Old 9th February 2007, 13:16   #121
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by revtech View Post
im getting both at almost the same price but the GTA with bill and warranty thats why im inclined towards that.
My advice wasn't based on official v/s unofficial.
Old 18th February 2007, 00:35   #122
revtech's Avatar
Thanked: 35 Times
one more addition to my setup...sony 2 chan amp is out and instead of that got the blaunpunkt GTA 275.sub sounds much nicer now and way more powerful.
i have one question though.how hot do these 2 chan amps get ?? because im guessing my previous amp got too hot couldnt take the load and blew.i definitly dont wnat that happening to this amp.the other day it seemed pretty hot ....!! gains arre set to about 60 %
Rev
revtech is offline   Reply With Quote
Old 20th February 2007, 11:37   #123
Dude...Amps getting Hot is noraml....i bet myself to keep ma AC On...when using my ICE...as that cools of the AMP a bit...and evrything remains clean:-)
ASH-WINS is offline   Reply With Quote
Old 20th February 2007, 12:55   #124
navin's Avatar
Thanked: 4,286 Times
hot enough to not handle for too long but not hot enough to touch. It also depends on the load.
Old 20th February 2007, 15:36   #125
revtech's Avatar
Thanked: 35 Times
why im worried is because the sony amp gave up i dont want the same to happen with this blaunpunkt.should i reduce the gain or bass boost ?will that help ? gain is set to about 60 %
Rev
Old 20th February 2007, 15:50   #126
navin's Avatar
is it too hot to touch?
Old 20th February 2007, 20:37   #127
revtech's Avatar
Thanked: 35 Times
its not too hot to just touch but if you put your hand on it for some time you can really feel the heat....its so hot that you have to get your hand off it.
Rev
Old 20th February 2007, 22:39   #128
Thanked: 21 Times
Mate, its a class T amp. We've used a few and it shouldn't be getting that hot. You're doing something wrong. Possibly: load, gains, boost. Fix it before you blow this amp.
Old 20th February 2007, 22:56   #129
hydrashok's Avatar
I think he bought the GTA275, not the PA275. I got a bit confused at first too. The GTA would be Class AB.
Rev, a bit of heating-up is all right. As long as you can put your hand on it for a while and not get reaaaaaal uncomfortable it should be ok.
BTW, what gauge power cables are you running, Rev? And you have just one amp now, right?
This is a real wild guess, but will an amp getting fed through a lesser (lesser = less thick) than required power cable get heated up excessively? With the amp feeding a bass tube, should he be running 4 gauge? Folks?
Old 20th February 2007, 23:38   #130
revtech's Avatar
Thanked: 35 Times
yea hydrashok is riight i got the GTA 275 not the PA 275.
at times after prolonged usage you cannot comfortably put your hand on the amp without feeling excessively hot/burnt.
and yea i have just one amp right now feeding the bass tube.
yea could this be the case ?? do i need a thicker cable ?
Rev
Old 20th February 2007, 23:58   #131
Thanked: 21 Times
Oops! My bad... thanks Hydra...
Old 20th February 2007, 23:58   #132
xinome's Avatar
HEY revtech i got a jbl bass tube 1000 watts recently my budget was 12000 so i go the tuve boss wiring and they gave me a AUVO or somthing like that AMP - the amp is on;y 250 watts what did i get and does it make a difference i own alto
xinome is offline   Reply With Quote
Old 21st February 2007, 01:17   #133
revtech's Avatar
Thanked: 35 Times
never heard of that amp ?? you got a 250 watt amp im guessing thats 250 W MAX power and not 250 W RMS.
since you were on a tight budget and you got this amp its k..as long as you feel it sounds nice but a more poweful amp will def be welcomed by the bass tube as its capable of handling much much more than what your current amp is prob supplying it.
make sure your gains arent set very high or your amp may over heat and give up like my sony 552 did.
its recomended to get a more powerful amp as soon as you can for the tube and use this for the front speakers unless its too grainy like the sony.havent heard it so i wouldn know.
but if your satisfied with your setup then alls good.....no need to change anything.
Rev
Old 21st February 2007, 10:32   #134
navin's Avatar
then this is fine. thicker cable will help the amp breathe. you will notice this on transients most. No need to rush but upgrade when able.
Old 22nd February 2007, 00:01   #135
Sam Kapasi's Avatar
Thanked: 1,473 Times
Rev, I'm sure it's all good. Amps do get hot and that's fine. Your blau amp is better than your ex sony. Sit back relax and enjoy.
Xinome, I had difficulty reading your post. I think the amp you have is Auzo. It's not bad for the price.
My Good old Zen Gets JBLfyed!! nripin In-Car Entertainment 27 17th February 2008 03:06
My JBLfyed Baleno.... sys_whiz In-Car Entertainment 26 5th May 2007 18:02
No more ZEN for Zen Lovers abhibh The Indian Car Scene 65 8th May 2006 17:17
Used Zen vs new Zen shuvc Hatchbacks 12 18th August 2005 19:16
E-Zen & B-Zen.... MustangMan The Indian Car Scene 3 2nd July 2005 21:27
