Old 11th October 2006, 01:24   #16
Thanked: 11 Times
Originally Posted by rsjaurr
He is our residant SPL expert here..
@ rsjaurr,
Wow..
How Do You Know ??
@ Technocrat,
You Will Need DB Meter To Measure Level.
If Possible Post Some Pics.
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 11th October 2006, 01:46   #17
Thanked: 294 Times
ask LBM to courier his SPL meter for few days.He is our residant SPL expert here..
At last I am expert in something..........
Thank you Rsj....
Old 11th October 2006, 02:04   #18
amit_sound's Avatar
ha ha ha, jus the kind of thread i was gonna start today...
I bought a new Nokia 3250, which has a application called "SounMeter" in it. Althought the application claims that it not ment for professional use because slight differences will occur if tested using a actual device..
As far as L_B_M's post no 6 of this thread goes. I tried and the results given by the application were very very similar.
Next, i took my car to a quite place to do a db test. I started playing the Glassy track by HardKaur.. I pupmed up the volume and even before the bass could start, the application started showing the reading of 114 db. The application does not read dbs above 114. So the it simple flashed ">114"..
Now i am guessing how much dbs does my system produce?
amit_sound is offline   Reply With Quote
Old 11th October 2006, 02:13   #19
Thanked: 294 Times
amit u have two 15 inch and power buy a good amp in your car they must be above 130 db easily.....
Old 11th October 2006, 02:34   #20
amit_sound's Avatar
hmm...i read that as powered by ...right LBM ??? well yes even i thought so it should be over 130 db... waiting to chk it officially though...thnx
Old 11th October 2006, 10:49   #21
Technocrat's Avatar
Thanked: 2,589 Times
Originally Posted by low_bass_makker
from where did u made the ported box....which ports are used....any pics would be help full.....
It was a readymade Box with the installer, It is slightly inclined at I suppose at around 30-45 deg something like this, just that its placed horizontal than vertical(i.e. the sub is facing up & towards front) & the ports(2 ports) are not like those in pic but are next to the Sub but on the same plain slightly lower near the corners, each of around ~2.5-2 inch dia
Will try to take picture from my cell at lunch time & post
Old 11th October 2006, 11:00   #22
Thanked: 294 Times
take the pic of the box when in the boot.....
Old 11th October 2006, 14:57   #23
amit_sound's Avatar
Yup, i got two GT4-15 ,15" and a JBL 601.1 mono.. I guess bass should be between 130 -140 dbs
Old 11th October 2006, 15:12   #24
navin's Avatar
Thanked: 4,282 Times
Please wear ear plugs (they reduce SPL by as much as 25-30db) when testing your system.
Old 12th October 2006, 10:24   #25
Technocrat's Avatar
Default Here are the Pics
Hi LBM
Here are the pics(clickable thumbnails) of my sub:
The Sub in Ported Box
Sub Below Tray with Speakers
Connector
Hope thuis helps, took the pics from my Nokia 6600 hence the quality
Old 12th October 2006, 10:39   #26
Thanked: 294 Times
man this is no ported box but it looks like a ported box ...I would say close the holes but putting some thing on the top of it....then it will sound better....one more thing try facing the sub the boot door it will also help a lot....this is for the sounding...the max spl you must be achiving would be nearly 120-125 db....this is a estimate figure not a correct one....
Old 12th October 2006, 10:53   #27
navin's Avatar
dont close the holes, stuff an old cotton sock in each hole. make it aperiodic.
Old 12th October 2006, 10:57   #28
Thanked: 294 Times
Ya agreed this can be done but try both the option keep which sounds you most....
Old 12th October 2006, 11:05   #29
Technocrat's Avatar
Thanks guys
Btw why do you say its not ported? I mean how do you define ports & why do these holes dont qualify as one ?
Hmm will change the facing and also put my old socks to use
Btw normally i listen to 50-60% of max volume level(The max is 62 & when I am blasting its at 35 or in some case 40, normallly between 25-30) So I belive that should approx be within 90db what say ?
Old 12th October 2006, 13:53   #30
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by Technocrat
Thanks guys
Let's start with, a 12" sub needs a port diameter of atleast 3-4" to atleast function as a port. Otherwise, the port contribution is too little. Secondly, it seems very unlikely, that the installer would have designed the box and the ports based on the sub's specs. Looks like a one-size-fits-all kinda box. And I don't know for sure, but does Sony even provide the T-S parameters with their basic subs? Maybe they do, just curious.
An 8 wheel electric car that puts Enzo to shame. v12 The International Automotive Scene 13 8th February 2010 22:35
GM puts temporary brakes on Vette production amit The International Automotive Scene 8 18th September 2008 02:23
Tiff Needell puts his real world skills against David Baker (UK GT4 champ)!!! Shan2nu Shifting gears 5 16th September 2008 21:15
Indian Auto Industry puts Expats in Drivers Seat Dolphin The Indian Car Scene 2 6th May 2008 16:14
