Old 11th April 2007, 12:16   #46
shuvd's Avatar
Gurus and guys, I've been offered the 7950UB for 15.5k with B&W in Calcutta. The dealer says he'll bundle in a CD-IU50 free with it. Is it a good deal?
shuvd is offline   Reply With Quote
Old 21st April 2007, 11:14   #47
razor4077's Avatar
Thanked: 258 Times
@shuvd: u got that quote at glix? i'm interested in getting one fitted too...
and to verify, the usb cable that comes with the ipod doesn't work in the 7950? is the CD-IU50 the only way out?
@somebodystopme: did u manage to get the OE ipod cable to work on your unit?
razor4077 is offline   Reply With Quote
Old 22nd April 2007, 13:06   #48
somebodystopme's Avatar
Thanked: 17 Times
NA.. Was too lazy to connect the cable again after 1st try. I am happily running CD on it and will buy a Pendrive soon. If you want for your satisfaction i can try again with IPOD cable.
But i dont really know if problem is regarding IPOD cable or Ipod model.
Mine is second generation ipod nano. I guess this HU will work perfectly with 1st generation IPODnano the one in black and white.
Which one is yours?
somebodystopme is offline   Reply With Quote
Old 22nd April 2007, 14:44   #49
Thanked: 294 Times
guys check with the pioneer cable I think it will work with it only.....not with the cable which comes with the IPOD......
and the genration does not change the dock connector ....it is the same since a long time......
Old 22nd April 2007, 14:59   #50
razor4077's Avatar
Thanked: 258 Times
Which one is yours?
Mine is a 1st generation nano. guess i'll carry it with me to the shop if & when i buy the unit. but yea, would be great if u could give the OE nano cable another shot.
how's the system overall? u happy with it? what's the rest of your ICE comprised of? pics pls
EDIT: @lbm: thanks for the info dude
Old 3rd May 2007, 00:40   #51
austere_sly's Avatar
Thanked: 9 Times
Doest these players of pioneer which are USB compatible can play music from portable HDD. I don't know how much power can an HU provide to HDD. but was just curious if it might be working. I have this Seagate portable HDD which works by connecting it to computer through USB.
austere_sly is offline   Reply With Quote
Old 3rd May 2007, 11:40   #52
abhi182's Avatar
Thanked: 202 Times
Lbm this is the same cable I am talking about. though I dont have the pioneer one. I got one with IPOD itself. But I guess both of them function in the same way.
I got this HU for 10K Without B&W
I know the cable is same but you can try the pioneer cable it might be a bit different.....
^^ it has to be different...
The USB port on the Pioneer would expect a normal folder structure on the storage device it is connected to... (e.g. root\pearl_jam\one.mp3)
The ipod however does not follow the regular storage pattern...it creates separate metadata files for navigation , renames the files and stashs them away in a hidden folder called data on the ipod hdd
when you connect the regular USB cable, your HU would expect a regular directory structure....
I am not sure how this cable is any different from the ipod regular USB cable, but for the reason above, it has to be
abhi182 is offline   Reply With Quote
Old 30th May 2007, 14:46   #53
amitoj's Avatar
Thanked: 1,691 Times
Hi Gurus
I got this Pio 6950UB HU thingy some time back. Couple of questions:
1. It does not remember the settings. Very frustrating this can be. Not even the FM channels stored in the so-called presets. Is this a setup problem?
2. I have a sony mp3 player as well. When i plug it into the usb cable, it does not get recognised. Any idea why?
Amitoj
PS: scrolling through the music in the ipod via this HU is very cumbersome.
amitoj is offline   Reply With Quote
Old 30th May 2007, 16:03   #54
amitoj's Avatar
oops... its a 7950UB HU. Sorry about that...
Old 30th May 2007, 16:09   #55
Thanked: 294 Times
I think the 7950UB has the software to recognize the IPOD interface as the model supports it when connected directly....so I think there will be no problem in that....
Old 11th December 2007, 17:57   #56
dilipkumar7278's Avatar
Thanked: 26 Times
Default Pioneer AVH-P 5750 DVD
Hi
Gurus,Please tell me how can I connect the above system with ipod? I dont want to buy the pioneer adaptor as it is expensive.Is there any other way? Is it available in cochin//
dilip kumar
dilipkumar7278 is online now   Reply With Quote
Old 11th December 2007, 18:54   #57
Thanked: 17 Times
If you don't want to buy the pioneer adapter, then you should go for an aux in connection.
Buy a 3.5 to RCA cable and connect your iPod to the aux in of your HU. Turn on aux in the HU system settings and play your iPod. The sound will come out from the speakers. You'll have to manually control your iPod and keep an eye on it's battery level. It won't be charged as if connected thru the adapter.
Old 11th December 2007, 19:20   #58
Jaggu's Avatar
Thanked: 8,686 Times
Originally Posted by amitoj View Post
Hi Gurus
If you havent sorted it out yet, check the wiring of the HU, there are 2 positives (red and yellow), Red (if i remember correct, check!!) has to be connected direct to the battery (always ON) and second via ignition switch.
Old 12th January 2008, 00:13   #59
kjdesigns_2000's Avatar
can someone please post a few pictures of different spectrum analyzers from 7950 or 6950. I have my mind set on both of these two but i want the dancing lights up and down for sure. anyone ?
kjdesigns_2000 is offline   Reply With Quote
Old 12th January 2008, 00:15   #60
Thanked: 13 Times
Pictures wont do justice. I suggest you take a demo at the installer itself.
Pioneer Head Unit Errors. Error 11 and error 17 in pioneer MP3 rajivanoj In-Car Entertainment 33 8th March 2018 12:58
Specs Req Pioneer 2950 and Pioneer 4950 HU nicejits In-Car Entertainment 3 23rd November 2007 12:03
For Sale: Pioneer FH-P 6200 2 Din and Pioneer EQ 6500 Equalizer . sam_78 Shifting gears 4 28th April 2007 12:16
How come Pioneer is still using 16 bit DACs on HU's below 7 series raul In-Car Entertainment 9 5th May 2006 15:32
Pioneer come to India via Autocop Sahil Modifications & Accessories 5 2nd April 2006 02:52
