Old 13th December 2006, 17:17   #16
Gtea's Avatar
Well actually I kind of gave her a hint. :-)
She asked me what I wanted for a present. So I said wiring kit.
Well she couldn't understand why normal wires wouldn't work.
So after some explaining I got them after a few days. Hehehe
I'm still planning to use them on the Scorpio. (just to make her happy)
Cheers....
Gtea is offline   Reply With Quote
Old 13th December 2006, 17:19   #17
Thanked: 26 Times
Originally Posted by Gtea View Post
I was searching around the Forum and I found that blueraven316 had 2 Audiobahn A8000T 800 RMS Mono Amps for sale.
Should I get the Audiobahn A8000T 800 RMS Mono Amp instead of the JBL 75.4 as I need to amp only the Woofer as of now?
More suggestions welcome..
800 RMS would be too much for your sub... since your sub is only 200 RMS.... And since this is a DVC, per voice coil rating would be something like 100RMS....
so 800RMS amp is not recommended....
anToNIcHeN is offline   Reply With Quote
Old 13th December 2006, 19:24   #18
Bass&Trouble's Avatar
Thanked: 71 Times
Wow, and she took the hint?
Old 14th December 2006, 11:25   #19
navin's Avatar
Thanked: 4,282 Times
She asked me what I wanted for a present. So I said wiring kit...
If I said the same to my wife she "wring" my neck. All she does is compain "wires, wires, everywhere" you'd think I married my mom!
Old 20th December 2006, 02:09   #20
Gtea's Avatar
Hehehe
My GF doesn't complain much about me and my car.
But she goes haywire if it comes to ME and my Computer.
BTW
I'm not using the VRS 10 anymore.(maybe next year as a second SUB)
My friend lost his mobile the other day and he needs some cash to get a new one.
So, he is willing to part with his Blaupunkt VRB 10 with a sony 222 (triple 2 - I think) for 6k. I'll be getting the VRB 10 tomorrow.
Will post pics when I have it with me.
Ooohhh I can hardly wait.
Cheers....
Old 20th December 2006, 03:20   #21
Thanked: 21 Times
I had this sub previously on my old 800. 2 of em connected to a 4 way amp of pioneer. really good, i even had velocti component rear and also about 6 inch small subs. (the pad tore after a yr).
These are really good sub. i had the Infinite Baffle set-up done by the bluapunkt shop owner itself. Very well done.
nosfreak is offline   Reply With Quote
Old 20th December 2006, 10:35   #22
Sam Kapasi's Avatar
Thanked: 1,473 Times
It is a good deal yes. But sorry to say this, but the 222 is well a supremely underpowered amplifier and will not drive any subwoofer that well.
Old 20th December 2006, 16:58   #23
Gtea's Avatar
True, True.
But he won't sell the VRB 10 without the Triple 2. (Don't ask me why)
I'm still planning to get the JBL 75.4.
Should I use the Sony 222 to drive the Rear or just leave that to the HU?
BTW, I'm using a Pioneer P1Y HU.
Going now to get my Sub.
Will post pics as soon as I can.
Puia.
Old 20th December 2006, 17:34   #24
hydrashok's Avatar
Wellll... if you're getting it, you might as well use it. :-)
Use it for the rears. Let the 75.4 power the fronts and the sub. Or you can go crazy and use all of the 75.4 to power the sub (in a sealed enclosure) and use the 222 for the fronts. You would get killer bass :-)
And once the novelty wears off, you can use the 75.4 for the fronts and sub, and the 22 for the rears.
Old 21st December 2006, 00:54   #25
blueraven316's Avatar
Hey, I can't understand how can he used the entire 75.4 into a single sub ?
blueraven316 is offline   Reply With Quote
Old 21st December 2006, 11:59   #26
navin's Avatar
the 75.4 can be configured to drive a DVC (Dual Voice Coil) sub. I am not sure if the VRB 10 is a DVC though.
Old 21st December 2006, 12:12   #27
hydrashok's Avatar
I think the sub is a DVC (From the pics posted, we can see two sets of connectors (if you can call them that) on two sides of the magnet for each coil). That's why I said all of the 75.4 could drive it.
It will be overpowering it a tad, though. But in a sealed enclosure, with the gains set safely, there should be no problem.
Old 22nd December 2006, 01:32   #28
Gtea's Avatar
Guys Sorry for the late reply.
Drove around testing the Sub last night.
Anyway here are the PIcs of the VRB 10. (Looks a bit worn but it's still in pretty good shape.)
Sorry for the bad pics. I don't have a digi cam so had to use the Camera on the Cell.
Can anyone enlighten me about wiring the Sub in Series or Parallel?
Thanks,
Puia.
Old 22nd December 2006, 07:38   #29
hydrashok's Avatar
Hey, this is different from the sub you'd shown in the first post. This is a bandpass sub. I think Speedzak had the same thing but with a 12" driver in his Alto. You did mention VRB10 in an earlier post (#23) but I just assumed it was a typo and you meant the VRS10 you mentioned in your first post. :-)
I wouldn't recommend overdriving this sub. You won't get to know whether the sub is being pushed beyond its limits or not, as the actual driver is in the box and its ummm... sounds of protest may not be immediately apparent. Best to use just 2 channels of the GTO 75.4 (bridged) to drive this sub.
Since all you need to do is to connect the speaker cable (from the amp) to the sub-box's input connectors, you don't need to bother about series wiring or parallel wiring.
Old 22nd December 2006, 12:51   #30
Thanked: 17 Times
Rightly said. Don't overpower this sub. Blaupunkt had to stop production of this line up because of many going kaput it seems.
My VXB12 Bandpass is connected to Alpine 605 monoblock. The output level is kept very low at the amplifier. Even then on high volumes and heavy bass, the sub gets very hot. The burning smell can be felt inside the cabin. One of my friends had twice replaced a similar one after it was fried twice.
This sub produces heavy, nice bass. A bit lumpy though. If tuned properly, this can give you satisfying sound. Just don't play it over the limits.
Cheap Monoblock Amp and Sub Enclosure.. sonic_boom In-Car Entertainment 85 15th December 2008 19:32
my 15inch sub's enclosure issue! rider60 In-Car Entertainment 16 30th January 2008 09:12
Help wanted -- Building a Sub Enclosure WasavaTyres In-Car Entertainment 39 18th August 2007 21:51
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Fiberfill for Sub enclosure madbullram In-Car Entertainment 18 5th November 2006 00:50
