Old 8th April 2007, 02:40   #1
Thanked: 21 Times
Smile Autopsyche's Mitsubishi 3000GT ICE...
Hey Guys
For all those in the know, Arush finally ICE'd his baby... (For the others, linky linky) And though we don't post installs here anymore, here is a small SQ install you may like. Enjoy!
The Story Begins...
The car came with this Pioneer Double DIN HU
Stock tweeter location, up on the dash
Stock Tweeter removed...
Stock Tweeter close up
Now onto the doors...
stock midbass location
Door panel removed, a pioneer coax was installed in the stock location by the earlier owner
Inner side of the door panel
The Boot of the car with space saver wheel and utility pockets in place
Utility pocket removed. Why? Read on...
Stock 6x9 location behind front seats
Again, Pioneer ovals installed by earlier owner
Car being stripped of almost entire interior
Boot Stripped
Work starts on sub enclosure, which will be where the utility pocket was on the floor. Note masking work on interior plastic panels.
Fiberglass work progresses
Rough edges eliminated
Sub ring being made
Contd...
Old 8th April 2007, 02:44   #2
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Its been a long time coming .. Gunman , expecting a good install as always .. Glad to know that you guys are visiting this side of the forum more often these days .. Arush , what next ??
Old 8th April 2007, 02:44   #3
Thanked: 21 Times
Smile Autopsyche's Mitsubishi 3000GT ICE... contd
Contd from post #1
Ring test fitted on enclosure
Fiberglass work proceeds...
Enclosure test fitting
Autophile (JB) doing the all important volume and sealing test of the enclosure
Mr Fancy Schmancy coat himself, Mukul Patel of Patel Auto
A layer of FonoGel used for the enclosure's internal sealing
More stripping
And then begins the damping of the car and boy did we damp it
They even damped the fuel pump cover
Wondering whats going in?
Fronts: HERTZ HSK Custom 3way with Dome Midrange
Sub: HERTZ HX250 10" sub
Contd...
Old 8th April 2007, 02:46   #4
Thanked: 21 Times
Contd from post #3
The sub enclosure again, now carpeted
AZcomp AT25G terminal cup used for connections at the rear of the enclosure
test fitted again
Internal cabling for sub enclosure
cable from amp plugs in into rear of enclosure, like so
while internal cable plugs into sub like so
Final test fit of enclosure
Cables going in...
Connection Audison Reference SONUS ST interconnects used
Cables laid
And now back to the doors... umm... where the hell are the doors...
Yes, we removed the doors, why? cuz we can... heh heh, read on...
As you can see, the inner skin of the door has been damped
The doors were removed as there was no acceptable provision for routing the 12ga speaker cable into the door. Of course, we could always use the stock connector but that would involve cutting and splicing a cable that was already butchered by earlier installers (cough cough: hacks). The solution, we made a new hole...
Contd...
Old 8th April 2007, 02:50   #5
Thanked: 21 Times
Default Autopsyche's Mitsubishi 3000GT ICE... contd
contd from post #4
Of course the hole was sealed with a grommet.
Where do you find such a grommet you ask, your friendly neighborhood workshop... or in this case...
Stock door cabling gets a new conduit
Doors get more damping
Close up of custom MDF ring installed on door
AZcomp FonoPol 1000 also used for damping
Panels finally go back on the doors once doors finally go back on the car
close up of custom ring installed
Cosmetic ring, finished with AZcomp vinyl
cosmetic ring installed
HERTZ HV165L high output 6.5" woofer going in
And the doors are GO! seen here with grill
Remember the rear stock 6x9 locations... we made new cosmetic rings for them, seen here with and without AZcomp vinyl
test fitted onto panel
And used as a crossover mount location
Contd...
Old 8th April 2007, 02:52   #6
Thanked: 21 Times
contd from post #5
Back to electricals, stuff used for connections
Grounding point ready and grounding terminal installed
Earlier battery and connections
Battery Terminals changed
Car Battery to Ground cable upgraded
Battery replaced with Optima Yellow Top
Also note battery to car chassis ground installed
Waterproof fuseholder
Now to the HU, an Alpine 9857 with the full speed iPod cable
Alpine full speed iPod cable comes into glove compartment and HU installed. See the round black thingy in front of the HU, thats the controller for the bluetooth handsfree kit
and the kit's brain sits snug behind the HU
while the mic goes on the top of the A pillar and the little display onto the center of the dash, affixed to the windshield.
Now for the handsfree kit's dedicated speaker... we removed the ashtray.
Contd
Old 8th April 2007, 02:59   #7
Thanked: 294 Times
nice install waiting to get it finished.....nice work gunbir phaji....
Old 8th April 2007, 03:01   #8
Thanked: 21 Times
contd from post #7
So we removed the ashtray and used the location to house the Bluetooth kit's speaker.
Of course we also fabricated a custom grill for this, covered with AZcomp speaker grill cloth
Now that things are beginning to look good, its time we go back to audio
Dome midrange and tweeter installed.
Audison LRx4.1K amp
Amp Installed, note trim plate on top with concealed neon lighting and plexiglass
More concealed lighting...
Boot top cover (fabricated from MDF) installed
Sub close up, note gap in floor board in front of sub
Sub gets cool ambient lighting effect
System power up time
HU checked, iPod interface checked
And she's done...
End result: As desired, a light yet powerful SQ setup that can sing as well as kick. All this with almost no loss in boot space or functionality. And the sound is very involving and enjoyable, especially the vocals and midbass. The sub integrates like crazy. FYI, The fronts get 130w per side and the sub gets 500w off the other 2 bridged channels. There is no EQ, XO or TA used on the HU.
The Bluetooth kit adds a new dimension of convenience, enables safe driving and works very well. Recommended for anyone who spends a lot of time on the road talking on the phone.
Do post any questions you have re the install and we will be glad to answer...
Old 8th April 2007, 03:06   #9
manikjeet's Avatar
Thanked: 110 Times
Wooo nice install makes me feel weak in the knees
and what was the total cost and the time taken
manikjeet is offline   Reply With Quote
Old 8th April 2007, 03:07   #10
Thanked: 21 Times
Phew!!!
Doing the install was easier than uploading and posting pics.
Its finished veerey. Drop by at Arush's sometime and hear it. I also look forward to seeing your new setup sometime soon.
Old 8th April 2007, 03:19   #11
Thanked: 294 Times
Originally Posted by gunbir View Post
Phew!!!
Ya i can see that lots of photo`s and so much details....nice work sir.....Hats off to you.....I am impressed....
Ya still waiting for the subs to arrive on the 14th...and a day or two to finish the work.....then maybe on the next meat we can audition both the setups.......if ishan take some care this time....
Old 8th April 2007, 11:24   #12
hydrashok's Avatar
This has gotta be the most detailed install-pics thread. Beyooootiful work. Your mouse finger must be real sore from all that uploading
As always, great install! And as always, I'm pissed there's no way I'll be able to listen to the car :(
Congrats on the setup, Arush! Enjoyyyyy!
Old 8th April 2007, 11:37   #13
aZa
aZa's Avatar
Thanked: 17 Times
aaah finally !! have been hearing about the install since ages great work as usual gunnu and jb!!
time for a demo and a test drive wot say arush heheh
Old 8th April 2007, 11:49   #14
faithless_1984's Avatar
Thanked: 217 Times
awesome install.!
looking forward to a demo.
ishan bhai is busy arranging bombay/mumbai meets
faithless_1984 is offline   Reply With Quote
Old 8th April 2007, 14:18   #15
Thanked: 13 Times
Finally the Ice has been added to the Spice
Nice work as usual guys. I especially liked what you did with the custom enclosure for the subbie.
Pics : Mitsubishi GTO / 3000GT / Stealths in India v12 Super-Cars & Imports in India 153 19th January 2018 17:38
My Quest to Build the Ultimate 2nd gen Mitsubishi 3000GT (& Hello from the USA) Markingtime The International Automotive Scene 6 4th May 2013 16:37
Project Autopsyche Mitsubishi 3000GT autopsyche Modifications & Accessories 388 27th December 2008 20:29
1993 Mitsubishi 3000GT VR4 - 400bhp Monster! autopsyche Super-Cars & Imports in India 65 23rd October 2007 05:13
1996 Mitsubishi 3000GT SR autopsyche Modifications & Accessories 77 11th September 2007 22:02
