Old 28th December 2006, 00:31   #1
jerish666's Avatar
Default amplifier for alpine speaker...help me .
Hey guys I have 2pairs of alpine SPR-17LS component speakers.Can anyone help me which amplifier i can suit?I want clarity.
Type R Power SPR-17LS Specification
Weight 2.2 kg (one piece)
Power Handling Capacity (Peak) 350W
Power Handling Capacity (RMS) 70W
Mounting Diameter 135.2 mm
Mounting Depth 69.5 mm
Sensitivity 87 dB/W (1m)
Frequency Response 35Hz-30kHz
Impedance (Nominal) 4 ohms
jerish666 is offline   Reply With Quote
Old 28th December 2006, 00:35   #2
Thanked: 21 Times
What Head Unit do you have. And whats your budget for the amp?
Old 28th December 2006, 01:33   #3
jkdas's Avatar
Thanked: 1,436 Times
jerish; once you have made choice do some damping too and get it done at cochin not at cp or motor plaza or sort.
Old 28th December 2006, 08:12   #4
hydrashok's Avatar
Alpine Type Rs are reportedly good speakers. Feed them well. Budget? The speaker sensitivity is 87 dB/W, so a good powerful amp would be in order.
And like JK said, get the damping and install done in Cochin if you can.
Old 28th December 2006, 09:32   #5
jerish666's Avatar
CDA-9830 is the headunit.If it is not recommended for my speakers i can change it.Speakers are definitetly good.I want full clarity of my speakers.So please tell me which amp i can go for.For amp i can go upto 25000/-.
Last edited by jerish666 : 28th December 2006 at 09:48. Reason: to put some more stuffs
Old 28th December 2006, 10:46   #6
hydrashok's Avatar
25K? Look no further than the Audison SRx4. 60w RMS x 4, 24K. (I just bought one).
RCAs, power wiring & install will be extra :-)
-- Use Audison FT2-600 RCAs = Rs.1000/- per set (so 2000/- for you) for best response from the Amp & the speakers.
-- Audison power wiring (FPK300) will run to 3.5K for the 8 guage kit (8 will do for one 4-ch amp).
To finish it all in one go, (and have about 6K left over) get a JBL GTO75.4 (@13k) and do the Audison wiring.
You will need to come to Kochi (Emperor, Palarivattom) for the Audison wiring. If you are coming to Kochi, my setup will be done in 2 days, so you can check-out the amp in action after that. I don't think they (Emperor) have 4ch Audison amps left over after yesterday, so make sure you call them before you plan the trip for the installation (if you are going for the Audison Amp, and are getting it done in Kochi).
alpine 2 channel amplifier and wire guage/properties query? makanaka In-Car Entertainment 18 10th March 2009 13:19
Amplifier rating Vs Speaker rating CaAT In-Car Entertainment 28 31st October 2008 19:32
Running 2.65 Ohms speaker impedence to 4 Ohms Amplifier kiran1103 In-Car Entertainment 13 2nd April 2008 11:30
HU ( CD player), speaker and amplifier is available for 10k nicejits In-Car Entertainment 5 1st October 2007 23:44
FS : Alpine MRP F240, 4 Channel Amplifier (used) s0uljah Shifting gears 1 4th February 2007 00:12
