Old 19th January 2007, 17:01   #61
I believe battery indicator in laptops is like fuel meter in cars- they both are meant to serve as a crude estimation (which is quite useful, practically) but not as accurate measurement devices.
santosh.s is offline   Reply With Quote
Old 19th January 2007, 17:24   #62
tsk1979's Avatar
Thanked: 16,421 Times
santosh is right, Li batteries do not suffer from memory effect, therefore reconditioning will just calibrate the meter.
Old 19th January 2007, 17:51   #63
rks
rks's Avatar
The following website confirms what santosh.s and tsk1979 have said:
Getting the most of your batteries
Simple Guidelines
- Avoid full frequent discharges; recharge Li-ion more often. There is no memory to worry about.
- Although memory-free, apply a deliberate full discharge once every 30 days on batteries with fuel gauge to calibrate the battery. If not done, the fuel gauge will become increasingly less accurate.
- Keep the Li-ion battery cool. Never freeze the battery. Avoid a hot car.
- For prolonged storage, keep the battery at 40% charge level.
- Avoid purchasing spare Li-ion batteries for later use. Observe manufacturing date. Do not buy old stock, even if sold at clearance prices.
Although only the "fuel gauge" gets recalibrated by the reconditioning, that is very important because the laptop needs the correct charge capacity readings in order to give the user appropriate warnings and also shut down safely upon reaching a low battery level, etc.
Edit: In the context of a car battery, I wonder if occasional full discharge/recharge will help if the car also has some electronic gauge of the battery capacity (say, in order to trigger off a warning light in the console). I doubt it, though.
Old 19th January 2007, 18:58   #64
rks
rks's Avatar
The answer is negative, as per the following website (and as mentioned in this thread):
Car and Deep Cycle Battery Frequently Asked Questions (FAQ) Section 14
The lead-acid batteries apparently should not be discharged below 20% of their capacity, otherwise their life will be reduced. And they should always be charged fully.
And by the way, it is not advisable to wait till the battery dies before going for a replacement. That could damage some electricals, including the starter.
Old 2nd February 2009, 07:56   #65
akshay4587's Avatar
Thanked: 1,686 Times
Recently due to keys being locked inside.the music system was on at a low volume(basic HU with 4 speakers),it ran for 18 hours,still battery had enough juice to start the car.
PS: I know its an old thread so I am just sharing my experience.
Replacing Existing Battery with a Cummins Shakti Truck Battery? condor Technical Stuff 14 30th June 2018 18:32
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
NANO effect and EURO effect in Small Car market allwheeldrive The Indian Car Scene 8 15th June 2009 22:29
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
Battery consumption due to security system paish Modifications & Accessories 16 20th March 2008 11:42
