Old 8th May 2007, 22:26   #181
nura's Avatar
Sorry Navin, your explanation went over my head. Can I perhaps request a diagram or two? Also, can you suggest some modifications, which would improve matters?
nura is offline   Reply With Quote
Old 8th May 2007, 23:09   #182
Thanked: 294 Times
which part went above your head sir....it is plain and simple english.....havent you read some high end post by Navin Ji.......
Old 9th May 2007, 10:33   #183
navin's Avatar
Thanked: 4,282 Times
There is not much one can do to the Santro's stock location that will look neat. What one ca do is use the stock location for a 4" coax and get 5-6" woofers in the door. Now in most cases this will require a 4 ch. amp with a crossover (like the Sony 554 which sounds a bit grainy but is cheap). Use 2 ch. for the woofers in the door and 2 for the coax in the dash. set the LPF to about 160-250Hz for the woofers in the door and the HPF to about 120-200Hz fo the coax in the dash.
Old 9th May 2007, 20:59   #184
nura's Avatar
I have (grandiose) plans to get 3-way comps for the front of my Santro. I guess the midrange will go into the stock dashboard location. So if it's defective, would welcome suggestions on modding it.
Old 10th May 2007, 00:51   #185
Thanked: 294 Times
it will be ok if you put the midrange in it...but few back will come out of the dash but I think it will not be a big problem..............
Old 17th July 2007, 15:20   #186
sameer_dg's Avatar
Very informative but womewhat confusing
sameer_dg is offline   Reply With Quote
Old 17th July 2007, 16:56   #187
Thanked: 294 Times
What is confusing you sir. We all are here to help.
Old 18th August 2007, 10:25   #188
navin's Avatar
ran into this link last night. most of what is discussed is pretty basic but it is well worded.
http://www.pispeakers.com/ssdm_99.pdf
Old 18th August 2007, 10:38   #189
Thanked: 294 Times
quite nice Navin Ji..any link from where did you got it..
Old 18th August 2007, 10:47   #190
navin's Avatar
No a friend of mine wanted me to talk to Pi Speakers into building a custom speaker (corner horn) for him. So I looked up the website for their contact details and ran into this. I knew Pi used JBL and Eminence drivers.
BTW the speaker I have envisioned for my friend will include 4 corner horns and 2 horn bass bins. The room is all concrete and 10m x 16m with a sloped ceiling (3-4.5m). It will be used purely for HT. The Audio room will use dipoles and a sophisticated MLTL.
I dont have the time to do designing anymore but I do help friends with concepts and leave the grunt work to others. My payback is that I can listen to the system whenever I visit.
Old 18th August 2007, 11:58   #191
DerAlte's Avatar
Thanked: 2,879 Times
Does your friend have a barn or something? Or maybe a private movie theater? An HT room of 160 sq.m. (1450 sq.ft.)!!!
What's MLTL?
Old 18th August 2007, 14:39   #192
Thanked: 294 Times
Originally Posted by DerAlte View Post
What's MLTL?
Mass-Loaded Transmission Line
FT-1600 MKII
Jordan JX125 and JX150
Old 19th August 2007, 00:03   #193
navin's Avatar
Nope he is an NRI who intends to build a house in Poona. Since it is funded by what he calls easy money (read as stock options) and his kids are all in college he is having a ball. Seperate HT room, seperate audio room, etc..
Old 12th September 2007, 13:29   #194
navin's Avatar
Nice demo on how woofers are made (this is the same proces for all cone loud speakers and very simialr to the process used for domes as well).
Old 12th September 2007, 16:15   #195
DerAlte's Avatar
That's a nice video for knowing the construction of a speaker. Thanks, Navin-ji.
Thanks once again for the trigger - I found what Clip and I were looking for: FG-making information.
Clip-ji, have a look at this
There are more such videos on YouTube. Navin had already talked about the resin stuff. We only have to figure out where to get the preparatory gels and sprays. (You might need permission from your wife to use the electric beater, though )
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Car Glossary needed on Team-Bhp navdeep Technical Stuff 6 8th March 2007 10:05
