Old 4th January 2008, 11:08   #76
Thanked: 294 Times
You can also try a 12 inch sub in a ported box. It will be quite loud and clean also. Also you will get quite many options also.
Old 4th January 2008, 19:20   #77
As said earlier here the installers are somewhat lazy and god knows what they know. I waited for 2 hours and the guy said to come next day as it will take another 4 hours to run the cables in A class. The A class has some unique flooring. So i got bugged up and decided to get the D510 and X374 form India for which I have to wait for 1 month. The installation cost with the cables are 120 pounds which is too much so I decided to invest that once after one month. I am more inclined at taking a sub box which is made by company and not custom made. Company makes available here are Infinity, JBL and some InPhase. The Inphase one is sealed active I guess. There is no port in that. To see it seems it will have 2 sub woofers, when u press one of the cone of sub the other moves proportionately. I need to research on this.
kiran1103 is offline   Reply With Quote
Old 4th January 2008, 22:43   #78
Thanked: 294 Times
Originally Posted by kiran1103 View Post
As said earlier here the installers are somewhat lazy and god knows what they know. I waited for 2 hours and the guy said to com.......e one is sealed active I guess. There is no port in that. To see it seems it will have 2 sub woofers, when u press one of the cone of sub the other moves proportionately. I need to research on this.
I would suggest to for this infinity model. Sam Bhai has this in his verna and I have listened to it also. Mind blowing sound. A must have.
Infinity - Car Audio
Old 5th January 2008, 00:28   #79
ramie2400's Avatar
Thanked: 58 Times
A bit out of topic I recently visited milan subway for doing up the cars number plate,so i thought just go and find the rates of different Boom boxes they sell in wiered whacky shaped and designs.. the funniest part was i came across a box which had a 1"inch hole with a small plastic covering,I asked him whats the rate of this box (Single Woofer) he quoted me 1200/- I said whats so special in this enclosure,he said this is a special designed box for bhass good material and its called "Vinyl Patti Box".. I blasted out in laugh hearing that enclosures name
Old 5th January 2008, 01:17   #80
The available box of Infinity is REF-1200B. The link is placed below
Infinity Reference Box 12" 1200 Watts REF-1200B - REF1200B from Infinity
Please suggest if this model from Infinity is good and suits the D510.
Old 5th January 2008, 01:27   #81
Ahh finally got the one which LBM is referring. The link is
http://caraudiosecurity.com/shop/pro...s_id/7221.html
The model is
Infinity: Reference 1240SE - 12" subwoofer in original box .
Your valuable inputs
Old 5th January 2008, 18:30   #82
Raxx's Avatar
Also in continuation to my earlier post, the JBL GTO 75.4 is available here with B and W for 8000 INR approx. Is it better to take it than getting the Pioneer X374 which I have already. Just trying to reduce the luggage from India. heheh. If its not of much difference, I wont invest it here.
kiran1103: are you sure about the price?? gto 75.4 at 8k with B/W iam looking for this amp please let me know
Raxx is offline   Reply With Quote
Old 5th January 2008, 22:48   #83
RaXX :
Yes, but its available in UK. Check this link.
http://caraudiosecurity.com/shop/pro...s_id/2911.html
With the postage its comes to 94 pounds and currently the GBP to INR is 77, so I can get it for less than 8000 INR.
Not sure if its available in India.
Old 6th January 2008, 00:43   #84
Thanked: 294 Times
RaXX :
That would be without B/W. In india you might get it for 8k with warranty. so it is better to buy from here.
Old 6th January 2008, 01:52   #85
Yeah may be its without B/W.
LBM : Is the Infinity Ref 1240SE the best match for D510.?
Old 16th March 2008, 18:09   #86
Considering that D510 gives out 500 RMS at 2 Ohms, It is worth taking the Infinity Reference 1240SE which is 300 RMS at 4 Ohms. Are there any subs for which I can utilize the maximum out of D510? Pls suggest an company enclosed setups as I am not sure that the installers here know anything abt calculations of colume for a specific sub woofer. Thanks in advance.
sealed or ported.which one for you?? zucchero In-Car Entertainment 55 16th April 2011 09:54
Ideal Enclosure for the JBL W12 GTi MKii? frankmehta In-Car Entertainment 20 3rd April 2010 17:17
Bandpass enclosure for JBL GT4-12 Xmax In-Car Entertainment 29 31st March 2008 15:52
JBL authorised dealers in Bangy? Suvrajit In-Car Entertainment 43 11th July 2007 12:58
