Old 13th December 2006, 20:37   #1
adnan's Avatar
Lightbulb Lookin for A Good Upgrade Solution..
Hello guys..
...A very big Hi to all the bhpians out here...i`ve been around here from quite a while..but never posted...My lack of knwledge held me back as i am a complete novice in car audio......
Wel decided to upgrade my setup...Nd so this time with opinions and help from all you Audio Gurus of course...
Here it goes...
The car is a Skoda Octavia rider...and the present setup is as follows:
Head unit-pioneer 6850
FRonts-Blau xl217 165cms 2 way component system
rears-jbl gto937
amp-sony 554z
So right now my requirements are GOOD and CLEAN BASS...not too boomy...And also good Quality music...As i already have a set of components dont i need to upgrade that right???
I had planned using 2 subs for better quality basss...thats only if its required.....my budget is around 20 -25k...So guys WAnt all your suggestions and ideas on improvin the present set up...
Plannin to go to bangy for installin as there arent any good installers out here in my hometown......Maybe auto fusion...Thnks in advance people....
Cheers...
adnan is offline   Reply With Quote
Old 14th December 2006, 00:15   #2
blueraven316's Avatar
Where are you planning to Buy ? if it is Bangalore then you will have loads of options, and you can hear the stuff before you decide because most leading dealers have demo vehicles, for 25k budget you can get a good setup which I suppose is for Amp and sub/subs.
blueraven316 is offline   Reply With Quote
Old 14th December 2006, 01:17   #3
Thanked: 11 Times
adnan,
You can buy Jbl Sub and Jbl Monoblock amp.
There are other options for subs like Pioneer,Illusion,Hertz Etc.
Mugen_Power is offline   Reply With Quote
Old 14th December 2006, 08:48   #4
hydrashok's Avatar
Welcome to Team BHP, adnan!
For an Octavia, you shouldn't consider anything lesser than a 12" sub. Two 10" would be good (for tighter, non-boomy bass), but will break your budget.
Sub suggestion: JBLCS1204B (sub-in-a-box) @ 8K approx OR a Hertz ES300 @ 9k approx + a custom box for 1.5K. [The Hertz option is costlier but I'd recommend the Hertz. I personally liked the Hertz better.]
Amp Suggestion: JBL GTO301.1 monoblock or Audison SRx2 (Not sure of prices. Around 16-17K I guess). You'll also need to spend about 4K on amp wiring & and RCA interconnect cable. Audison wiring would be the best.
I've blown your budget :-) There are lesser amps, but they wouldn't give you the output you'd want in a big car like the Octavia. Alpine & Pioneer may have some options, but I have no idea of prices. Alpine is not likely to aff in your budget, and I personally have a (uhhh... unjustified) not-so-good opinion of Pioneer. A little bit of window shopping with AutoFusion at Koramangala may help you get a better setup. You'll soon get more options from the gurus here.
Old 14th December 2006, 08:53   #5
adnan's Avatar
@blueraven:Wel i had called Anwar when i was in bangy last month but did not meet him cause i was short of time....The problem is th`t i`l be goin to banglore only after mid jan..not before that..
i just want to make my options clear so that i can decide whats the best solution.....
Also wanted all your experiences and opinions with the various Subs and amps that i can get for my budget...
Old 14th December 2006, 11:29   #6
navin's Avatar
Thanked: 4,282 Times
rears-jbl gto937
amp-sony 554z
my budget is around [b]20 -25k[/B..
Q1: how did you fit 6x9 in the rear of a Skoda Octavia?
Q2: How much space are you willing to sacrifice?
I'd consider a custom bass box if I had the space. You could make a 12" (10" internal) deep box that fit against the rear seat as wide as the car wit the woofer firing towards the tail. Hertz, JBL, Infinity, Alpine all make decent woofers. Listen to a few under 10K (leaving the other 10K for the amp and the rest for wires, install and a box).
BTW Arush (autopsyche) fit a 21" (not 12") woofer in one car so there is no upper limit.
Old 14th December 2006, 12:37   #7
adnan's Avatar
Well Navin.....i had a chevy aveo before which had the set up that i mentioned below....just got the new car few days back..So tot i`d upgrade whith some more components..
About the 6x9`s...had seen in one of Anwar`s set up with a custom foldable rear mdf deck...tot i would install it that way.And Space...not such a big concern....By the way..will the GTo75.4 be able to power 2 subs??..I just need a better sounding setup...Any views on how i can improve it??...
Old 14th December 2006, 13:26   #8
The 75.4 can support 2 subs provided the coil is single 4 Ohm upto 250 RMS max, or Dual 2 Ohms coils wired in series to connect to each Dridged output from the Amp.
But, honestly a monoblock is anyday a better option than a 4 channel for subs.
Old 14th December 2006, 13:35   #9
Just like Navin did, I too would suggest you get a sub driver from JBL, Hertz or whichever company and get a custom box made if you want to be sure you want to keep boominess to a minimum.
Vivekphadnis is offline   Reply With Quote
Old 14th December 2006, 14:47   #10
navin's Avatar
adnan, the 75.4 costs about 13K I think the 301.1 also from JBL costs a bit less and will drive a sub even better. There is no need to go overboard.
Option 1.
a) Add a good 250-300W rms monblock amp - cost 10K
b) add a 12" (most common size) in a custom 2-2.5cu. ft box (about 3' wide, 12" deep and 16" high - external dimension) firing towards the tail like mentioned earlier. - cost 10K + 2K more for braced and damped box
c) add a pair of good RCA cable and power cables - 3K
Now if you still want to spend more...
d) damp the trunk
and e) upgrade the 554 to something nicer like the Pio 6200, JBL 60.4, etc...
Option 2.
Get the JBL 75.4 use 2 ch. to drive the front components use the other 2 to drive the sub (it wont drive as well as a 301.1 but it will do) and use the 554 (bridged) to drive the rear.
Old 14th December 2006, 19:15   #11
jkdas's Avatar
Thanked: 1,436 Times
option 2
spend 13k get the 75.4
Navin, teh Cs series amp will cost 10k
Old 14th December 2006, 21:33   #12
adnan's Avatar
Default rockfort fosgate amplifiers.....
hey guys... anybody got any idea about rockfort fosgate power t10001bd...or p8002 amplifier.... weather its available over here and what price...
Old 14th December 2006, 21:59   #13
navin's Avatar
I've heard the P8002. I think it was a direct import and not purchased locally. It was powerful. Since it was driving 2 10" MTX subs subs I could not really tell it's finesse.
Old 14th December 2006, 23:23   #14
The T10001bd is a killer amp, have installed one in my brother's Skoda in Cal, and it is loud as hell and clear.
Bad news is official product here costs about Rs 45000.
Its not available unofficially and even if it is then its about 32k
Old 15th December 2006, 14:04   #15
adnan's Avatar
but at the net the p8002 cost 269.99 $ (12,149 rs)
and t10001bd cost 429.99$(19349 rs) on credit card bassis system... +a small amount of shipment...
lookin for a civic. mustang Shifting gears 3 27th December 2004 12:21
lookin for a 600 cc revtech Shifting gears 22 24th December 2004 01:01
best lookin engine? kokaine The International Automotive Scene 7 19th November 2004 11:19
lookin for a new car plz help libre sito Hatchbacks 11 13th October 2004 01:47
lookin' for a used ford ikon....bangalore powerrage Shifting gears 21 6th July 2004 14:38
