Old 28th March 2016, 17:11   #16
Default Re: Maruti releases map update for its Smartplay Infotainment system
Originally Posted by abhisheksircar View Post
Didn't work. The same problem. VIN Invalid. I am sure I am putting the correct VIN.
Hello abhisheksircar,
I just tried it again now and it worked just fine. Are you sure you are putting the right VIN number. I have edited out my VIN and Serial Number from the image for security reasons. But it shows that the download works just fine.
Maruti releases map update for its Smartplay Infotainment system-map-update.jpg
arnath is offline   Reply With Quote
Old 28th March 2016, 17:13   #17
manojgautham's Avatar
Thanked: 11 Times
Originally Posted by arnath View Post
Hello Guys,
You will definitely be able to download the Map update using the following link:
http://suzuki.navigation.com/home/en...iAPAC/USD#HERE
Even I am facing the problem, says VIN is incorrect, I'm sure I am filling the correct VIN. There is a link below to register VIN on Maruti Suzuki Play Website. After clicking on that I don't see any place to register VIN. Should the VIN be registered somewhere first?
Maruti releases map update for its Smartplay Infotainment system-screen-shot-20160328-5.09.23-pm.png
manojgautham is offline   Reply With Quote
Old 28th March 2016, 21:52   #18
SDK
SDK's Avatar
Thanked: 15 Times
Even I am getting an Invalid VIN error.
Looks like only the new VINs (ones with 10th and 11th characters for manufacturing date) are accepted.
SDK is offline   Reply With Quote
Old 29th March 2016, 11:32   #19
Thanked: 11 Times
The tenth and eleventh characters in my car's VIN are "0"
Old 29th March 2016, 11:35   #20
Thanked: 56 Times
Even mine are 0 but i downloaded the maps
fuzail is offline   Reply With Quote
Old 29th March 2016, 11:39   #21
Thanked: 56 Times
If you have no problem in sharing your VIN on pm, i can try at my end.
Old 29th March 2016, 11:46   #22
Thanked: 11 Times
Have shared my car's VIN through PM.
Old 29th March 2016, 11:58   #23
Thanked: 56 Times
This is the only email. contact@maruti.co.in
Old 29th March 2016, 19:01   #24
rednikhil's Avatar
Thanked: 146 Times
Thumbs down Re: Maruti releases map update for its Smartplay Infotainment system
It recognized the VIN once, however the link failed. When I try again, it reports an invalid VIN; strange!
rednikhil is offline   Reply With Quote
Old 29th March 2016, 19:36   #25
rednikhil's Avatar
Thanked: 146 Times
Thumbs up Re: Maruti releases map update for its Smartplay Infotainment system
This time it worked on the second link! Downloading now.
Old 30th March 2016, 11:14   #26
Thanked: 11 Times
Spoke to MASS regarding the missing SD card. They say that a replacement can be ordered from the spares section. They also say that the software update can be done on the same memory card and a new card (4GB) is not required. They say they will do the update once the memory card is here. It would take about 10 days for the card and it cost around 3K. Will wait for the card and then update.
Old 30th March 2016, 11:21   #27
Thanked: 56 Times
Why are you after the MASS. they are charging you rs 3000 for a SD card that cost around 300 rs. Also most or all of the MASS are not well versed with this type of service ,which according to me is electronic service. how can you put data more than 2GB on a 2GB SD Card.
Just Buy a 4GB SD card ,format it as MS DOS FAT32 and copy the files downloaded from MAPCARE and you are done. Happy Navigating.
PS. I have done the same thing as mentioned above.
fuzail is offline   (2) Thanks Reply With Quote
Old 30th March 2016, 13:25   #28
Thanked: 11 Times
In my case I haven't been able to download with my VIN number. Is there an alternate way for me to download?
Old 30th March 2016, 14:16   #29
sudeepg's Avatar
Thanked: 1,267 Times
Dont worry. Buy a 4gb SD card . Format it as MS-DOS FAT32. Download the files as per the link above. extract and copy the 2 files Cryptnav and tollfree to the SD card. you are done
You can even use cards formatted with NTFS file system. The update is 3.73 GB in size. I have put the update on a 32 GB SD Card formatted as NTFS and also loaded a lot of Media content onto it. I can now use it for maps as well as media.
Last edited by sudeepg : 30th March 2016 at 14:33. Reason: adding map update size.
sudeepg is offline   (4) Thanks Reply With Quote
Old 30th March 2016, 14:19   #30
Thanked: 122 Times
Originally Posted by sudeepg View Post
You can even use cards formatted with NTFS file system. I have put the update on a 32 GB SD Card formatted as NTFS and also loaded by a lot of Media content onto it. I can now use it for maps as well as media.
Thanks Sudeep. That's really helpful. I'm also having a 32GB card, used to interchange with maps card every time, now this info is a fix!
lovetorque is offline   (1) Thanks Reply With Quote
Datsun releases sketch of its Maruti Alto Rival volkman10 The Indian Car Scene 15 23rd May 2015 14:14
Rumour: More Maruti cars to get SmartPlay infotainment system Aditya The Indian Car Scene 2 14th April 2015 15:18
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
