Old 10th November 2006, 16:27   #1
revvedup's Avatar
Suddenly a strange problem has started occuring in my car stereo every time the horn is used it plays through one of my rear speakers(blaupunkt gtx-693x) on my zen.Not only this there is distortion is also caused even when the horn is not used.
revvedup is offline   Reply With Quote
Old 10th November 2006, 16:34   #2
navin's Avatar
Thanked: 4,282 Times
a) what sort of distortion (when the horn is not being used).
b) the horn relay might need to be changed
c) Does the hron only play via the rear speakers or also in the front (if so do you have an amplifier for the rear speakers?)
Old 10th November 2006, 20:41   #3
revvedup's Avatar
I do not have an amplifier and the horn plays through only on the right speaker and when it does not the bass or the low frequeny sounds become distorted. However when i disconnected it it started playing on the left also.
I do not have an amp for the rears and the car has the following system-
hu-kenwood 30X4(factory fitted on the zen)
speakers front -pioneer not ovals they are fitted in the oe door slots instead of the orignal kenwood but are of the same size and are the circular ones
speakers rear -blaupunkt gtx 693x ovals 45w rms and 135w peak fitted them about a year back did not change the head unit because i read in one of the mags that the speakers cannot handle too much power and moreover most of the hu's today are 50wx4.Although the speakers do not get the desired power the problem has started occuring only recently.
Old 10th November 2006, 23:11   #4
amitverma's Avatar
a case of faulty earth wiring.
get it checked immediately.
amitverma is offline   Reply With Quote
Old 10th November 2006, 23:18   #5
kURETI's Avatar
go back to the same dealer and ask him to check for te cause and rectify the same. I FEEL ITS A FAULT IN WIRING / GROUND / SPEAKER TERMINALS TOUCHING THE BODY OF THE CAR.
kURETI is offline   Reply With Quote
Old 12th November 2006, 22:04   #6
theMAG's Avatar
Thanked: 1,572 Times
Case of multi-tasking capable electronics ?
More likely a leaking earthing.
Old 13th November 2006, 00:48   #7
Thanked: 17 Times
It can be easily the wiring gone haywire!
Get back to the same installer and get it sorted out.
Very few times, it could be due to the HU also. Get the wiring checked first. If it doesn't stop, you know.....
Old 13th November 2006, 01:10   #8
Zappo's Avatar
Thanked: 2,079 Times
Haa haa haaa... the thread heading made me swear out, thinking it is another one of those crazy mods that someone has done.
It sounds like a case of wiring gone haywire. Take your car to the installer.
Zappo is offline   Reply With Quote
Driving through Melghat - Quickie through Seemadoh, Kolkhas & Chikhaldara 1.2TSI7DSG Travelogues 5 4th April 2016 13:50
Hissing sound from speakers when not playing music. Please help. vishnuvijay In-Car Entertainment 62 12th March 2016 15:17
Advice needed for playing FLAC files through ICE ZeroThoughts Gadgets, Computers & Software 9 24th September 2010 14:41
hissing noise from speakers when horn is blown gopz In-Car Entertainment 7 14th June 2007 13:40
Speakers and horn for Zen Lxi in Chennai Serenity_Nimble Modifications & Accessories 1 9th May 2007 21:27
