Old 3rd August 2017, 14:58   #1
akhilesh51's Avatar
Thanked: 335 Times
Default BMW 525i E60 TV module gone, and Bluetooth too. Now what?
I have a 2009 model BMW 525i E60 car which has an inbuilt TV Tuner. As nice it sounds to have in the car, I have rarely used it over the past 7 years and don't intend to use it in future, but I have a problem.
The TV Tuner module (located in the Boot of the car) malfunctioned sometime back and is not working.
Doesn't matter since I don't use it? Right.
Wrong.
What has happened is that the TV module malfunction has rendered the CD Player and Bluetooth also useless since power is supplied to these modules through the TV module. (at least that is what the dealership says.)
Now, I really need Bluetooth to work because of hands-free operations. It is a must-have in my car and the only way to get it to work is to install a new TV module costing, wait for it... Rs. 2 Lac+.
I need your help in finding a solution which could bypass the TV tuner and activate Bluetooth module (I also don't care about the CD player, who has CDs anyways!) or a retrofit TV module which is cheaper to install.
So, anyone who has faced a similar issue or has knowledge of BMW Electronics and Entertainment system wiring, please help!
akhilesh51 is offline   Reply With Quote
Old 4th August 2017, 11:24   #2
Thanked: 91,437 Times
Default Re: BMW 525i E60 TV module gone, and Bluetooth too. Now what?
Two options.
1. Find the part number and order from here (Indian) or here (UK).
2. Update your head-unit - link.
Either option will work out far cheaper than the ridiculous quote provided by the dealer.
GTO is offline   (2) Thanks Reply With Quote
Old 4th August 2017, 11:31   #3
Akshay1234's Avatar
Thanked: 6,722 Times
That doesn't sound right. I don't think the TV module failing should stop all the other functions from working. Infact if the TV module fails it should only stop the TV function. That's based on my knowledge of how the newer Bimmers work, and I doubt this should be different.
Akshay1234 is offline   (1) Thanks Reply With Quote
Old 11th August 2017, 16:25   #4
Surya-TJet's Avatar
Thanked: 117 Times
Thumbs up Re: BMW 525i E60 TV module gone, and Bluetooth too. Now what?
Originally Posted by akhilesh51 View Post
I have a 2009 model BMW 525i E60 car which has an inbuilt TV Tuner....
As a simple solution for the stop-gap until this is sorted, please buy a handsfree bluetooth kit.
There are lot of companies, inlcuding a review of the Tantra BT kit in Team-BHP by one member. This will help in making and receiving calls for the time being through the head unit's aux speaker output.
Just my two cents for a temporary solution. Hope this helps.
Cheers & Safe Driving
Surya-TJet is offline   Reply With Quote
Old 11th August 2017, 16:30   #5
akhilesh51's Avatar
Thanked: 335 Times
The explanation given by dealership staff is that TV Module, Bluetooth Module and CD Player Module are linked in series i.e power passes through one module to reach the next module. Now, TV Module seems to be the first in the row therefore closing out the other 2 modules.
They even showed it to me on the vehicle diagnostic software where all three modules showed up in yellow while rest of electronics showed in Green.
Now, I feel there should be a way to bypass TV Module and supply power to other modules but don't want to risk using help of someone not well versed with BMW electronics.
Old 11th August 2017, 19:30   #6
Thanked: 160 Times
Akhilesh,
Not 100% sure but I believe you can bypass any component using a fiber optic loop in the BMW so that rest of the modules which do not have issues work. Please check on the net for the fiber optic loop.
malgudi is online now   Reply With Quote
Old 13th August 2017, 22:58   #7
Akshay1234's Avatar
Originally Posted by malgudi View Post
Akhilesh,
Fibre optic is for the data, and not the power as far as I know. But yes, even if he manages to power the other modules separately, he will need a fibre optic loop to make everything function. Or he can power the other modules separately which leaving the spoilt tv module in its place thereby removing the need for a fibre optic loop.
BMW 525i E60 (N2N) 2009 acceleration issue FlyinLow Technical Stuff 9 18th July 2012 20:15
Modding My BMW 525i krazyking Modifications & Accessories 13 11th December 2011 04:52
Opinion Please: BMW 525i or X3 mohitarora Luxury, Imports & Niche 16 12th March 2010 02:29
