Closed Thread
Old 12th October 2006, 15:54   #1
hey guys,
so I finally got my car audio done for the time bring(Blaupunkt Monterry HU+ Blaupunkt 5.25" in the dash +JBL gto in the rear).The sound quality is really good in CD/MP3 but when I switch tp Radio some FM stations give a lot of disturbance.I gather that this happens due to the frequency of the station.I live in Bangalore.FM 91.0 comes really clean but others have a little jittery sound in between coverage.I am said that the Indigo's inernal antenna is not hat receptive.Is that true?
How do I fine tune the antenna settings.?I do not wanna put a whole in my car for an external antenna.
raptor3624 is offline
Old 12th October 2006, 16:46   #2
Thanked: 54 Times
Default fm antenna
yup ,even my indica had an antenna problem . I use an aluminium rod ,the ones that TV antennas used to have . i have the rod concealed under the carpet near the gear shifter . My Fm works good . may be you could try the same
greatmana2000 is offline
Old 12th October 2006, 16:57   #3
kph
kph's Avatar
I have indica using in Bangalore. I'm using a sony explod in it which doesn’t have any problem in reception of any of the channels. Indica uses the same type of internal antennas Indigos have. I changed it with a Sony branded one and didn’t find much improvement in reception (I mean reception when in outskirts of bangalore) Anyway there shouldn’t be a problem with the clarity.
Also I feel radio mirchi and radio one has got performance. That definitely depends on the area (near/far from the transmission antenna).
Anyway you can check if your antenna connection is properly given. Also check if the separate power connection for the antenna is given.
kph is offline
Old 13th October 2006, 06:53   #4
goldsun's Avatar
Post
My friend had Indica and now Indigo. He said that the radio reception has not been so perfect in both the cars. I feel this could be due to some inferior built-in antenna that is provided in both the cars. It is suggested to go for external antenna.
goldsun is offline
Old 13th October 2006, 07:16   #5
condor's Avatar
Thanked: 4,897 Times
Same for me - had the Indica, have the Indigo. Always used the internal antenna, and never had any reception problems. Pls have the connections checked up.
condor is offline
Old 13th October 2006, 11:55   #6
jkdas's Avatar
Thanked: 1,436 Times
Get the connection checked up. Is it a petrol one? Blau HU are known ( based on my knowledge frm advts and sort) for good radio reception.
jkdas is offline
Old 13th October 2006, 15:44   #7
how does it matter whether the indigo is a petrol or diesel one?neways..if it does..then I have a diesel(facelifted) Indigo.
Old 13th October 2006, 16:03   #8
Sam Kapasi's Avatar
Thanked: 1,473 Times
An internal antenna is not as powerful as an external antenna. That's pretty much the extent of your problem. Try replacing the internal antenna, or make a whole and fit an external antenna. Blaupunkt radios are known for good reception, as are all german HUs.
Sam Kapasi is offline
Old 18th October 2006, 10:41   #9
navin's Avatar
Thanked: 4,282 Times
If your listening is so FM centric it might be worth it to invest in a diversity antenna. these antenna are actually 2 anetnnae location at opposite ends of the vehicle. The signals are compared and summed to give you a nicer cleaner output. These anetnnae can also reduce "picket fencing" to some extent. I have use these sort of antennae in diffcult places like the Catskills (NYS) or Shenandoah (VA).
navin is offline
Closed Thread
The Amateur Radio (Ham Radio) thread bejoy Shifting gears 102 11th October 2017 10:43
Radio Auto Launched! Radio TUK TUK RW9763 Street Experiences 2 24th November 2010 15:17
Radio Disturbance when Braking - Help please manaa45 In-Car Entertainment 6 27th January 2007 14:19
Radio Disturbance A.T In-Car Entertainment 21 7th December 2005 22:13
