Old 14th November 2006, 17:48   #1
Hello,
I am thinking of installing a pair of 6.5 inch coax speakers which have 2 ohm impedances, to go with the Sony GT350S head unit. The Sony specs says its rated 52W x 4 at 4 ohms impedance.
Is there a danger of overheating? Thermal cutoff? Or a blown fuse? I googled a bit and it looks like opinions are divided...
Thanks!
auriga2001 is offline   Reply With Quote
Old 14th November 2006, 18:25   #2
Sam Kapasi's Avatar
Thanked: 1,473 Times
What speaker are you installing? Sounds much like a JBL, lol.
If it is, Yes it'll be OK do not worry.
Old 14th November 2006, 19:36   #3
Hi Sam,
You guessed it right... they are JBL GTO637s.
Thanks!
Old 12th December 2006, 15:15   #4
Ramsagar's Avatar
Thanked: 62 Times
Hi sam,will poneer 6850(3 pre-outs 50w*4c) can drive JBL GTO937 3-way co-axils?and which 4" speakers can i go for the front of alto without using AMP.
Ramsagar is online now   Reply With Quote
Old 12th December 2006, 15:28   #5
Sam Kapasi's Avatar
Hello ram, welcome to our little part of this town. Do not forget to post an intro later.
Yes the 6850 will drive the GTO937 just fine. Matching 4" speakers would be GTO427.
Old 12th December 2006, 16:28   #6
navin's Avatar
Thanked: 4,286 Times
Sam seems that that "2 ohm" rating is scaring some people. Guys dont worry the "2 ohm" rating is nominal. Atleast the 937 measures closer to 3 ohms across much of the freq. range.
navin is online now   Reply With Quote
Old 12th December 2006, 21:51   #7
aah78's Avatar
Thanked: 1,752 Times
SPEAKER FAQs and ABC's...
this person has tried to explain the relation between speakers and impedance.
aah78 is offline   Reply With Quote
Old 13th December 2006, 18:20   #8
rsjaurr's Avatar
Thanked: 27 Times
navin,last yr when i was going through reviews of alpine HUs and infinty kappa speakers i found many complaining about shutting down of alpine HU and blamed it on HU or speakers.
I also read somewhere that alpine HUs r known to have less powerful int. amplifier than some of other HU like pioneer/kenwood/sony.
Now why manufacturers make speakers with 2ohm rating is to get maximum juice out of amplifier which only ext.amplifier and not int.amplifier can provide.
So based on above if i have to decide about it,i would not use any spk rated at 2ohm without ext.amplifier to be on safer side.
Even if someone uses these spk without ext.amplifier,nothing untoward can happen as u said that sometime spk have higher impedence but what if rating is even lower than said 2ohms for some other manufacturer?
rsjaurr is offline   Reply With Quote
Old 13th December 2006, 18:58   #9
Sam Kapasi's Avatar
I do not think anyone would make a speaker less than 2 ohms, commercially.
Old 14th December 2006, 10:36   #10
navin's Avatar
Yes they do/did. Wilson's original WATT had an impedance that dipped to less than 2 ohms (1.5ohms or thereabouts) and posed a pronblem for many an amplifier.
Besides in my mad crazy younger days I DIYed a line soruce of 6 8" woofers (8 ohms each) wired in parallel. I was trying to make a scaled down replica of the some speaker I think it was called Infinity IRS system V.
6 ohm or 8 ohm speaker?? arjithin Gadgets, Computers & Software 12 27th November 2011 16:11
4 ohm DVC sub and JBL 1004 LionX In-Car Entertainment 27 28th August 2009 19:57
Sale: Sony Xplod CDX-GT350S CD/MP3 player theMAG Shifting gears 1 26th November 2007 12:32
Correct Eq settings for Sony CDX-GT350S msharma_79 In-Car Entertainment 2 21st November 2007 13:13
Sony CDX-GT250S + Sony XS-GF6932 aalaap In-Car Entertainment 13 20th September 2006 13:31
