2016, 21:07   #105
maddyguage's Avatar
Thanked: 177 Times
Originally Posted by diganta.gogoi View Post
Hi everyone,
3. Can I fit a sub?
I don't know if anyone has changed stock speakers but you can definitely add a sub. I'm running on stock speakers and I've added JBL 1100 W subwoofer along with JBL 2 channel GT series amplifier.
Sound quality is pretty decent and I like mild woofer punch just like you get in a premium german cars with stock setup.
You can go for nice component speakers if you want to upgrade. It'll cost you around 10 K for a good setup. Add another 15 K for subwoofer and amplifier. But honestly stock players don't do justice to any high end speakers. That's the reason I didn't go for speaker upgrade.
VW Polo DIY: Delphi RCD 510 headunit + 9W7 Bluetooth unit installation Gannu_1 In-Car Entertainment 60 7th August 2017 19:41
Problems after DIY install - RCD/RCN 320 on Polo/Vento callme9009 In-Car Entertainment 41 21st February 2017 16:58
Volkswagen Ameo @ Auto Expo 2016. EDIT: Starts at Rs. 5.14 lakhs! Rehaan The Indian Car Scene 271 14th July 2016 12:22
DIY: RCD 510 head-unit upgrade for VW Vento and Polo moralfibre In-Car Entertainment 96 23rd April 2016 11:36
VW's Polo-based compact sedan, Ameo unveiled! volkman10 The Indian Car Scene 243 3rd February 2016 20:06
