Old 9th November 2006, 13:04   #1
blueraven316's Avatar
Question The JBL 300.1 Amp
Was going thru the specs of the JBL 300.1 amplifier,
GeneralPower Output300 watts RMS x 1 channel at 2 ohms
and ≤ 1% THD + NS/N Ratio100dBA (reference 1 watts into 4 ohms)Dynamic Power400 watts at 2 ohmsEffective Damping Factor6.39 at 4 ohmsFrequency Response10Hz - 300Hz (-3dB)Maximum Input Signal7.5VMaximum Sensitivity100mVDimensions2.2" x 13" x 10.3"
Now what is the output at 4 Ohms on this amp ? 300 RMS itself ?
Is this amp CEA Rated ? as the site did not mention it.
blueraven316 is offline   Reply With Quote
Old 9th November 2006, 13:21   #2
Thanked: 26 Times
CS300.1
• 200W RMS x 1 channel at 4 ohms and <= 1% THD + N
• Signal-to-noise ratio: 100dBA (reference 1W into 4 ohms)
• 300W RMS x 1 channel at 2 ohms, 14.4V supply and <= 1% THD + N
• Dynamic power: 460W at 2 ohms
• Effective damping factor: 6.395 at 4 ohms
• Frequency response: 10Hz – 300Hz (–3dB)
• Maximum input signal: 6V
• Maximum sensitivity: 100mV
• Output regulation: – 0.07dB at 4 ohms
• Dimensions (L x W x H): 12-11/16" x 10-1/4" x 2-3/16"
• Fuses: 20A x 2
I am not sure whether this is CEA rated power!
GTO301.1II
• 204W RMS x 1 channel at 4 ohms and <= 1% THD + N
• Signal-to-noise ratio: 77dBA (reference 1W into 4 ohms)
• 294W RMS x 1 channel at 2 ohms, 14.4V supply and <= 1% THD + N
• Dynamic power: 320W at 2 ohms
• Effective damping factor: 6.39 at 4 ohms
• Frequency response: 10Hz – 302Hz (–3dB)
• Maximum input signal: 4.7V
• Maximum sensitivity: 75mV
• Output regulation: .098dB at 4 ohms
• Dimensions (L x W x H): 11-5/8" x 12-5/16" x 2-3/8"
• Fuse rating: 1 x 30A
This is CEA rated power
anToNIcHeN is offline   Reply With Quote
Old 9th November 2006, 13:25   #3
Sam Kapasi's Avatar
Thanked: 1,473 Times
Let me check if the CS is CEA rated.
Why are you looking at a CS monoblock? You want one?
Edit: Just called for the box - CEA2006 compliant logo is on the box. So Blue , the answer is yes.
Old 9th November 2006, 13:40   #4
My friend wanted to fit one, now my main query was what is the power output on the amp @ 4 Ohms ? 300 RMS itself or less , if less what is the Output ?
Old 9th November 2006, 13:41   #5
Sam Kapasi's Avatar
At 4 ohms it is 200W.
Old 9th November 2006, 13:42   #6
Thanked: 26 Times
Originally Posted by anToNIcHeN
CS300.1
GTO301.1II
do look at the rating that i had posted!
@SAM... man talk about synchronisation!... look at the timings of both the posts!!
The 250/300 War! Ninja 300 vs CBR250 vs Hyosung GT250R jkdas Motorbikes 27 30th December 2013 19:14
JBL GTO Vs JBL GT5 Amps. rider60 In-Car Entertainment 9 30th May 2011 13:35
JBL 607C or JBL 660C? ultimatechamp In-Car Entertainment 33 18th July 2008 19:13
For Sale - JBL 2ch Amp and JBL 12" Basstube karthik247 Shifting gears 5 3rd December 2007 17:44
