Old 3rd March 2007, 08:37   #1
determinus's Avatar
Default Kicker and SQ?
Does Kicker make any SQ oriented woofer? Most of it applications that I have seen/heard are SPL. Would like to know the "tendancy" of similar drivers, if there is any. (Say, the 05CVR104, 4 ohm DVC)
determinus is offline   Reply With Quote
Old 3rd March 2007, 10:40   #2
Bass&Trouble's Avatar
Thanked: 71 Times
All the new lines of Kicker are inclined towards SPL and display moderate SQ. It works well though, since SPL is a bigger market worldwide than sheer SQ is.
Old 3rd March 2007, 10:46   #3
Thanked: 294 Times
kicker and spl goes together but kicker and SQ does not much...but i think it will be much better than the rest avalable in the market like pioneer and sony....
Old 3rd March 2007, 12:46   #4
blueraven316's Avatar
A kicker SPL sub (Except for the SoloX) if fitted in a compact sealed enclosure can produce some pretty decent SQ, I have seen some people use them is 6.1 setups in cars, but if you a hardcore SQ person, then Kicker is not the way to go.
blueraven316 is offline   Reply With Quote
Old 2nd July 2008, 01:31   #5
pt7
Default Kicker Coaxials?
How is sound quality from Kicker Coaxials? Like LBM mentioned Kicker and SQ does not go hand in hand - is this true for coax also? Even the latest ones?
pt7 is offline   Reply With Quote
Old 2nd July 2008, 02:02   #6
Awaiting Email Confirmation
Man its pretty evident in the name itself. They Kick, they boom. Doesn't matter if they sound that good. :P
nitin.dangayach is offline   Reply With Quote
Old 2nd July 2008, 08:24   #7
nickoo's Avatar
Kicker woofers are not value for money, they are way too expensive for the kind of sound they produce. I personally didnt even find the compos to be termed as good either.
nickoo is offline   Reply With Quote
Old 29th December 2009, 18:51   #8
mithun's Avatar
Thanked: 58 Times
My friend is going to buy a 4" co-ax for Alto.
He is having two 4" options :
1. Kicker
2. JBL GT5
Which one should he go for since both of them are similarly priced@Rs.1300 ?
Old 31st December 2009, 14:47   #9
Dhams's Avatar
Both r good brand. Take audition of both, otherwise GTO/GT-5 JBL, Polk db401 and Blaupunkt GTx/THx have good note in 4"Cox section.
Dhams is offline   Reply With Quote
Old 31st December 2009, 22:43   #10
CaliforniaKnight's Avatar
Thanked: 46 Times
OFF TOPIC:-
How can you differentiate between SPL and SQL from a laymans point of view?
CaliforniaKnight is offline   Reply With Quote
Old 3rd January 2010, 14:54   #11
mithun's Avatar
Thanked: 58 Times
But I've heard that Kicker concentrates more on SPL than on SQ. Is that true ?
Old 3rd January 2010, 16:29   #12
chiragh_bir's Avatar
Thanked: 70 Times
I heard MTX 812 sub and Kicker L5 before buying ...
Kicker is not at all for SQ and is purely made for SPL lover.
Kicker lacks "KICK" but is good for deep bass , but MTX has good kick & goes low as well
Try MTX !!
chiragh_bir is offline   Reply With Quote
Old 3rd January 2010, 22:03   #13
Thanked: 294 Times
That will very much depend on the enclousre it is installed in. Deep bass and the kick !!!!!
Old 4th January 2010, 03:58   #14
Thanked: 11 Times
Originally Posted by CaliforniaKnight View Post
OFF TOPIC:-
well to be honest everywhere else SPL is just when you have a system that is a one note wonder that will burp frequencies in competitons and is designed and tuned to only play at the vehicles resonant frequency which actually adds around 10 db's more to your SPL numbers
whereas what you are terming an SQL setup would be called a ground pounder elsewhere because even though it has loud bass it wont be able to pull off huge SPL numbers. In fact some cars that pound so loud that it turns your stomach actually will give you very low SPL numbers because the system is not tuned toward playing only the specific frequencies that will make the vehicle resonate hence create the extra energy at the required frequency to give a large amount of sound pressure
In South Africa thats how they differentiate and here we have guys who specialise in using computer modelling programs to design and tune their enclosures to give huge SPL numbers - in fact there were many SPL world records set here - only thing is those are reset each year. As an example the highest SPL number recorded here in SA is 179.9db and there are certain rookie cars that are actually approaching 150db legally ie with ports that are legal and no modifications to the vehicle ... note that these numbers were done with calibrated audiocontrol meters as per IASCA rules (has to be calibrated for world record runs) and we have around 4 or 5 events per year where records can be set hence are judged with the calibrated meters
naughty001 is offline   Reply With Quote
Old 4th January 2010, 17:32   #15
mithun's Avatar
Thanked: 58 Times
OK, that applies to sub only. But, what about the speakers ?
Which amp for Kicker L5,2 choices Rockford Fosgate PRIME R500-1 or Kicker ZX 500.1 abishek2222 In-Car Entertainment 4 27th January 2010 00:49
My new Swift with Pioneer HU, front JBL and Kicker ovals paranoidAndroid In-Car Entertainment 45 8th July 2008 17:10
Need help between JL Audio and Kicker amit_sound In-Car Entertainment 70 27th September 2007 16:09
Kicker AMP with MB Quart Comp and Audiobahn madbullram In-Car Entertainment 15 20th August 2007 01:31
Wanted - Kicker Solobaric and Monoblock Amp karthik247 Shifting gears 0 27th June 2006 21:07
