Old 17th April 2007, 14:31   #1
rishibravo's Avatar
Question Palio ICE help needed.
Guys I am a big zero when it comes to ICE. Right now my car has a very average ICE setup. I have a JVC KD-G413 Head unit (bought it because it was the cheapest option which comes with an aux input to connect my ipod), A 2 channel JVC KS-AX3300 amplifier (Dont ask why) , a set of 6x9 JVC co-axials and some crappy kenwood (probably fake) speakers in the front.
My budget is around 40K. Please suggest what I should go for.
I listen to varied kind of music. From Daler bhai to Pearl Jam... From Himesh to 50 Cents... Dont want too much boom boom...just good quality music. I drive more than 50Kms a day and roughly spend 2 hrs a day in my car.
Moreover i am too confused about whether to spend a fortune on a good amp or not? Another confusion is : JBL or Hertz? So I want to leave everything to the Gurus...Please Help
Can someone tell me if I should keep the current head unit or should I go for a pio.
rishibravo is offline   Reply With Quote
Old 17th April 2007, 15:38   #2
hydrashok's Avatar
40K is a good enough budget.
I couldn't make out how many pre-outs the HU has. If it has two, good. If only one (most likely), you should consider changing the HU for a Pio 4950 or something like that. I don't know how the JVC sounds so I can't comment based on that.
Between Hertz & JBL, it would be a good idea to listen for yourself and decide
Fronts (6.5" comps in stock pods): HERTZ DSK165 or JBL GTO607c (approx 6.5K)
Rears (5.25" coaxes in stock speaker pods): HERTZ DCX130 or JBL GTO527 (approx 4K)
Sub (12" sub): JBL GT4-12 12" sub in a custom-built ported box in boot (5K + 1.5K = 6.5K)
Amp : Your existing amp should do an almost decent job with the sub in bridged mode. Depending on the webpage it puts out 280w or 320w max. If it is not enough (try it with the sub), get a Pio 6200 (8K) or JBL CS60.4 (9K) Power the rears off the existing JVC amp.
Power and RCA wires: Stinger/Twister/Other good brand (approx 3K)
Damping: About 3-4K max (you don't need a lot for a Palio).
TOTAL: About 32K (if you buy a new amp also -- recommended since you have the budget. Else 24K).
If you add a HU (switch to Pio 4950) add 6K to make the total 38K.
If you want to max-out your budget (and a bit more), get a JBL GTO 75.4 amp instead of the ones I mentioned above (13K). I'd recommend this.
You'll probably get a maximum of 3K or so for the existing stuff (including the 2-ch amp) you have in the car if you sell it/exchange it, so you can take that off the total.
Old 17th April 2007, 16:12   #3
rishibravo's Avatar
Thanks Hydrashock... you have given me so many options within my budget..
Old 17th April 2007, 16:16   #4
esteem_lover's Avatar
Thanked: 451 Times
We are confused & excited now, are we ?
Exactly why we have hydra here. Most enthu ICEr in Team-BHP.
Old 17th April 2007, 16:21   #5
hydrashok's Avatar
I actually googled the amp and got different specs on different webpages. But yes, still on cloud nine.
Old 17th April 2007, 16:31   #6
Bass&Trouble's Avatar
Thanked: 71 Times
You're in New Delhi. That makes both Hertz and JBL accessible to you. Go and listen to both and decide.
Old 17th April 2007, 16:38   #7
rishibravo's Avatar
Went to Driven the other day...Listened to Hertz...I was awestruck considering what I was used to listening in my car. But I still want to listen to JBL before deciding as it is gonna cost me a lot (as per my pocket ..he he).
As per the JVC site KS-AX3300 gives 320W max.
Old 17th April 2007, 17:21   #8
Sam Kapasi's Avatar
Thanked: 1,473 Times
Now that is correct advice. No one brand is better than another. let your ears decide for you. Luckily you have access to both products.
Old 18th April 2007, 10:34   #9
navin's Avatar
Thanked: 4,286 Times
Actually I am starting to be more sure in my earlier theory
"Our ears are very good if only we know what to listen for".
In keeping with that theory I would suggest that you listen to a few brands that are a bit more refined (albeit more expensive). Infinity, Alpine (R/S), Hertz Hi Energy, Blau Velocity, Boston, etc.. why you should even try to hear Focal, DLS (LBM is in your area), etc...once you listen you will know what to look for, what is missing, and what are the various strengths and weaknesses of your (proposed) system.
navin is online now   Reply With Quote
Old 18th April 2007, 10:59   #10
Thanked: 17 Times
I would suggest you to get a decent HU with 3 pre outs if your current HU doesn't have it. Pioneer 5950 is a good option available below 8k. Get compos for front and 5.25" coax as told earlier. Power everything from the HU. Get a JBL sub and connect it to your amp.
later when you gather some more green, get a decent 4channel amp and power your speakers from it.
Then, you can gather more green and follow Hydra's way of ICING a Palio. See it in sound off, show off section.
Old 22nd April 2007, 23:23   #11
rishibravo's Avatar
Guys I finally upgraded my ICE. This is what I got
  • HU: Pioneer 6950 with ipod docked
  • Amp: JBL GTO 75.4
  • Front Speakers: Hertz ESK165 (6" 2-way component speakers).
  • Rear Speakers: Hertz ECX130 (5" co-axial speakers).
  • Subwoofer: Image Dynamics IDQ12 D2V.3 12.25" Sub in a custom-built Sealed Box.
  • Damping: will go fot dynamat if needed
  • Cables: Connection Audison power cables & Connection Audison RCA interconnects and Speaker Wire.
  • Install: install job by DRIVEN
Special Thanx to JB and Manik ......
Thanks guys for guiding me through the upgrade...
Old 22nd April 2007, 23:40   #12
Thanked: 294 Times
now it is time for the pics then.........and enjoy music.......
Old 22nd April 2007, 23:45   #13
hydrashok's Avatar
WOW! You've got one killer setup
Congrats! And PICS PLEEEEZ!
EDIT: Looks like the budget got thrown outta the window, huh?
Old 23rd April 2007, 09:22   #14
rishibravo's Avatar
Thumbs up
Guys most of the equipment went into stock location . Here are some pics of the install. Couldnt take pics while intallation was carried out.
Old 23rd April 2007, 10:17   #15
moralfibre's Avatar
Thanked: 6,533 Times
Great choice of equipment Rishi! How about a breakup of cost of the equipment that went in? How do you find the sound?
fiat palio 1.9 d help needed drnibu Technical Stuff 14 23rd February 2013 11:01
palio suspension help is needed payam Modifications & Accessories 9 12th June 2009 18:36
My palio 1.2 Elx issues, help needed desperately Rosario Technical Stuff 57 9th March 2009 13:58
2002 Palio GTX for 2.4L?? not just advice , help also needed. deetee Hatchbacks 7 13th October 2007 13:11
Urgent help needed on Palio 1.2 Dhanan Hatchbacks 9 6th October 2006 11:58
