Old 17th January 2007, 20:53   #136
ankur's Avatar
Originally Posted by speedzak View Post
For internet connectivity on the move, The best option now is to go for the Indicom USB modem kit. Just plug in to a USB port and You're connected. And it's quiet small in size too.
I dunno about the indicom's performance there. Here, it's not that great when it comes to customer service. Network reachability is not bad though.
Ankur! Once again, YOUR SETUP IS AWESOME!! Congrats on finishing it with perfection.
Thanks.
I went to 2 separate dealers of Tata indicom and neither knew anything about these. The website has a Plug 2 Surf system which i think will be perfect for me but neither the dealers nor the customer care knows about it. I also went to Reliance about the internet connection on mobile phones and those dealers were also almost clueless about the internet schemes. Typical indian company mentality, the company, the customer care and dealers are never on the same page. The same is also true for companies like Airtel. Really sad when prospective customers have to run from pillar to post to buy something from a company.
I have written to tata indicom and will write here if anything moves.
cheers.
ankur is offline   Reply With Quote
Old 18th January 2007, 11:46   #137
tsk1979's Avatar
Thanked: 16,421 Times
Don't go to reliance webword express, go to reliance webworld. Webworld express are franchises and are clueless. Their only aim is to sell handsets at a price higher than the market rate.
On reliance you will get unlimited platinum plan only on a PCMCIA card or the USB modem. As per reliance website they have discontinued unlimited plan on handsets.
Your other options are BSNL/MTNL(Garuda) and Airtel GPRS, but on the latter speeds are around 10-15kbps(Kilo bits per second).
Old 18th January 2007, 12:29   #138
hydrashok's Avatar
Default Heads up on Reliance Internet connection
Ankur, there is something that you'll need to keep in mind when you go in for the Reliance Internet Connection over a CDMA cellie (if you do).
When I travel with my Laptop, I use the Reliance Infocomm connection over an ancient LG2030 (the first model they used to give). The Reliance connection has the problem that it goes into idle if the connection is not used for more than say 30 secs (yes, 30 secs!). And once the connection goes into idle it never comes back online properly. Either the connection gets cut-off by itself after about an minute of idle-time, or the computer hangs.
I'd spoken to Reliance Customer Care (yes, like speaking to a blank wall) about the idling issue. They said that they are conserving bandwidth, and allocating it to somebody who is using the connection at that point of time. I kept getting the same spiel each time I tried asking about this. So I gave up and used the PING hack instead.
What I do is, I give a "ping/t xxx.yyy.com" command in the DOS console (where xxx.yyy.com is the first IP I get on a TRACERT, or either one of my 3 websites, or a very high bandwidth website). This keeps the connection alive till I decide to disconnect.
I'm not sure if the TATA connection also has this issue. I'm not sure if the Reliance PCMCIA card connection or the USB modem has this issue either. Maybe somebody using either of these can comment?
Old 18th January 2007, 12:50   #139
Have you tried this?
TATA Indicom - Do More. Live More --------------------------------------------
hrag is offline   Reply With Quote
Old 18th January 2007, 13:04   #140
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by hydrashok View Post
I'm not sure if the Reliance PCMCIA card connection has this issue either. Maybe somebody using either of these can comment?
I use a Reliance PCMCIA card to get online when i am not in the office. I have no such 30 second issues. However, on occasion (Say once in an hour) it will show no connectivity (That is to say, i can't open a webpage in Safari, or check my mail) when i disconnect and reconnect, it's fine then.
Old 18th January 2007, 13:10   #141
iraghava's Avatar
Thanked: 156 Times
TATA also has this issue as both these providers devices are bandwidth-on-demand devices & hence go dromant if not used for an extended period of time. But if the signals in TATA are 4 or 5 out of a 5 scale then this issue doesn't bother, this problem is more exaggerated in a low-signal area.
Old 18th January 2007, 14:36   #142
ankur's Avatar
Originally Posted by hrag View Post
I am actually interested in the Plug 2 Surf from tata, if they call me.
cheers.
Old 18th January 2007, 14:40   #143
ankur's Avatar
Ah a mac user . Most of the dial up systems, pstn or cdma do have an issue keeping an idle connection alive, the company doesnt want people to tie up their ports. There are lots of simple programs availble to keep these alive and i will just one of them.
cheers.
Old 18th January 2007, 14:43   #144
ankur's Avatar
MTNL i wouldnt touch with a barge pole and Airtel sucks, i already have it. Its pretty reliable but the throughput is completely choked. I use it on my phone for email and IM but browsing is just not worth it.
I will try to get the Tata connection.
Old 18th January 2007, 15:16   #145
tsk1979's Avatar
You will be paying a lot as the max free data transfer is 1GB for the high end plan.
On reliance you have the option of 1500/month with no data transfer charges. They also have a USB modem.
If you want, this weekend I can ask Noida reliance webworld which is a full fledged outlet.
Old 18th January 2007, 15:20   #146
ankur's Avatar
I dont think i will be using this a lot anyway, maybe after a month or so i decide to cancel it altogether.
Yes, please let me know what Reliance says, in the meantime i am trying to get someone from Indicom to tell me what they have. Called and left my details, now someone will call me ... *sigh* !
cheers.
Old 18th January 2007, 15:23   #147
tsk1979's Avatar
I was thinking maybe you plan to use google earth as your GPS sytem via GPS trackmaker. This way it will eliminate need of any maps etc,. since google earth has mapping for most major roads, with many new ones being added.
But your data transfer is going to be high with that.
Old 18th January 2007, 15:27   #148
ankur's Avatar
Well i already have Mapking, and it works great so i dont need the net connectivity for that. I wanted it primarily as a novelty and also to be able to check email on the go, there is an app that reads out the email etc.
cheers.
Old 23rd January 2007, 13:40   #149
ankur's Avatar
Ok people, had some time so decided to post some more pictures :
Here is JB diligently putting heat shrink sheeting over the connectors
Here is the sound card - SB Audigy 2 NX
Some of the supplies
More supplies
The USB Hub sitting on the DVD, sitting on the PC case
Old 23rd January 2007, 16:41   #150
ankur's Avatar
This is the reverse sensor, it overlays the sensor information on top of the camera image and displays that. Connected to the reverse light, so it comes on automatically when i put the car in reverse.
JBs prized possessions
Concealed wiring for the concealed reverse camera
Panel where the USB ports are mounted
Opus 80watt power supply sits behind the screen
JB and me wiring the MMI controller
This is the PC, it sits under the front passenger seat
This is me, cleaning the old battery contacts with a Dremel tool
Another view of the power distribution near the hand brake
The Tsunami power cable connected to a new Amaron Pro battery
Making a grounding point
The GPS receiver under the windscreen
Decals at the back
Fabrication advice for Vintage Car Parts (axle, driveshaft etc.) Jehan-Sam Vintage Cars & Classics in India 1 26th October 2014 07:25
Hyderabad, "Willys MA" 1941 fabrication fazalaliadil 4x4 Vehicles 46 15th February 2011 19:07
SQ Setup for Polo (budget-friendly install) Youcanburn In-Car Entertainment 19 12th February 2011 14:20
Indigo Center Console Touchscreen LCD Fabrication shldn In-Car Entertainment 95 13th August 2009 12:47
