Old 19th April 2007, 01:27   #16
Thanked: 17 Times
I am curious. Are you going to make another box for your subs? Ain't the first one good enough? Or was there any problems in it?
I think normal self tapping wood screws would do good in fixing the sub in one place. Use extra long ones with good, deep thread and pitch. The screws You've shown will be difficult to install and will look ugly too I guess.
Old 19th April 2007, 10:37   #17
Thanked: 295 Times
Ya new one will be made soon as the present box opening is a little big for the max mounting and 1 or 2 screws are not able to tighten properly......thats why i looking for a new method....also the picture I have posted is a nut which will go inside the box and the bolt head will only be visible......
Old 19th April 2007, 10:58   #18
tsk1979's Avatar
Thanked: 16,459 Times
I have used the screw you show LBM. It fits nicely and gives a real tight lock. I don't think it will come off with vibrations if you use a rubber washer along with the nut.
As for Zuari not giving this, all you have to do is go to a furniture shop. Many people are not DIY and ask these guys to assemble. They always have spare screws.
Old 19th April 2007, 12:40   #19
panky12345's Avatar
Thanked: 151 Times
must be available in Menards....let me know if u need 'em!
Old 19th April 2007, 13:19   #20
navin's Avatar
Thanked: 4,346 Times
LBM stick to your first idea (your post #4). it will work.
Old 2nd May 2007, 15:19   #21
ST7677's Avatar
Thanked: 45 Times
LBM, these are called T-Nuts and are a must for installing the subwoofer. This let's you remove the subwoofer multiple times for tuning purpose without compromising on the grip.
I have been myself looking out for these but haven't got much success.
I need 8 of them, if anyone can help!
ST7677 is offline   Reply With Quote
Old 2nd May 2007, 15:42   #22
tsk1979's Avatar
LBM, check out the home store in "Great India Mall, Noida". They have some weird looking stuff for home use(tools, nuts, bolts blah blah).
Old 2nd May 2007, 19:10   #23
Thanked: 295 Times
where is it in noida....any pointers.....
Old 2nd May 2007, 19:52   #24
Sam Kapasi's Avatar
Thanked: 1,474 Times
Where can i find this nut to tighten my woofer?
I can suggest this nut, to tighten your woofer. It will be an excellent job.
I am not referring to the appy fizz. I am referring to the nut holding it. Our very own, mad but lovable LBM.
Old 2nd May 2007, 20:04   #25
Thanked: 295 Times
upto mad is fine .....but lovable.......
Old 2nd May 2007, 20:43   #26
Thinking of a juggad…
You can use inverted 'Wing nut' onto the mounting hole.
First cut some groove on the baffel board from inside to block and secure the movement. You can use the rubber washer used in water taps to make a base for the nut and then glue it with some adhesive.
just an indicative figure
Sutra is offline   Reply With Quote
Old 2nd May 2007, 22:40   #27
tsk1979's Avatar
you cant miss it dude.
ITs the biggest mall in North India.
Right opposite Centerstage Mall(Sector 18)(Gurudwara Side).
When you come in from DND, take left just after Film city, and as soon as you hit sector 18 you will see it on your right.
Old 3rd May 2007, 14:14   #28
Bass&Trouble's Avatar
Thanked: 74 Times
I tried looking all over Bombay but couldnt find this nut.
Anyway, I have feeling you're going to get into some trouble with santosh.s (not singh) over this. Good luck explaining what you have here calling a poor, vulnerable and pitiful appy-modelling sardar, a piece of hardware.
Old 3rd May 2007, 14:32   #29
navin's Avatar
From the grin on LBM's face I believe the Appy was spiked.
Old 3rd May 2007, 15:08   #30
Thanked: 295 Times
till the photo was then the bottle was sealed....the grin is because of something else.....
Tighten the mirror? DjNik In-Car Entertainment 15 11th June 2013 11:16
Hero honda splendor - Which nut to open to change oil? vinfriend Motorbikes 1 27th August 2007 12:03
A complete nut case S Pathak Street Experiences 17 10th January 2007 20:36
One more car nut joins the team.!! Hellraiser Introduce yourself 13 10th December 2006 23:55
Car Nut from Dubai.......Samaj! Samaj Introduce yourself 7 26th December 2005 15:29
