Old 27th April 2007, 22:09   #31
binz's Avatar
Thanked: 412 Times
Beautiful car,.. beautiful Equipment and an amazing install.
Originally Posted by mojo View Post
First of all,with ice, .
Now wont the parcel tray vibrate a lot when the subs plays really low ?? I mean shouldn't it get some damping ??
Old 27th April 2007, 22:19   #32
there is no vibration...
mojo is offline   Reply With Quote
Old 27th April 2007, 22:47   #33
Autophile's Avatar
The bass from ID 8's is low and tight and nothing vibrates in the car.
The sub level controller is a must in this install as the head unit only has front and rear speaker level output, so to control the sub level the Audison VSR controller is used.
Simple setup but mind blowing sound.
How the system is wired.
The front output of HU goes to High Level input of SRx 1 (Mono amplifier
) which gives full range preout to SRX 4's (Ch A), and the rear speaker output of HU is connected straight to SRx 4's (Ch B). The SRx 4 takes care of front and rear Hertz Hi Energy speakers.
2 X ID8v3 D2's in 0.3 cuft sealed enclosure are connected in parallel to SRx 1 which gives 350 Watts in 2 ohm.
The remote turn on is taken care by SRx 1 which converts remote turn on by sensing signal from high level inputs and also gives out remote turn on for more amplifiers.
All the cabling is by Connection Audison, 14 AWG for speakers and subwoofers and the power section is taken care by 4 AWG kit distributed in two amplifiers using 8 AWG cables.
No modifications / cutting was done to car for this install apart from two holes for Ipod & Drive + Play cables.
Autophile is offline   Reply With Quote
Old 28th April 2007, 00:15   #34
esteem_lover's Avatar
Thanked: 451 Times
There was no going back once I met with the guys. It just happened that Autopsyche's 3000GT had just been finished, and once I heard his setup, things got out of control! Favorite track to listen to now is "The End". It gives me goosepimples!
The End ??? i think i am OLD. i don't know that song. who has sung that ? So does that mean it is really the end for Jim on your car ? i hope you have not fallen for the 'sound is more important than the music' stuff. I love the sound, but i love my music more than the sound. But thats how I am. I hope you enjoy your sound.
Old 28th April 2007, 07:09   #35
jkdas's Avatar
Thanked: 1,436 Times
......beautiful.....
another excellent job by our hero from Delhi
Old 30th April 2007, 11:33   #36
Technocrat's Avatar
Thanked: 2,589 Times
Thanks for the clarification, Moral, Hydra, Gunbir & JB.
@JB: you mean to say the subs are driven by the front's output routed through the SRx1 & this very connection is given as preout to SRx4 ??
Old 30th April 2007, 14:20   #37
Bass&Trouble's Avatar
Thanked: 71 Times
I think that's exactly what he means.
Old 30th April 2007, 14:49   #38
Technocrat's Avatar
This was something very new for me hence asked. Sorry if it sounds very obvious to you guys :|
I didnt knew that Sub can be driven from same output as speakers. As a matter of fact it cleared one of my query, I always wondered how can subs be run if there is no pre out for Sub & now its clear to me
Old 30th April 2007, 15:35   #39
Thanked: 71 Times
The sub out of head units is a filtered part of the original full range signal intended for the speakers. When you dont have a sub out, you can take that full range signal, and let the amplifier do the filtering. Thats what is done here. Result is the same. Only, you cant control the sub from the head unit, change levels independently etc. thats all.
Old 30th April 2007, 15:40   #40
Technocrat's Avatar
Ok that was some nice gyan
Btw why was the front's out put used for Sub & why not rear? Was it to sync the sub with Front comps so that the imaging gets better ?
Old 30th April 2007, 16:05   #41
Thanked: 71 Times
Either could have been used. There is no effect on imaging etc with either of the arrangements. My guess is that Autophile would prefer to fade the level of the fronts and sub with respect to the rear if required, rather than having the rear and subs constant.
Old 1st May 2007, 13:39   #42
Wink Old is gold!
Dear Esteem_lover... only if you are on the older side would you know "The end". Its my favorite track of Jim Morrison's (The Doors).
I would admit that in the first week after installation I went around looking for tracks that would sound the best. Since then however I have fallen back to my Old! favorites. Having said that, the range of music that I listen to now has increased because, frankly, they dint sound so good before.
Old 28th May 2007, 02:32   #43
theEnd's Avatar
Truly an amazing song! (you can tell I like it a lot) It has a little bit of everything in it.
theEnd is offline   Reply With Quote
Old 14th June 2007, 22:47   #44
SRK
SRK's Avatar
Thanked: 356 Times
HUMMER!!
Hey where is that hummer??
Its looking really beautifull with all that chrome on her,,
By the way loved the way you got your soundsystem done..
But does it have a good effect with the original HU..Will changing HU get some more quality output?
SRK is offline   Reply With Quote
Old 6th August 2007, 19:35   #45
rosh_aveo1.4's Avatar
Thanked: 310 Times
Wow. One of my fav cars and now I seen it come with an amazing ICE install. Neat, subtle and yet powerfull. And it's iPod compatible!! The perfect blend!! Kudos to you Mojo!!
rosh_aveo1.4 is offline   Reply With Quote
Stealth Warship INS Kochi commissioned HolyDriver Commercial Vehicles 18 10th October 2015 11:06
Stealth Bull! Lamborghini Aventador with Radar and Laser Jammer Scorcher The International Automotive Scene 4 13th April 2012 22:45
Stealth with good SQ Possible on a 70K (excluding HU) budget? vipul_singh In-Car Entertainment 40 24th September 2008 10:22
PICS: 2006 Movistar, 2007 FZ6, 2007 Hornet 600 BunnyPunia Superbikes & Imports 39 13th August 2007 20:51
