Old 9th April 2007, 15:32   #1
blueraven316's Avatar
Thumbs up JBL Setup in a Skoda
This was a rather simple setup built by Anwar few days ago,
Setup comprises of 2 sets of 607 JBL Component Speakers.
1 of JBLCS60.4 4 Channel Amplifier
1 of JBLCS300.1 Mono amplifier
1 of JBL 1000 Watt 12" Subwoofer
Setup is tuned for purely for SQ, along with the rear compos and woofer loaded in a Sealed Fiberglass enclosure.
Below are the pics:
Rear component Speakers mounted in a custom Fiberglass Pod generates some really clean mids.
Amplifiers mounted in the boot.
The Owner of the car wanted to retain the Original Plank and not cut any holes in it.
Anwar Said " Thata Astu "
There is hardly half a cm gap between the plank and the rear speaker when the plank goes up with the boot.
blueraven316 is offline   Reply With Quote
Old 9th April 2007, 15:43   #2
hydrashok's Avatar
Really nice, clean setup. Exceptional work. It looks really stock. Not almost stock but really stock. The fronts must be in the stock locations, right?
Anwar is an artist. No doubt about it.
Old 9th April 2007, 16:15   #3
rishibravo's Avatar
Really cool setup... This is the stuff which has made me addicted to team-bhp .
rishibravo is offline   Reply With Quote
Old 9th April 2007, 16:25   #4
moralfibre's Avatar
Thanked: 6,532 Times
Nice install there. What headunit is used?
Old 9th April 2007, 16:34   #5
nikkibike's Avatar
Default Wow!!!
Thatz "P R O F E S S I O N A L I S M" !! Splendid job!!
and.... HOW DOES IT SOUNDS??!! more info please!
nikkibike is offline   Reply With Quote
Old 9th April 2007, 16:43   #6
navin's Avatar
Thanked: 4,282 Times
The install is clean and I may be nit picking here but given that my icar is also an Octy....
a) I would have installed the sub on the left wall and the amps on the right. The left wall does not contain the fuel tank and hence one would ahve room to build a bigger box without protruding into the central trunk space.
b) I would have used custom grills on the rear components. The stock grills, in my view, do not mate well with the stock interiors of the Octy.
I understand the limitaions of the rear tweeter install but cant help worrying about the smear in the HF after it bounces of the rear glass. Maybe the 507c would have been a easier fit.
Lastly a grill for the 12" woofer is also in order.
Old 9th April 2007, 16:56   #7
Thanked: 294 Times
very nice install.......good work can now be seen in india also.....
Old 9th April 2007, 17:38   #8
revtech's Avatar
Thanked: 35 Times
great install...really well done. simple but looks great.
revtech is offline   Reply With Quote
Old 9th April 2007, 18:16   #9
Bass&Trouble's Avatar
Thanked: 71 Times
That enclosure volume appears way too small. For a space like that, a 10" would have been more appropriate, in my opinion.
Old 9th April 2007, 18:51   #10
hydrashok's Avatar
I did wonder about that. The GT4-12 needs 1 cu. ft. and that enclosure doesn't look to be that much.
Old 9th April 2007, 19:05   #11
Ricky_63's Avatar
Thanked: 394 Times
Surely one of the best installs that I have seen. I too have a Octavia with a (I think decent system), but after seeing the meticulous install I might want to hide mine from prying eyes.....
Pardon my ignorance, but what would it cost in terms of labour & customization cost i.e without the cost of the equipment ?
Old 9th April 2007, 21:23   #12
jkdas's Avatar
Thanked: 1,436 Times
very neat
12 inches would have been better but then its upto one's taste. still for a skoda
and woofer is naked! give it some protection
Old 9th April 2007, 22:13   #13
Thanked: 294 Times
I think JK it is a 12 incher....not a 10 inch or smaller one....sometimes I think you are in a hurry to post and forget to read the complete thread....
Old 9th April 2007, 23:20   #14
esteem_lover's Avatar
Thanked: 451 Times
@navin, you are right. Those tweeters are facing the glass & not the cabin.
@blueraven316, How does it sound? & is one sub enough for this car ?
Old 10th April 2007, 00:45   #15
Quite surprisingly the volume is actually 1 Cu Ft, I had seen the enclosure once while it was being built.
The owner wanted less irritation as the tweeters like most entry level component speakers produces pretty sharp treble, and moreover the speakers a mounted barely 6 inches away from the back seat passenger's ear, hence the mounting, though I have not sat on the backseat so cant tell how effective the positioning was.
Overall the system sounds quite fab, as it has been paired with some good packing and damping job by Anwar.
JBL GTO Vs JBL GT5 Amps. rider60 In-Car Entertainment 9 30th May 2011 13:35
JBL 1004 vs JBL PX300.4 vs GZ TA 4.120MK2 vs Infinity 475A St. Anger In-Car Entertainment 12 13th August 2009 15:26
JBL 607C or JBL 660C? ultimatechamp In-Car Entertainment 33 18th July 2008 19:13
For Sale - JBL 2ch Amp and JBL 12" Basstube karthik247 Shifting gears 5 3rd December 2007 17:44
