Old 21st May 2004, 11:29   #1
Sahil's Avatar
Thanked: 2,712 Times
Thumbs up
Hey guys i am new to this forum... good thing u guys got on here ... I need you ppls suggestions for fitting a woofer in my Accord it's the 2002 model . I dont want to cut the tray or anything. Was thinking of putting a woofer in a box in the trunk with the amp so that i dont screw around with the interiors. If anyone of you have fitted a system on an accord or can help me in anyway about whats the best way to do this pls post a reply thnx
Old 21st May 2004, 13:14   #2
Rudra Sen's Avatar
Thanked: 4,288 Times
Hey Sahil.
I don't think you need to cut the tray.You can keep your sub woofer in the trunk. But in this case get a cylindrical one. Say a JBL or Blaupunkt.
Amp can go under the seat. I have the same set up in my Optra. No issue with low frequency.
Old 21st May 2004, 21:52   #3
Sahil's Avatar
Hey buddy thnx for the reply, unfortunatly i have already got a 12inch woofer and a pioneer i think 404 amp, which i actually got to fit in my endeavour but the rear space is too less so i thought i'd rather put it in the accord. I had changed the speakers rear ones earlier and fitted pioneer 300 watts opens i am not sure about the model number but they are the high end ones give reall good sounds, i dont even feel the need for a woofer as much but since its goin waste i rather fit it.
Well my only concern is that the woofer box should not toss and tumble in the trunk.Also should i connect the amp to my speakers too? I think accord 2002 the one i have is with the factory fitted high end panel which i heard has an inbuilt small amp powering the spkers hence the effect is soo good from my spker change.If any1 has any knowledge about this pls let me know if i should connect the amp to the speakers too as i dont wanna have it torn by the end of it. I want the bass to come mainly on the woofer and as less as possible on the speakers to ensure they last longer,any clue how i can do that ?
Old 21st May 2004, 21:59   #4
aadix's Avatar
hi sahil
pm gto, he knows a lot abt audio setups
infact check out his city vtec audio setup
and i think you can connect ur spks to the amp
aaditya
ps:what cars do you have bud?
howz the endeavour??
aadix is offline   Reply With Quote
Old 22nd May 2004, 04:52   #5
Rehaan's Avatar
Thanked: 25,038 Times
Originally Posted by [b
Quote[/b] (Sahil @ May 21 2004,20:22)]I want the bass to come mainly on the woofer and as less as possible on the speakers to ensure they last longer,any clue how i can do that ?
Hey Sahil,
When you connect the amp to the output from the head unit, the amp should have an "cutoff frequency" and maybe even a cut off curve selector. Basically this is a "low pass filter" which lets only the low frequencies (bass) through the amp to the woofer. You should be able to select the upper limit of what frequencies are passed through to the subwoofer.
About not letting the bass through to the regular speakers, well, if there is no amp to the speakers its a bit complicated, i guess you could install a high pass filter (lets only highs through)....they come in two types, active(need power supply) and passive(no power supply needed).
However, i wouldnt try to kill the bass on the regular speakers unless you are planning to listen to your music REALLY loud...
Thats the solution i could think of...
cya
R
Old 26th May 2004, 13:06   #6
Sahil's Avatar
Thumbs up
Hey guys thanx alot for the help, really appreciate it. I however did get the woofer finally fitted, Rehaan i had already done the low pass thing to max that really helps coz it bass load on the spkers is much less. The accord's deck doesnt have enough settings to get the sound just pefect just basic things like Bass and Trebbile adjustments but its good enough the pretty good and as for my speakers i think they r pioneer 6975 if i am not mistaken, they go a good job
BMW 635d - Sound deadening ( Dyna-matting ) and new sub-woofer and amp. g8128 In-Car Entertainment 8 18th July 2010 18:08
Looking for an AMp & Woofer for my Santro Ali Shifting gears 3 12th October 2007 10:53
What do I do with a 2 way SONY amp 1 Woofer and 4 speekers. bhogalrajnish In-Car Entertainment 37 26th July 2006 22:42
Woofer & Amp jesal In-Car Entertainment 13 5th April 2006 12:30
Fitting a sub-woofer ajmat In-Car Entertainment 27 3rd June 2005 11:04
