Old 10th January 2007, 12:10   #1
desmoquattro's Avatar
Question Audio Noobie
Hi
The new install on my Palio is as under -
Front - JBL GTOs 6 inchers ...or were they 6.5 inchers
Rear - Pioneer 6*9 ovals series 6896 or something similar (these were existing from my earlier cassette unit) and was adviced not to change them
HU - Pioneer 5850MP
Question - Is the above setup good? bad? What can be the additions (later though)
There are some vibes from the left front door because of the GTO.
Suggestions?
desmoquattro is offline   Reply With Quote
Old 10th January 2007, 12:41   #2
Done at "Music Corner" - Pune.
Got to know he's a good friend of Sam !
PS: How do i edit previous posts?
Old 10th January 2007, 14:09   #3
hydrashok's Avatar
Your setup is allright, except for the 6x9s in the back. They will not go well with the GTOs in front. When you can, get component speakers for the front (GTO series) and move the co-axials in the front to the back.
Now,
- What do you want out of your system?
- What kind of music do you listen to?
- Do you plan to add a sub later? (Do you want powerful bass?)
- Or do you want just more power overall in your front & rear speakers?
- Do you mind giving up half your boot for equipment (a sub and amps)?
- How much do you plan to spend on the system, and over what period of time?
- Is this a new Palio? How much longer do you plan to keep the car?
Give us some answers, and we will give you some suggestions and configs. I'm a fellow Palio owner, so you will get special treatment from me :-)
Yes, this is an irritating problem. Happens with nearly all speakers when you push them, and not just the GTOs. The problem comes from the door-panels vibrating with the low notes.
Solution 1: Ugly solution, but the quickest and cheapest: Stick some A/c foam to the back/inside part of the doorpads and screw the door pads onto the door firmly - with screws in all 4 corners and one screw each between the corners. Right now the doorpads are fixed to the door with some push-to-hold tab things. This method does not hold the panels tightly enough.
Solution 2: Costly, but best, if you plan to spend some money on and amps and a sub: Damp the doors. Will run to 2.5K to 3K or so for just the doors.
Solution 3: Really costly and should be done only if you are really serious (in your heart and in your wallet) about ICE: Custom door panels (MDF) (with or without damping). (Now I'll show off my install shamelessly: http://www.team-bhp.com/forum/car-en...or-panels.html heh, heh)
A Noobie International Traveler's first trip - The Land of Smiles, Thailand ninjatalli Travelogues 56 9th October 2012 11:38
Noobie needs Help please, ICE for Fiesta ascertain In-Car Entertainment 30 11th December 2008 19:16
Noobie here Hellblazer Introduce yourself 14 20th May 2008 13:21
