Old 30th April 2007, 10:23   #46
navin's Avatar
Thanked: 4,286 Times
why the EQ should be zilch? just a question
when it comes to audio less is often more. In mast cases where EQ is used it is abused. so my generic recomendation is no EQ.
Old 30th April 2007, 11:05   #47
Thanked: 294 Times
Normal the boat shape pattern is the most popular among people....
Old 30th April 2007, 11:16   #48
mobike008's Avatar
Thanked: 8,319 Times
How do you define this? can you list the typical values of the range from low to high frequency?
Old 30th April 2007, 15:53   #49
Dhar's's Avatar
Thanked: 163 Times
Has any one tried Infinity Basslink II? Is it available in India? It's 250W RMS and has a frequency range of 20-100hz.
Dhar's is offline   Reply With Quote
Old 30th April 2007, 16:55   #50
Thanked: 294 Times
that would be the low and highs at the max and the mids at the lowest.....
Old 30th April 2007, 17:12   #51
iraghava's Avatar
Thanked: 156 Times
Check with fellow member RedOne. He's using one is his Land Cruiser.
Old 30th April 2007, 17:53   #52
hydrashok's Avatar
As Ishan mentioned, RedOne has one I think he bought it from Driven in Delhi.
The BassLink II is not officially available in India from Harman Intnl/JBL.
Unless you want to avoid a sub + amp combo (and some wiring) like the plague, a separate sub & amp would work out to be more VFM. The BassLinkII runs to about 18K, if I'm not mistaken.
BTW, which car are you planning it for?
Old 1st May 2007, 10:25   #53
Dhar's's Avatar
Thanked: 163 Times
Hi Hydra and Raghav,
I'll check out with RedOne.
Im planning for my little Maruti Alto. I think its space saving compared to sub boxes and tubes without much compromise on the bass. I had been looking for reviews in web. Where Basslink I had good reviews, the Basslink II has mixed reviews of blown off sub etc.
Old 10th March 2009, 19:15   #54
ajithbc's Avatar
Thanked: 9 Times
Hello Guru's,
I have an Alpine head unit and two componet alpine speakers on front with two alpine tweeters. The rear speakers are blaupunt 6" standard fitting from the company. Quality wise i m happy with the sound i need to add sub woofer to the set up. I m not in to loud music. i listen to the classic rock mainly and i would like to get some good bass. I have a sony explode 4 channel 600 watts amp with me. Shall I use it and power a 10" jbl subwoofer fixed on an enclousure. or do u guys think of a value for money good set up for my car with a new amp and sub? The car is a skoda.
ajithbc is offline   Reply With Quote
Old 10th March 2009, 19:35   #55
greenhorn's Avatar
Thanked: 1,519 Times
a 10" sub would be inadequate for your car. I'd suggest a 12" ported sub. an amp upgrade would also help, since a sony amp would be the weak link (sound quality wise) since your HU and speakers are alpine. Which is the sony amp's model no ?
Old 11th March 2009, 12:34   #56
ajithbc's Avatar
Thanked: 9 Times
thanks green horn, forget the sony pls suggest a amp and subwoofer set which will give me a quality bass on the existing set up. Or is it ok to go with an active subwoofer tube? Does it give sustantial sound improvement on amplifing the front components aswell?
Tubes on a tubeless tyre?? aggressive_anush Tyre & Alloy wheel Section 21 18th July 2011 15:09
Help on Bass Tubes for Swift Zxi Swiftron In-Car Entertainment 26 17th June 2008 23:39
Some Good Low Bass Songs I've heard! headers In-Car Entertainment 16 20th March 2008 15:17
not getting good bass effect trivedishivam In-Car Entertainment 3 2nd December 2007 00:18
Don't tubes have speed ratings??? Shan2nu Tyre & Alloy wheel Section 18 9th July 2004 23:18
