Old 19th May 2007, 15:13   #16
tsk1979's Avatar
Thanked: 16,421 Times
He could you post your final list of parts used and costs involved.
Is the Diode Isolator power circuit DIY or you got it from somewhere?
Old 19th May 2007, 15:37   #17
navin's Avatar
Thanked: 4,282 Times
Originally Posted by abhi182 View Post
^^ Hehe, I had never even noticed that and you spotted it in a picture
On a side note, I was wondering whether to mould /mount the LCD
I am a devil for details.
THe LCD would be lovely if it cold be fliped down when not needed like a laptop.
navin is online now   Reply With Quote
Old 19th May 2007, 15:39   #18
navin's Avatar
I need to source a DC-DC PSU, but until then, it is running off a 150W 110V AC inverter (Xantrex)
The Xantrex is hooked to a Tank circuit (Diode Isoltaor based) connected to a small gel type sealed battery ....
I would keep the second battery and dual battery isolator. dont try to build a DC-DC PSU it is a pain in the neck just buy one.
semi-DIY
M2-ATX (160w) Intelligent DC-DC Car PC Power Supply
A PC in Your Car--ExtremeTech Feature: Startup/Shutdown
professional PSUs
DC-DC Regulators for CarPC automotive computers
New 160W carpc power supply | Dashboard Monkey
googling will get you more.
Old 19th May 2007, 15:42   #19
abhi182's Avatar
Thanked: 202 Times
The Diode isolator is a DIY consisting of 4X 4A diodes and a 4700uF 50V Cap
here is a tally of the running costs:
7" TS LCD (iride.in) 11400/-
Via C7 board + processor + AC PSU + Casing: 6.5K (it was a steal, the total normally would be arnd 10-11K)
Xantrex 12V- 110 V inverter: $35
Holux 236 gps: $80
80gb 2.5" hdd: 3K
512 MB ddr ram: 1.5K
BT (widdcomm): 300
rubber keyboard: 450
Tank Circuit + Wires + fuses + misc.: 1000
7AH Sealed gel type battery : 800
Satguide map for chennai (yet to come) : 800
Google earth + Goops + roadrunner: free
~26k + $105 -> 30.5k
You are right..I don't plan to build that..not worth the time that'll go into it...
As it stands, I have already spent 1 entire weekend and then average 4 hours every night (11:30 PM- 3:30 AM) from last Monday till Thursday on setting this puppy up
Will do that after all the software is done and over with (tweaking windoze, installing satguide maps etc.)
yup, that would have been great....shouldn't be too difficult if I can find the right mount to do that...the current mount is a stick on mount and so far, I haven't cut/bezelled/dremelled any of the plastics in the car so it doesn't hurt to try new locations for the LCD
abhi182 is offline   Reply With Quote
Old 19th May 2007, 15:46   #20
navin's Avatar
...7" TS LCD (iride.in) 11400/-...7AH Sealed gel type battery : 800...~26k + $105 -> 30.5k
Look on my neighbours face...priceless. :-) Ok that was OT Sorry.
Old 19th May 2007, 15:54   #21
abhi182's Avatar
Thanked: 202 Times
^^LOL.....that was a good one!
Anyway, the costs are very reasonable considering stand alone GPS units and even car dvd players come close to that price....
BTW wish me luck , am off to get a new HU right away since the stupid XPLOD (why did I ever buy that) i have doesn't have aux in and I am feeding the output through FM..
Planing to pick up a basic Alpine/Pioneer (2950 maybe) as I don't need any fancy features on my HU now
Ah, another thing I forgot to add in the list above is completing the phone integration piece...I haven't been able to get it up & running as yet..also need to get a trackball to keep in the centre console for the times I may need a mouse
Old 19th May 2007, 19:46   #22
navin's Avatar
the basic alpine (i'd recommend the 9843 of the older stock or 9812R/9883 of the newer stock) would cost 9K the Pio 2950 about 4K.
Old 20th May 2007, 03:07   #23
abhi182's Avatar
Thanked: 202 Times
Picked the Pioneer 2950..
I like the SQ of the unit (have it on my swift coupled with infinity 9623) ..
Also the price diff. between the Alpine (10K) and the Pio (3.9K) was huge...
Since the HU is going to work just as an amp, and nothing more, decided to save a few bucks in the process
Old 23rd May 2007, 18:17   #24
abhi182's Avatar
Thanked: 202 Times
Update: I installed Google Earth with GoopS, and also the Satguide map for Chennai yesterday
The Satguide map is pretty accurate (Make it very accurate) though the routing is less than perfect..The POI (points of interest) implementation could be better too
What however is awesome is Google maps...The accuracy is dead on spot, and the cool factor of seeing the actual landscape from the top is mind-blowing...Best of all, it's totally free!
The only constraint is you can't do routing (i.e. mark your start and end-points and expect the software to chart the route for you and give you visual and voice directions)
But for out-of-town trips, it's the perfect solution
Old 23rd May 2007, 18:53   #25
Awesome work. Dumb question, but where's the CPU casing mounted? And how quiet is this thingy?
ballkey is offline   Reply With Quote
Old 23rd May 2007, 21:58   #26
abhi182's Avatar
Thanked: 202 Times
not a dumb qstn at all...placing the CPU casing is one of the biggest problems
since i used a mini-itx mobo (which is really tiny) and a very small form factor casing, the whole unit went under the passenger seat and fastened with velcro
again, the Via processor is very low on power drain and heat so it has a tiny fan which cannot be heard at all
Old 24th May 2007, 01:09   #27
esteem_lover's Avatar
Thanked: 451 Times
but how good is the via processor ? they suck in home pc solutions.
Old 24th May 2007, 11:00   #28
I think the Via processor should be good enough for media playback duties. Even phones do it, with a puny Geode or something.
I like this idea a lot; I wonder if it can also be hooked into CanBus or the ECU, and provide realtime vehicle diagnostics and control. Sort of like a home-brew iDrive or MMI ...
Old 24th May 2007, 13:30   #29
abhi182's Avatar
Thanked: 202 Times
there are OBD II scanners available that can connect to a USB port to do ^^ exactly that
Old 25th May 2007, 10:40   #30
whatcanthisbe's Avatar
dude check out Road Runner Clocks for a cool clock/compass / speedo /logo for rr
also
Release new phoco integration preview - MP3Car.com for the phone integration
whatcanthisbe is offline   Reply With Quote
Another weekend, yet another Hill Station - Yelagiri Mr.Boss Travelogues 7 2nd August 2014 23:02
ANHC- Another New Honda City! One" H" to Another "H" mkh Test-Drives & Initial Ownership Reports 246 22nd December 2010 17:12
Another pavement, Another Car running over it & a few more deaths esteem_lover Shifting gears 39 26th December 2007 21:52
OH NO!! Another Ferrari Enzo crashed.. and another... and another (w/ video) GTO The International Automotive Scene 72 26th May 2007 14:09
Another crash, another fire, another death in Delhi suman Street Experiences 7 15th December 2006 15:30
