Old 24th May 2007, 12:13   #46
tsk1979's Avatar
Thanked: 16,422 Times
Thanks sam.
With HU+Amp for 19K I can manage a subwoofer in a custom made box for around 6K.
Now coming to Compo's
I understand 507 is smaller than 607.
What about
CS2165C? What is the difference between this and the 507/607 series?
Another confusion is the component dilemma.
Suppose I fit a very very good 6" loudspeaker in the door and let the amp drive it.
Then I fit the best quality 4" 2way speaker in the dash and let HU drive it, will it give me good SQ?
What if I go for a 6" 2 way thing in the door and a simple 4" loudspeaker in the dash. Too bright?
I am leaning away from 6"+tweeter combo(all component sets have tweeters right) because the tweaters I have listened to are shrilly. don't know about the JBL ones though.
So to rephrase my question, what is the advantage of a component set over buying a 6" Loudspeaker pair + 4" 2 way speakers and having everything in front.
Old 24th May 2007, 12:15   #47
tsk1979's Avatar
TSK, If I were you I'd wire everything, damp the doors etc. and add the sub and amp later. sortof build slowly. But if 30K is your budget and not a penny more then the Blau amp is not a bad deal. I have heard the 450 and 470 and if it at that level it will suffice for now. Someday you can get a cleaner amp. Actually see if your dealer can get your a Pio 6100 (old) or 6200 for 6K. then hear both (Blau and Pio) and choose.
Originally Posted by low_bass_makker View Post
Ya tsk add the sub later if it is getting tight on budget....this was you can have it in parts...this is what I would do....
All right, a little birdy told me a 6100F second hand amp may be available, but will see if its still there when I go for system.
So if I go for the best VFM amp, I just get compo's and AMP+HU and save up for a nice 8K subwoofer and get it fitted later, right?
So in the intermediate period which speaker+amp+HU combo will give me great SQ. I know I wont get sub type BASS but I think good speakers can deliver nice BASS?
Old 24th May 2007, 12:22   #48
navin's Avatar
Thanked: 4,286 Times
a components set has a pre set balance to the sound. By going outside that orbit you are now depending on your ears and skills to produce a balance that you prefer.
If you want to go for a 6" coax (door) and a 4" coax (dash) you can "tune" the sound by tinking with the tweeter caps.
Old 24th May 2007, 12:23   #49
navin's Avatar
Speaker+Amp+HU for 30K?
Old 24th May 2007, 12:29   #50
tsk1979's Avatar
Hmm so its not the components, but adjustments with Bass and treble and equalizer settings. I was thinking of going with 6" Loudspeaker(no tweeter) in door, and a 4" 2 way in the dash.
Umm nope, around 25-27K. If I can push to 25K I can get a 12" sub and a box made for 6K and fit everything within 31K. See 1K my budget went above.
If it goes to 27K I can wait for 6 months for the sub and buy a 14" with box for 8-10K.
Another question, why doesn't anybody talk about tubes? Are they bad?
Old 24th May 2007, 12:32   #51
Thanked: 294 Times
Ya they will not sound good when compared to boxes.....
Old 24th May 2007, 13:46   #52
tsk1979's Avatar
On the HU front I see the following
DV8305 DV8306 : Both have the same features, but look different
DV7305 DV7306 : bluetooth which I don't need. Does not have multi color display and no 5V line output level in specs(what does it mean?)
So can anyone tell me the approx price of these 4 units. The 8305/8306 have everything I need.
PS: There is a 7206 also but it only plays mp3 via the USB port.
Old 24th May 2007, 13:52   #53
Thanked: 294 Times
5v volts out is the RCA output level which will be used to connect the hu with amp....you can dump this feature as it will not effect the sq of the whole setup...look for other features like usb gigamp3 dvd....
Old 24th May 2007, 14:37   #54
tsk1979's Avatar
Gigamp3/USB Port/DiVx is there in all 4 options I have.
Any idea about the approximate costs.
I was checking 5.1 surround but thats there only in the multimedia series which start from 21K. So I guess only if I had 50K budget that would make sense.
Old 24th May 2007, 14:45   #55
Bass&Trouble's Avatar
Thanked: 71 Times
You would also need rear speakers for it to make sense, and a center channel of course.
Old 24th May 2007, 14:47   #56
tsk1979's Avatar
Eggxactly. Thats why looking at the above said models.
Once I know the price of the 4 models, I can balance the remaining moolah I have among rest of the stuff.
If I get a multimedia reciever, I can say TATA to the AMP and subwoofer and just have speakers.
Old 24th May 2007, 14:48   #57
navin's Avatar
Umm nope, around 25K?
HU: 9K with the features you want
Speaker: 6K for components mayeb you can get the CS series for 5K.
Amp: 10-11K maybe a JBL dealer will get you a 75.4 for this price.
now you have to start hunting.
Old 24th May 2007, 16:41   #58
tsk1979's Avatar
HU: Nobody has replied to the prices. Where did all ICE guys go!?
Compo's : Here I am seriously confused. Can somebody enlighten me.
Is the only difference between components and simple nice loudspeakers 2way or 1way or 3way is that the loudspeakers have to be manually tuned?
Sub: Since my budget is 25K, which is the best VFM sub for < 8K(Including box)
Old 24th May 2007, 16:53   #59
Sam Kapasi's Avatar
Thanked: 1,473 Times
I'll answer you.
The CS2165C costs 5K and it is last years GTO component (GTO606Ce) with an inline crossover. It is good, for the money but the GTO607C (new 7 series GTO) is a better component set, with an external, user-adjustable crossover and it costs Rs.6500/-.
Old 24th May 2007, 16:58   #60
tsk1979's Avatar
Sam, If I get GTO607C then will my setup
HU+75.4+607C+(6K Sub in box) sound good. As of now rear speakers are not in equation. Are rear speakers needed for good sound, or you can create nice sound with just good components.
10 lakh budget. New car, used car or wait and increase budget? Tejas@perioimpl What Car? 59 2nd May 2014 12:03
Rajasthan State Budget: Expensive Cars & Petrol get cheaper ! akhilesh51 The Indian Car Scene 0 27th March 2012 18:45
SQ Setup for Polo (budget-friendly install) Youcanburn In-Car Entertainment 19 12th February 2011 14:20
Budget 2010 : Petro products by Re 1 & Cars to be 2% expensive, StarVegabond The Indian Car Scene 40 2nd March 2010 20:26
World's 10 most expensive car auctions.. _Crazi4Speed_ Shifting gears 4 11th May 2004 07:44
