Old 30th April 2007, 13:34   #1
Ad1tya's Avatar
Default Sound Advice needed for 2 Cars.. A Palio and an Accent..
Hey..
Alright, I already have a Palio. May just go in for a 1.6L Palio Stile, but anyways, I guess the boot space is around the same.
My Budget for audio is around 40k, MAX 50k. Id prefer to keep it under 40k.
Things I have, but prefer getting rid off, 6" Front Speakers, 6x9's 3 Way Pio's.. a 4950 HU.
Palio..
Requirements are everything... max Budget 50k, Prefer under 40k.
New HU (Pio 6950?)
- 6" Front Speakers (Pio's?)
- 6x9's Coaxial Rear Speakers (Was thinking of JBL GTO937's)
- 1 x 15" Sub (was thinking a 15" Kicker), or 2 x 12" Subs (2 x Premiers?).. I love bass, the more the bass the better. Issue is, Since there isnt much boot space in the Palio, I want only 2 Amps, 1 to drive the Woofer(s) and 1 to drive the 4 Speakers.
- Which amps? Was thinking of a Pio 800W Mono for the Woofer(s)..
- What about the 4-Way?
- Wiring, Sub Enclosures (Custom ofcourse?, I want 1 side, like the side open to the Boot, Plexiglass...)
Accent..
Alright, this is for my friend.
He has a MAX. budget of 60k, Excluding the HU, he already has a 8850...
2 amps (Pio's?)
2 rear speakers again (GTO937's?)
front speakers
Single woofer\basstube
enclosures
cabling
Thanks the Help!
Ad1tya!
Ad1tya is offline   Reply With Quote
Old 30th April 2007, 15:02   #2
payam's Avatar
dude
i think your budget s not sufficient for your list,i assume the price list for you:
1.head unit=9-10k
2.front=6-7k
3.rear=6-7k
4.2subs??!!!i dont know about kicker but you can gt jbl by 7-8k (each)=14-16k
5.amp=again i can give you jbl 13k(each)=total 26k
total=62-66k
payam is offline   Reply With Quote
Old 30th April 2007, 15:09   #3
payam's Avatar
let me tell you something as you are a palio owner like me.
there is no need to have 2 sub in palio as one sub can give you the bst of bass worlds.
regarding to your budget i suggest you to go to ice threads and search,you can find the best stuffs according to your budget.
ooops ,i didnt calculate for wiring and costume for your set up.
again i assume 10k for that.
Old 30th April 2007, 16:37   #4
navin's Avatar
Thanked: 4,282 Times
Originally Posted by Ad1tya View Post
Palio..[/b]
Accent..He has a MAX. budget of 60k, Excluding the HU, he already has a 8850...
some ideas. The gurus will chip in later.
40K....
Damp front doors: 4K
Get good RCA cables: 3K
HU: 8-9K fron Blau, Pio, Kenwood
Amp: 7K for a Pio
Speakers: 10K for components (front) and coax (rear) JBL, Energy, Blau THx
Sub: 7-8K (12" in box) same as speakers
60K...same brands asa above unless mentioned.
Damp front doors (4K), trunk (2K) and undercarpet (4K) : 10K
RCA cable: 3K
Power cable: 3K
HU 10K
Amp: 13K for the JBl 75.4 for example
Speakers: 13K Infinity, Hi Energy, Alpine, Blau Velocity
Sub: 8K for 12" in box same as speakers
Old 30th April 2007, 17:29   #5
Ad1tya's Avatar
Im getting a Kicker 15" Sub, The ES154, IIRC, for 7k...
One of my frnds dealer, gave me Quote of 32k, for 1 HU (8850 at that time), Amp (Pio 800W mono) + Sub (Kicker 15") + Soundstream Cap (I think 2000W) + Install (Sub enclosure was going to be 1 Side Plexiglass) + Good RCA Cables...
Adding to that, 5k for speakers, and 5k for another 4Way Amp. Maybe ill keep my existing front 6" Speakers?
Old 30th April 2007, 18:25   #6
hydrashok's Avatar
I think you should follow the configs Navin has mentioned.
A CAP? Seriously, I would spend that money on better power wiring, which would in itself help you avoid a Cap completely.
I think it would be a good idea to change the front speakers (if they are the OE speakers). After all, 40K is a good budget.
Here's a 40K budget system for a Palio posted about 2 weeks back: http://www.team-bhp.com/forum/ask-gu...tml#post415524
Old 2nd May 2007, 11:20   #7
navin's Avatar
There are better speakers than Sony and Pioneer. Still I would recommend to use your ears.
A good system in a poor install is not recommended. I would recommend some degreeof damping when you have a system that has a sub and and / or external amplifier.
Old 2nd May 2007, 12:31   #8
Ad1tya's Avatar
JBL GTO 937's were the speakers I was going for...
Damping is a must I know ..
Imma gonna get a system install after a week or 2. Will decide what to go with till then. The budget could rise too :P.
Old 2nd May 2007, 23:26   #9
Thanked: 13 Times
Soundstream Cap (I think 2000W) + Install (Sub enclosure was going to be 1 Side Plexiglass) + Good RCA Cables...Maybe ill keep my existing front 6" Speakers?
Plexiglass is great since its inert but it is very pricey. Just go in for a good sturdy enclosure and save the $$$. When you say 'good' RCA cables make sure you know what your getting and post back here... this is where most people get taken for a ride.
Navinji and the others have provided with you good suggestions...
Old 3rd May 2007, 02:24   #10
rocksterraghu's Avatar
Thanked: 96 Times
Accent..
If you want to keep it under 40k, I'd suggest you install components (JBL or Blaupunkt would do) for the front and save money by avoiding the 6X9's and buying co-axials instead. That way, you can install a 4-Channel Amp and drive the components and the sub through the amp. If, however, you can stretch it up to 50, you can have the 6X9's and a monoblock for the sub.
Here's how I look at it:
Under 40:
1 X HU (Pio/Blau/Kenwood) - 8k
1 X Pair Components (JBL) - 6k
1 X Pair Co-axials (rear) - 2-3k
1 X 4 Ch Amp (Pio/JBL) - 7.5k
1 X JBL 12" Tube (More the better) - 7k
Cabling and Misc - 3k
50:
+ 1 Monoblock Amp (JBL/Pio) - 7-7.5k
- Co-Axials
+ 6X9's JBL 937's - 5k
+ Better cabling
Again, YOU have to decide what is enough and what's not or what suits your taste and what does not.
And for your friend, I guess Navin's post is more than enough.
Old 4th May 2007, 12:44   #11
Ad1tya's Avatar
Thanks a lot!
Gonna decide soon..
Will post the Final config here, when I do decide .
My Accent 1.6 DOHC in trouble - advice needed rex_varghese Technical Stuff 8 5th April 2010 19:29
sound car advice needed for my dying self esteem ! jeevan Modifications & Accessories 8 18th September 2009 04:13
Advice Needed: Ford IKON Diesel(2009) engine sound too loud agent009 Sedans 16 15th March 2009 14:51
advice needed: car audio in hyundai accent amit_baghe In-Car Entertainment 273 25th December 2005 00:04
