Old 5th November 2006, 19:07   #16
rsjaurr's Avatar
Thanked: 27 Times
Sony SD series or pio mono [not D510 which mugen was talking abt]would be his best options but without b&w.
rsjaurr is offline   Reply With Quote
Old 5th November 2006, 20:28   #17
Bass&Trouble's Avatar
Thanked: 74 Times
I think you should select the sub before deciding which amp to get for it. If you buy yourself a single voice coil sub, there's no point buying a monoblock optimized for maximum output at 2 ohms. It's a waste of money. For a SVC, I would recommend a monoblock capable of full output at 4 ohms, or a 2-ch amp bridged, to do the job.
Old 5th November 2006, 20:51   #18
Awaiting Email Confirmation
lancer_mania's Avatar
whats is a SVC and what is a dvc why cant i use a 2 chan amp with a DVC
lancer_mania is offline   Reply With Quote
Old 5th November 2006, 21:07   #19
Sam Kapasi's Avatar
Thanked: 1,490 Times
SVC - Single Voice coil Sub (generally 4 ohms)
DVC - Dual Voice coil Sub (can be 2 ohms each, or 4 ohms each or rarely even 8 ohms each)
Old 5th November 2006, 21:36   #20
navin's Avatar
Thanked: 4,351 Times
no reason why you cant. what gave you this impression.
most car amps are ahppy at 4 ohms and can tolerate 2 ohms so as long as each channel of the car amp "sees" more than 2 ohms you should be ok.
the problem will be if you bridge the amp then you need to double the minimum impedance stated. so if yo take a 2 ch amp and bridge it then take a DVC 4ohm per coil speaker and parallel the 2 coils you are going to overload the amp. The amp will see 2ohms bridged which effectivly means 1 ohm per channel.
but you can wire the coils in series and drive the amp to a 8 ohm load (4+4 ohms).
Old 6th November 2006, 16:42   #21
Thanked: 74 Times
Hey Bhagwan (not the Bhagwan who posted someplace else looking for an installer in Mumbai),
Why 8 ohms and all? Then the setup doesnt sound as loud based on the specs advertised, and you blow the sub by clipping it. And if the installer cannot figure out serial connection, then you have a fried amp.
The idea of my post was to advice that please buy mono amp rated at full power at 4 ohms if using a dvc, or 2 ohm stable class D types if DVC. Like Sam says.. 'Buss'
Old 6th November 2006, 16:47   #22
navin's Avatar
Originally Posted by Bass&Trouble
Why 8 ohms and all?
I thought he already had a 2 ch. amp and a DVC sub. Sorry I am senile.
Old 6th November 2006, 21:17   #23
how will the jbl sub sound with the sony 552 bridged ?
if im using the 552 will he JBL sound better or will the pio sound better.and finally between the sony and the pio sub which one is a better bet ?
Old 6th November 2006, 22:08   #24
Sam Kapasi's Avatar
Between those 2, the pioneer is a clear winner.
Old 6th November 2006, 23:24   #25
Thanked: 11 Times
lancer_mania,
JBL Or Pioneer Both will sound great but you should not have to go for Sony Sub.
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 6th November 2006, 23:33   #26
Originally Posted by Mugen_Power
lancer_mania,
Cheers,
Mugen_Power.
so then if not sony which amp should i use.which is less than 4k
Old 6th November 2006, 23:36   #27
revtech's Avatar
Thanked: 35 Times
yeah id have to agree with sam. i heard the pioneer and sony this eve and the sony aint that great.
but sam i was unable to hear the earthquake so i wanted to know between the pioneer and the earthquake which one is better ?
Rev
revtech is offline   Reply With Quote
Old 6th November 2006, 23:58   #28
abhibh's Avatar
Thanked: 34 Times
Earthquake is better IMHO. I heared it while one of my frnd was getting the hu installed. It was getting instaling a fiesta. Bass was nice really nice..
Old 7th November 2006, 00:01   #29
Thanked: 11 Times
lancer_mania,
I was only talking about Sub not the Amp.
Mugen.
Old 7th November 2006, 00:09   #30
which amp shoul i use with the pio or jbl
BMW 635d - Sound deadening ( Dyna-matting ) and new sub-woofer and amp. g8128 In-Car Entertainment 8 18th July 2010 18:08
Sub under 20K budget Mi10 In-Car Entertainment 28 27th February 2010 03:48
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
