Old 25th February 2007, 11:00   #151
Sam Kapasi's Avatar
Thanked: 1,490 Times
Originally Posted by Sam Kapasi View Post
I think the amp you have is Auzo. It's not bad for the price.
That should answer your question Karthik, it was a few posts above. Maybe you missed it.
Guys, really, please read before you write, thanks.
Old 22nd March 2007, 01:41   #152
xinome's Avatar
Question
Re - starting thread!
what karthik meant to say is, how are the auzo amps
i have a auzo 250 watts 2 channel amp ( i still don't know why i bought it )
powering a 1000 watt JBL bass tube
its going to be a month now and i am happy with the install but, how long would this AUZO last its powering a 1000 watt bass tube + the gain on the amp is low + it gets hot i mean seriously hot
xinome is offline   Reply With Quote
Old 22nd March 2007, 02:18   #153
revtech's Avatar
Thanked: 35 Times
many amps get really hot. i used to get worried when my amps got hot but realized its normal.
whats your gain set at.
Rev
revtech is offline   Reply With Quote
Old 22nd March 2007, 02:23   #154
xinome's Avatar
i didn't exactly get what you asked by where the gain is set at, but i hope this answers your question, half way through full.
and yes i still haven't changed the gaps between the speakers and tube, seriously will this cause any problems!
Old 22nd March 2007, 04:15   #155
revtech's Avatar
Thanked: 35 Times
so your gain is fine.no it wont cause any problems but may sound better if you do.but if it sounds good to you right now.i suggest you leave it as it is.
Rev
Old 22nd March 2007, 09:05   #156
hydrashok's Avatar
I'd read in an amp manual (a pretty powerful mono amp) that when pushed hard, it could get as hot as 90 degrees, and that one should exercise caution while touching an amp that has been working hard for some time.
The exact heat limits would be different from amp to amp, but if used for a while, most amps get pretty hot -- hot enough to not be able to put your palm on them for more than a few secs. Most amps will have thermal shutdown setups, so they will turn themselves off if things get hot enough to cause damage.
Old 22nd March 2007, 12:06   #157
navin's Avatar
Thanked: 4,349 Times
If the amp is getting you hot and bothered I am sure there is a DIY circuit out there that will trigger a fan off a Thermistor; I have used this for my Home amps (2 fans trigger at 55deg C and 2 more at 70 deg C and I have manual overide if I ever want to use the amps baised to Class A).
Google (or LBM) can help find such circuits.
My Good old Zen Gets JBLfyed!! nripin In-Car Entertainment 27 17th February 2008 03:06
My JBLfyed Baleno.... sys_whiz In-Car Entertainment 26 5th May 2007 18:02
No more ZEN for Zen Lovers abhibh The Indian Car Scene 65 8th May 2006 17:17
Used Zen vs new Zen shuvc Hatchbacks 12 18th August 2005 19:16
E-Zen & B-Zen.... MustangMan The Indian Car Scene 3 2nd July 2005 21:27
