Old 21st November 2007, 09:29   #31
shuvd's Avatar
Exclamation
Sorry to bother you guys again. Was waiting for the new GT5 range in Calcutta. But, my ICE money is running out and I need to get the install done today.
From the inputs given above, I have two options.
1. Get a mono block 300.1/equivalent or 7300. And a DVC sub.
2. A 2channel amp and a SVC sub (GTO 1204BR/equivalent).
Queries: Is a DVC sub available from JBL? What other options do I have from Kicker/Pio? (Other brands are not available in my range)
If I get a SVC (GTO 1204BR), what kind of amplification should I look at? Please suggest some models from JBL/Pio/Kicker.
shuvd is offline   Reply With Quote
Old 21st November 2007, 11:57   #32
rocksterraghu's Avatar
Thanked: 97 Times
shuv, why a DVC in particular? Why not a good monoblock like 301.1 and a sub in a sealed enclosure? 1204BR would not produce the tight bass of a sealed enclosure IMO.
Old 21st November 2007, 13:04   #33
shuvd's Avatar
DVC so that I could drive it off a Mono block. Gurus are suggesting not to get a mono block for a SVC. Does JBL have a sealed enclosure setup?
Old 21st November 2007, 13:15   #34
Thanked: 97 Times
I think B&T or Navin will clarify that, since they're the gurus.
JBL has a sub with sealed enclosure - CS1204B which comes with GT4-12. I am using the same with a monoblock 300.1 and it works wonders for me.
Old 21st November 2007, 13:27   #35
shuvd's Avatar
Thanks for the reply! Its so confusing for me. BTW, how much did the CS1204B cost?
Old 21st November 2007, 13:41   #36
Bass&Trouble's Avatar
Thanked: 71 Times
Ahem, loveguru? You certainly dialled the right number, baby!
Monos that are rated for max output at 2 ohms or 1 ohm are not putting out full rated power at 4 ohms (exception of some monos like the Alpines/ JLs etc). So you're buying an amp and paying the price for more power while extracting lesser from it. Better to go for a 2 channel amp (or use two channels of a 4-channel amp) in bridged mode to get the required power and optimize the spend on the amp. No?
Woofer lagaya toh mono lagana hi padega?
...Naah!
Old 21st November 2007, 13:50   #37
shuvd's Avatar
Okay then! Should I go for a 2 channel amp or THE 75.4 and a sealed box sub? Could add another sub at a later stage, budget permitting!
Old 21st November 2007, 16:35   #38
navin's Avatar
Thanked: 4,284 Times
A SVC can also be run of a monoblock.
the CS 1204B and 300.1 ere made for each other.
but the amp runs cooler.
Old 23rd August 2008, 18:29   #39
nura's Avatar
Originally Posted by DerAlte View Post
I think yes, if you have a DUAL-COIL sub, you could bridge the 4ch amp to get 2 bridged channels, each of which can drive once coil.
This sounds great to me. I have a DVC sub & am thinking of getting an amp for it. The Pioneer PRS-4100F is a 4-channel amp. When bridged, it puts out 300W x 2. It is available locally & doesn't cost the earth.
Now here's the catch. The AZ Audiocomp binding cup on the sub box has just 2 connectors on it. Is there any way of fitting another 2 connectors on it?
My sincere thanks in advance for your suggestions.
nura
nura is offline   Reply With Quote
Old 23rd August 2008, 18:43   #40
Thanked: 71 Times
The 4ch amp will not drive a 2 ohm load off its bridged output.
Old 23rd August 2008, 23:45   #41
nura's Avatar
Oops! Alzheimer's strikes. I guess I'll have to settle for this then Kenwood - KAC-9104D
Facelifted Octy, Cheaper Laura EDIT : Laura Elegance ajmat The Indian Car Scene 139 27th August 2007 10:47
Just witnessed a OCTY crashin into a Biker. aZa Street Experiences 11 11th September 2006 17:35
New Skoda Octy for India??? DRC The Indian Car Scene 9 13th September 2005 21:29
Help - Octy RS air bag, EPC, ABS, etc.... navin Technical Stuff 12 4th August 2005 18:26
