Old 4th January 2007, 11:41   #1
partypest's Avatar
Question Need some input on reducing rattling noise in the rear due to the oval speakers
hi,
i have a wagon-r fittered with Fusion components, pioneer ovals, JBL Base tube and a sony amp. the base is really good, but at high volumes there is a rattling kinda sound in the trunk, its due to the vibration of trunk lid as the ovals are fitted on them, how do i reduce this sound? really appreciate some adivse on that!!! some one suggested removing the ovals and fitting them on the reater quater glass...is tht good and will sound good???
partypest is offline   Reply With Quote
Old 4th January 2007, 12:38   #2
navin's Avatar
Thanked: 4,286 Times
I would put the rear ovals in boxes or on a MDF rear deck. However if you intend to keep them on the hatch make sure th hatch is well damped and the ovals tightly installed. Over time as you open and close the hatch the Ovals will get loose. If you want a permanant solution to this get a new door panel made for the hatch and attach the ovals with lock nuts on to this new panel.
Some damping in the hatch will also help (not with the rattling but with the BOOM and Buzz when your Ovals are active).
navin is online now   Reply With Quote
Old 4th January 2007, 13:19   #3
partypest's Avatar
ya damping!! how much would that cost me??
Old 4th January 2007, 13:42   #4
hydrashok's Avatar
Damping would run to about 1.5K to 2K max for the hatch-lid/door alone. Like Navin said, speakers installed in an MDF doorpanel on the hatch door and damping in the hatch-door will definitely fix the rattling problem.
If you can, consider putting the speakers in boxes in the boot. The speakers will be placed wider apart and will improve the stereo image that way. But speakers in boxes OR speakers in an MDF panel behind the rear seat will not let you push back or drop the rear seats to the back. (I guess this is why you installed the speakers in the hatch lid?)
Old 5th January 2007, 07:49   #5
thoufique's Avatar
get some double sided tape and start by dampening the number plate.
thoufique is offline   Reply With Quote
Reducing in car noise varadha_r Technical Stuff 35 31st May 2010 17:00
RATTLING sound in car due to audio system... torque.steer In-Car Entertainment 4 9th March 2010 10:14
Reducing the Safari's incabin noise vivek.singh.73 What Car? 10 1st June 2009 23:16
about 4 way pioneer oval speakers sixthsense2k6 In-Car Entertainment 4 26th September 2007 23:31
Hyundai Getz Parcel Tray Rattling Noise arunkumar_rec Technical Stuff 4 24th August 2007 10:41
