Old 28th February 2007, 12:02   #16
mobike008's Avatar
Thanked: 8,319 Times
a) remove the TS20. Dont throw them away yet...
b) add a Pio 6200 amp (7K) - cheapest decent amp for the front components and sub
c) Use the 554 bridged for the rear speakers (JBL 937) turn down the gains to 30% or less. The 554 can drive the 12" sub but it is a bit grainy. It will do fine for the rear. another option is to use the 6200 bridged to drive your fornt components and the 554 for the sub and 937s.
Which is more powerful of the 2 amps? Sony 554 or Pio 6200? Let me state here my understanding, please correct me, if i am wrong
Sony 554: I connect 2 channels of this amp to the rear speakers ( 937) and remaining 2 channels for Front components ( Blaupunkt)
Pio 6200: I power the new sub ( JBL Bass Tube) with 2 channels of this amp and remaining 2 channels use it to power the HU.
Is the above correct?
Old 28th February 2007, 12:06   #17
Sam Kapasi's Avatar
Thanked: 1,473 Times
NO! How can you power the HU? You have to power the speakers.
If they are both 4 channel amplfiers (which is what i gather) then the usage will be the same. I would prefer the pioneer amplifier to power your speakers.
I prefer the sound of the pioneer amps to the sony.
Old 28th February 2007, 12:33   #18
hydrashok's Avatar
I too think the Pio 6200 will be the better sounding amp. So if I were you, I'd use the Pio to power the front comps. (Or the front comps and the rear 6x9s).
Old 28th February 2007, 12:55   #19
esteem_lover's Avatar
Thanked: 451 Times
Pioneer Amp : Power the front & rear speakers
Sony Amp...Power the Sub, right ???
Old 28th February 2007, 13:38   #20
Thanked: 294 Times
the same thing said by sam bhai repeated two times by hydra and esteem..........I could not get the point here....
Old 28th February 2007, 15:21   #21
navin's Avatar
Thanked: 4,286 Times
i'd take the Pio to power the front and the sub (since it is also more pwerful than the sony) and use the sony bridged for the 6x9s.
Old 28th February 2007, 15:44   #22
Thanked: 451 Times
just making it clear, LBM
Wouldn't it be too much for the ovals ??
Old 28th February 2007, 15:47   #23
navin's Avatar
you can reduce the gains on the amp. I think I offered this advice earlier on this thread.
Old 28th February 2007, 16:21   #24
mobike008's Avatar
I understood this now:
Option 1
Sony 554: Bridged to power the rear speakers
Pio 6200: 2 channels for Sub ( JBL Bass tube) and 2 channels for Front Comps
Option 2
Sony 554: Power the sub-woofer
Pio 6200: 2 channels for front comps and 2 channels for rear speakers
Which option to go for, decide
And, what the cost of Pio 6200 is 7K but what is its specs? And, i thought you get a JBL amp for around that much? 65.4 or something? is this better or should i stick to Pio amp?
How much would be the 12" JBL bass tube? 6K? Btw, hope this gets fitted as is and no modifications to the tube. Also, as it may take majority of whatever little boot space i have, it is detachable when required.
Old 28th February 2007, 16:52   #25
Thanked: 294 Times
the 6200 specs...
Old 28th February 2007, 16:57   #26
mobike008's Avatar
@LBM, thanks. I see that 6200 does not have the bass boost option. What difference does its non-existence make apart from not getting the boost to the bass?
Old 28th February 2007, 17:02   #27
Thanked: 294 Times
since i am no using any boost I cannot comment further than that...but I would definetly recommend if you have bass boost on the amp always keep it at zero as it will only add to clipping nothing else....
Old 28th February 2007, 18:33   #28
revtech's Avatar
Thanked: 35 Times
the JBL amps is for 7999 if im not mistaken or something like that.i would get the JBL amp if i were you.(specially if im using it for the speakers)
the 12" JBL bass tube is for 6500/-
dont worry about the tube fitting in your car...i have got a tube iin my zen and yes it will be easily detachable.
not necessary i have my bass boost ON on my blaunpunkt amp which is powering my tube and no clipping what so ever.
revtech is offline   Reply With Quote
Old 28th February 2007, 18:43   #29
Thanked: 294 Times
Sir I said I keep it off and I only recommend it to keep it off....thats all...it is one`s person choice to keep it on or off......but i recommend it off....
majorly people switch it one when the amp is smaller that to drive the sub...so as to achive most from the amp the bass boost is enabled.....
Old 28th February 2007, 18:55   #30
Thanked: 17 Times
I would prefer the bass boost thingy better kept at off position. According to me, There're some very good reasons for that.
Help : Viva crdi or Verna crdi nitindangoria Sedans 15 10th March 2009 22:50
Problems with Accent Viva CRDi goel.honey Modifications & Accessories 16 9th March 2009 08:15
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
Viva Crdi Revvmaster The Indian Car Scene 7 15th June 2004 15:30
