Old 12th May 2007, 23:40   #61
JPL
Regarding the door panel ( well that was one my main concerns when I Iced my Santro) I will get the prices on tuesday ( servicing my car) you may also have seen hydra elaborate that MDF gives better damping against the stock door panels. however please check the cost of replacement door panels and let me know also, if sooner.
Even with the stock door panel and with the JBL GTO 607 you will need damping ( no fibre thingy) to reduce the vibrations coming from the 6.5 compos and making the front door rattle. More infor here, actually a guide to damping. Vibration Damping Installation Guide
Regarding the installer, hyderabad guys will need to help. I am not very sure but installation will be expensive at sprocket. Better to go there if you need to purchase high end stuff but installation elswhere.
JPL is offline   Reply With Quote
Old 13th May 2007, 09:51   #62
romyeo4u's Avatar
Thanked: 13 Times
Default how much does MDF cost
ok ...now I pretty much wanted to go for the comps against my bro and friends.
i'm stuck with these questions
how much does MDF cost ? even if get one do i need to do damping ?
if i ask them to use the OE door pad do i need to use more damping?
when is the Fibre glass used and wht for is it for MDF or doorpad
good installers in HYD .....please
romyeo4u is offline   Reply With Quote
Old 13th May 2007, 14:18   #63
romyeo4u's Avatar
Thanked: 13 Times
Its clear now
My existing config:
GTO 937 rear
HU pio 5990 IB
upgrade plan:
AMP 75.4
Sub 4-12 ( should i go for 1204 or 4-12 and sealed enclosure?)
front would it be good if i go for 507 without touching the door pad or 607
do i need to do the damping if so how much will it be ?
for moulding he said it will cost 3400 what exactly will it be ?
any good installers in Hyd? SPROCKET is he a good installer ?
Old 13th May 2007, 14:30   #64
nura's Avatar
The Santro front door pads cost 1.5K each. I think Hydrashok's suggestion is better. Either go for MDF & preserve the original pads or cut the original pads & when selling the car, remove the expensive speakers & fit cheap ones.
By the way, is it possible to fit 4'' speakers into a 6.5'' hole?
nura is offline   Reply With Quote
Old 13th May 2007, 14:39   #65
Thanked: 294 Times
It is possible but the finished job would not look nice....so it is better to get cheap 6.5 inch speakers instead.....
Old 13th May 2007, 14:59   #66
nura's Avatar
Oh dash! I thought I'd found a way to save some money & get rid of my fake Pio 4 inchers, which have been lying around for the last few years.
But before that I have to hear some speakers, buy, fit, enjoy (hopefully) & get fed up of the old car. So it's still some way to go.
Old 13th May 2007, 16:37   #67
romyeo4u's Avatar
Thanked: 13 Times
I spoke with the guy who installs in SPROCKET in HYd .
he was talking about Fibre glass which has to be ordered if i have to go for 607 wht does he mean by that and it costs 2800/- is he talking abt MDF itself?
If its Fibre'd do i need to go for the Damping again ?
Old 14th May 2007, 18:54   #68
romyeo4u's Avatar
Thanked: 13 Times
any good installers in HYd please
I went to MOTOAXIS
the prices of JBL are of the MRP and he was not ready for the Discount.
I have asked him for the installation he said 1900/- which is very expensive.
Now I'm stuck with this question:
if I go for 607 for front .. the door pad has to be cut through, SPROCKET guy was talking about some moulded Fibre glass which has to be ordered and it will cost 2800/- what is he talking about? any clues
Old 14th May 2007, 20:29   #69
hydrashok's Avatar
@romyeo4u, answer posed here in response to your post (see post no. 5921):
http://www.team-bhp.com/forum/ask-gu...new-q-395.html
About the fiberglass, he was probably planning to fabricate a speaker pod with fiberglass in the front door. Strictly speaking I don;t think that is required -- a well damped OE door pad (cut, of course) or an MDF door-pad should do the job at half the cost. The fiberglass pod is likely to look better, though (if done properly).
Old 14th May 2007, 20:44   #70
romyeo4u's Avatar
Thanked: 13 Times
Thanks Hydra .... you are the man to look for
how much will MDF cost and I have to go for damping also is that correct?
If i let my OE door pad cut then all i have to go for is Damping then this way is cheaper rite compared to FIbreglass which is 3000 and damp another 3000.
what is your say
Old 27th May 2007, 15:40   #71
nura's Avatar
If I were to get Hertz ESK163S 3-way components for the front & Image Dynamics IDQ 10" sub for the back, what would be the best choice of amp(s)?
Option A
Audison SRx3 driving components & sub
Option B
JBL GTO75.4 driving components & sub
Option C
JBL GTO75.2 driving components (would have to be sourced from abroad)
JBL GTO601.1 driving sub
Have not bought anything yet, as I'm still waiting to hear the stuff.
Thanks in advance.
Old 27th May 2007, 16:05   #72
Thanked: 294 Times
I would recommend 75.4 as it will be value for money option....the audison will be a expensive option here...
Old 28th May 2007, 00:15   #73
hydrashok's Avatar
what is your say
MDF should not run to more than 1500/- to 2000/- max including labour.
Between Fiberglass & Cutting doorpad I thnk cutting the door-pad and damping it will work out to be a lot cheaper.
Old 28th May 2007, 00:20   #74
romyeo4u's Avatar
Thanked: 13 Times
Thanks Hydra !!!!
I got the door pad cut rather than have the Fibre thing and i was not happy and not convinced by that.
he couldnt get the bigger one whch was 2500/- instead he told me he bought a smaller one for 1500/- which was a fibre ring. and lucky me it was broke . so i got lucky by not paying the 1500/-and asked him to cut the door.
now the Damping is left . might do it next week.
Old 28th May 2007, 00:30   #75
hydrashok's Avatar
Option A
Option B
Option C
I'd take option 1 or 2. Choice will depend on your listening taste & budget. The Audison sounds a bit warmer and the JBL sounds a bit brighter. Better listen to both and decide. Then of course, it's between 13K for the 75.4 and 30K for the SRx3
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Knocking Sound in Santro Vys De BlUR Technical Stuff 24 14th June 2009 20:38
Knocking Sound in Santro Vys De BlUR Technical Stuff 0 5th March 2008 18:38
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Knocking sound from the rear of my Santro psynaps3 Technical Stuff 7 20th April 2006 02:07
