Old 18th July 2017, 18:23   #1
akshay380's Avatar
Thanked: 487 Times
Smile DIY: Touchscreen Android ICE on a shoestring budget (using a Tablet)
Requirement: To have a touchscreen android unit in car
Options considered:
1. Android HU. I didnt want to spend too much money since i am not a music buff and needed the display mainly for viewing data from OBD.
2. Tablet mount available online: Most of these were suction mounts on glass/dashboard which affect the visibility.
3. I was OK with slight loss of aesthetics as long as it did'nt look downright ugly.
4. Already had a spare Nexus 7 lying around so decided to use that.
Items needed:
1. Some wooden/plastic blocks
2. Sandpaper for wood
3. Velcro
4. 3M double sided Tape
5. 30 minutes
Getting Hands dirty? Not really!
Went around neighborhood and bought item 1,2,3 from different shops. Since the quantity needed was tiny, none of them asked for money. Had I bought from from one shop, I might had to pay something
1. Get the wooden blocks sanded properly. Make sure that the height is more than the central ON/OFF+Volume knob. As of now I have just stuck two blocks with 3M tape (one onto another) but will replace them with a single block once I find time. Also the length of the block should be such that it has enough contact area on HU for holding weight of Tablet.
2. Cut required length of Velcro and stick it on wooden blocks as well as either ends of tablet. I have kept soft strip on tablet and hard on wooden block. Measure the distance between two blocks and match it with Velcro on tablet.
These pics were taken before the blocks were sanded. Now they are silky smooth!
Ideally I wanted the blocks to be slightly nearer but this is the only flat place I could find.
3. Thats it, job done!
So now I get all readings from Torque pro without using my mobile. I also have a TANTRA bluetooth receiver connected to N7 and I can watch movies or listen songs while the sound gets routed to car audio. I cannot use it to make calls since my N7 does not have simslot. Doing a workaround to fix this.
The tablet does not vibrate/shake even on bad roads. One of the reasons for using Velcro and two blocks of wood with 3M tape. All have good dampening. One issue I am facing right now is to access volume knob when tablet is mounted. I am mitigating that by using volume options on tablet.
So thats it guys. I know many have done it much better but this is sufficient for me. Total cost? About 4 inches of 3M tape!!
akshay380 is offline   (31) Thanks Reply With Quote
Old 18th July 2017, 21:52   #2
Thanked: 9 Times
Default re: DIY: Touchscreen Android ICE on a shoestring budget (using a Tablet)
Nice mod. And good use of the Nexus 7... one of the iconic tablets.
Do you switch it off when you park the car? The only potential hazard is the lithium cell in the tab. The high temps in the stationary car may impact the battery. Definitely do not keep it on standby mode. Switching off might alleviate the problem a bit.
social3047 is offline   (5) Thanks Reply With Quote
Old 18th July 2017, 22:35   #3
akshay380's Avatar
Thanked: 487 Times
Hey, Thanks. I take it out when leaving the car. That's the reason I'm using velcro.
akshay380 is offline   (5) Thanks Reply With Quote
Old 18th July 2017, 22:58   #4
govigov's Avatar
Thanked: 382 Times
Very nice. The nexus 7 is a good tablet for this purpose. There are some custom roms and kernels/firmwares which can take this to the next level.
For example -
https://forum.xda-developers.com/sho....php?t=2789993
https://timur.mobi/timurs-kernel-n7-2013/
govigov is online now   (3) Thanks Reply With Quote
Old 19th July 2017, 01:55   #5
vidyanand's Avatar
Thanked: 37 Times
Nice budget mod.
You can install/sideload Android Auto app on your tablet if it is Lollipop or higher. Interface will give you all Android Auto features including handsfree (Google voice) controls in a standalone app.
https://play.google.com/store/apps/d...ction.gearhead
vidyanand is offline   (3) Thanks Reply With Quote
Old 19th July 2017, 10:02   #6
Thanked: 261 Times
Looks nice. But, how do you operate the ICE? The access to ICE is completely shut by the Android
I doubt even if remote works on ICE since android physically covers the system.
gkveda is offline   (2) Thanks Reply With Quote
Old 19th July 2017, 11:16   #7
akshay380's Avatar
Thanked: 487 Times
Default Re: DIY: Touchscreen Android ICE on a shoestring budget (using a Tablet)
Ok, only thing I use from ICE is the AUX port situated at the bottom. It's connected to tantra Bluetooth receiver. For volume knob, I have set it to almost max position and use volume controls on tablet. I don't use FM or CD player at all. Also worst case, I can just remove the tablet in one second
akshay380 is offline   (1) Thanks Reply With Quote
Old 20th July 2017, 12:10   #8
Thanked: 28 Times
Please can you let me know how do you get all this data from OBD.
Looks really useful.
joy_swift is offline   (1) Thanks Reply With Quote
Old 21st July 2017, 12:42   #9
ank.nsit's Avatar
Thanked: 157 Times
Simply nice work.
But I have one question, the setup as such does not look sturdy enough to take on the potholes of Indian roads.
How did you ensure that the blocks do not come out? Is the 3M tape that strong?
ank.nsit is offline   Reply With Quote
Old 21st July 2017, 13:05   #10
harsh79's Avatar
Thanked: 546 Times
@akshay380
Try Dual Lock from 3M instead of the velcro.
harsh79 is offline   (1) Thanks Reply With Quote
Old 21st July 2017, 17:41   #11
sriramr9's Avatar
Thanked: 43 Times
How do you get data from ECM to your tablet ? If its via the ELM327 streamed through blue tooth, do you keep ELM 327 plugged all the time to the port ?
Will it not cause Battery drain ?
sriramr9 is online now   Reply With Quote
Old 23rd July 2017, 08:27   #12
akshay380's Avatar
Thanked: 487 Times
Hey I use Torque Pro app on Android. Here is a the thread on OBD. Pl ask if you have any doubts. http://www.team-bhp.com/forum/techni...dian-cars.html (OBD (On-board diagnostics) for Indian Cars)
Its been a week I am using this and yesterday drove on some non existent roads thanks to monsoon. Its holding up well. The best thing I like is the dampening provided by Velcro+wood since the screen does not vibrate at all. Surely at some point I will have to find out what to use though!
Originally Posted by harsh79 View Post
@akshay380
Surely didnt know about that!
Yes it is via bluetooth. Frankly I have been using this for 2+ months now and didnt see any issues. That said I make sure I ill take it out when not using car for extended periods.
Old 23rd July 2017, 13:21   #13
Thanked: 55 Times
The latest OBD2 adaptor from 'icar pro' from VGATE is said to consume <3mA (Earlier versions upto 30mA) in standby mode. This 'Pro' version also has 'Auto On/Off' feature; so you can avoid plugging / unplugging.
batman is offline   (2) Thanks Reply With Quote
Old 24th July 2017, 14:25   #14
SRK
SRK's Avatar
Thanked: 352 Times
Nice DIY Akshay. Good that it is holding up well.
Did you not check out the CD Slot Mount options? Since your car has a cd slot it could be useful.
These are avaialble on Amazon starting from Rs. 550 onwards - http://amzn.to/2tD8ogD
SRK is offline   Reply With Quote
Old 24th July 2017, 15:02   #15
samaspire's Avatar
Thanked: 2,092 Times
I had ordered a similar one and stopped using it because the screen vibrates too much on the road. And there is a very real danger of the tab/phone falling off on hitting a large pothole.
samaspire is offline   Reply With Quote
The Quintessential Tablet PC Thread (Android, Apple, BB et al) vcash Gadgets, Computers & Software 1660 7th August 2017 16:25
Team-BHP App for your Android Phone & Tablet GTO Team-BHP Apps & Mobile Access 887 24th July 2017 10:07
DIY: Tablet as an In-Car-Entertainment Console sara.ramli In-Car Entertainment 54 9th December 2015 15:19
DIY 7 Tablet PC Mount yajaman99 In-Car Entertainment 16 8th September 2013 09:10
ICE on a shoestring naru In-Car Entertainment 15 31st May 2009 09:56
