Old 18th February 2008, 16:26   #31
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by adityamunshi View Post
I dont know what exact frequencies are given to the rears but the upper limit is 125 HZ. Can this damage the speakers ?
I presume you have set the rear speaker output to subwoofer from the function menu. Similar to what the FIE used to do in older Pioneers. This means that you are only sending frequencies upto 125Hz to the rear speakers. This will not damage the speakers as such, but dont turn it up too much expecting them to churn out subwoofer-like bass. I am not sure which rear speakers you are using but could be reasonably sure that the Fs must be 60 Hz or higher.
Old 18th February 2008, 16:44   #32
adityamunshi's Avatar
Im using the Ground Zero 6x9s. I have them set up as woofers but, if i feel that its distorting i turn down the level in the subwoofer menu. Currently the sub level is set to -3, the EQ to flat and the Loud to low.
Does Fs mean the lowest frequency the speaker can handle ? If so what would be the Fs for El62s ? Ive set the HPF to 100Hz for the fronts.
adityamunshi is offline   Reply With Quote
Old 18th February 2008, 16:49   #33
Thanked: 71 Times
No point playing them in such a small band. They will distort at higher levels because the low frequencies going to them (<50Hz) is not exactly what 6x9s are designed for. I suggest you use them in full range mode with a HPF of 50Hz instead, and use the EQ to give a 1-2 dB boost from the head unit at about 100-160 Hz if you desire a little pronounced midbass.
Old 18th February 2008, 16:57   #34
Thanked: 294 Times
Upper limit is 125 HZ. Are you using it as a sub kya if yes how is it driven.
Old 18th February 2008, 17:05   #35
@LBM im using the HU to drive the rears. This is what i think im doing
Old 19th February 2008, 10:42   #36
navin's Avatar
Thanked: 4,286 Times
If you want a HPF and want to use your HU's amp you can add a bass blocker (simply a pair of 470uf electrolytic caps back to back).
navin is online now   Reply With Quote
Old 19th February 2008, 10:59   #37
Thanked: 294 Times
So I presume you using HPF at 125 hz but how can then the speaker can produce bass.
Old 19th February 2008, 12:02   #38
The fronts have HPF set to 100 Hz. The rears are as set up from the subwoofer menu with LPF set to 125 Hz.
Old 19th February 2008, 12:09   #39
Thanked: 294 Times
Yaar it is getting confusing here.
You are driving the ovals through the hu. but how can HU run in LPF mode. The speaker channels can only be set as HPF.
Old 19th February 2008, 12:23   #40
Thanked: 71 Times
Arre LBM sir, he is using the DSD feature of Pioneer head unit. Rear speakers set for subwoofer frequencies. I am sure you are not used to such ideas for driving subs.
Old 19th February 2008, 19:40   #41
Thanked: 294 Times
Oh ok ok that is FIE. Front Image Enhancer.
Old 19th February 2008, 20:16   #42
Thanked: 71 Times
Oh no no. It is DSD - Direct Sub Drive. From function menu, like you can set the rear pre-out to be sub in 2 pre-out HUs, you can also program rear speakers to play subwoofer frequencies. Sorta like the FIE, but with cut-off freq selection, and importantly, the ability to drive a single mono load (like bridging).
Old 19th February 2008, 22:19   #43
Thanked: 294 Times
Yaar I am also getting old now..Navin Ji where are you !!!!
Old 19th February 2008, 23:18   #44
LBMji
It is bound to be confusing when a newbie, who has never even listened to a proper sub (like me) tries to expain something about subwoofers to THE low frequency guru of Team BHP.
Old 20th February 2008, 00:10   #45
Thanked: 294 Times
LBMji
Hahahahaha.
I was a little out of mind and did not gave enough attention. Chalo learning new things which I like the most. Thanks.
Ground Zero or JBL mohitd In-Car Entertainment 30 16th December 2008 10:01
Review of Ground Zero SUB Radioactive GZRW 12XS-AL smokin In-Car Entertainment 21 23rd September 2008 22:07
Skoda RS ICE - Re-Done: Carbon + Steg + Ground Zero + Stinger + Optima BHAGWAN In-Car Entertainment 142 4th June 2008 14:53
Illusions and Ground Zero Available in Pune amit_mechengg In-Car Entertainment 32 23rd April 2008 16:30
